Get Samsung NX1 H.265 Workflow to Premiere Pro/Sony Vegas Pr
Postod Andyeric » 02.02.2015 5:05
Trapped in the trouble of H.265 footage shot by Samsung NX1 camcorder? How much do you know about the latest codec H.265? Do you think it is only the upgraded version of the former H.264? Whatever, this new H.265 footage seems not so friendly with Adobe Premiere Pro and Sony Vegas Pro, so we need to find some solutions to get rid of the trouble. In this article you can receive some efficient solutions here.
Professional explanation of H.265/HEVC codec:
H.265/High Efficiency Video Coding (HEVC) is a video compression standard, a successor to H.264/MPEG-4 AVC (Advanced Video Coding), that was jointly developed by the ISO/IEC Moving Picture Experts Group (MPEG) and ITU-T Video Coding Experts Group (VCEG). HEVC is said to double the data compression ratio compared to H.264/MPEG-4 AVC at the same level of video quality. (Let's Have an Intensive Talking on H.265/HEVC)
What's the Prospect and benefit of H.265 codec?
H.265 is the codec of the future, we have advanced to that time, and rolling a way back machine back to now, by giving to users an affordable and easy HEVC video converter. See the results yourself With the H.265 encoder incorporated on Cinec we achieved the following result, by converting a ProRes file of 550MB to a H.265 5MB file with almost no noticeable difference at normal screens, look yourself.
See Also: Professionals Favorite H.265/HEVC Video Encoder/Decoder – Smaller Size and Higher Quality
Key features of Samsung NX1 camcorder:
  • 4K (DCI 4K & UHD) video recording using H.265 codec
  • Can output 4:2:0 8-bit 4K video over HDMI
  • Stripe pattern AF illuminator with 15m range
  • Weather-resistant magnesium alloy body
  • USB 3.0 interface
  • Optional battery grip
What a pity that the output footage H.264 cannot be accept well by Adobe Premiere/Sony Vegas! In order to get a nice watching of these videos, we need to do some changes. Luckily, we have the Pavtube NX1 H.265 Video Converter, with the upgraded version 4.8.2.0, it can work the H.265/HEVC codec well. As we all know the best codec for Adobe Premiere and Sony Vegas is MPEG-2, so we just transcode our NX1 H.265 footage to MPEG, right? Let's do it!
See also: Adobe Premiere Pro Supported Formats
Guide on how to transcode H.265 from Samsung NX1 to MPEG for editing in Adobe Premiere Pro and Sony Vegas Pro.
Step 1. Load your H.265 files into this best H.265 Video converter.
Install Pavtube H.265 Video converter on your PC, then load your H.265 files from NX1 by clicking 'Add video' and 'Add from folder', or just drag-and-drop your NX1 H.265 files in this interface.
Step 2. Choose "MPEG-2 (*.mpg)" as your output format
Come to the output list, just select the suitable formats for Adobe and Sony Vegas. Tap the 'MPEG' in the searching box is okay. Or drop down the list, nearly on the bottom of the list, we can find the 'Adobe Premiere Pro/Sony Vegas' >>'MPEG-2 mpg' there. Just as follows:
Tips: Encode your original videos to H.265 codec for enjoying with nice effects? On the output list, select the 'HD Video'>>'H.265 HD Video(*.mp4) there. I have to mention you that though H.265 coded has the higher definition, it will take you much more time to work with. (Convert H.264, MP4, MOV, AVI, MKV, FLV to H.265 video)
According to the workflow, usually for those advanced users, it is not a bad idea to adjust the output videos in the 'Settings' button. Such as the 'video codec', video size, bitrates or even the audio channels. Surely you can leave the default as usual.
At the end of this paper, if you have finished the preparation, back to the main interface, just hit the 'Convert' to get this NX1 H.265 to MPEG-2 conversion started. Or any other suggestions or better methods you can leave the message below, okay?
Additionally, we also found a third-party plug-in released by Cinemartin, it is initially for Adobe Premiere Pro which allows users to export sequence timeline to all versions of prores or HEVC/H.265. Just look the short videos below as referene
Youtube guides video url: https://www.youtube.com/watch?v=JaZDpXwoT_o
More related:
Source: http://1080p-video-tool.blogspot.com/20 ... miere.html
