Play NX1 H.265 videos with QuickTime on Windows 8.1/8
Postod JeanLiu » 23.01.2015 10:20
Want to play NX1 H.265 videos with QuickTime player? Here, I recommend you the easy way to convert Samsung NX1 H.265 to QuickTime MOV on Windows 8.1/8.
The NX1 is Samsung's flagship mirrorless interchangeable lens camera and video is also a big part of the NX1. It can record video at 4K/24p or UHD/30p video and also uses the new H.265 codec that offers the same quality as H.264 but at half the bit rate (and file size). Watching NX1 H.265 video with QuickTiime is highly intriguing and gives real life experience to the viewers.
However, when dragging your NX1 H.265 video files to QuickTime for playback, you'll be informed H.265 is not in a format that QuickTime player understands. Thus, you may have to convert NX1 H.265 to QuickTime supported MOV format before playing. Read on to learn details on how to transcode your Samsung NX1 H.265 videos to QuickTime MOV on Windows 8.1/8.
To finish the job, what you need is a video converter tool that supports the NX1 H.265 file to MOV conversion without compressing the video quality. Here Pavtube Video Converter Ultimate is an all-in-one tool that can help you to convert and decode NX1 H.265 videos within one stop.
Now! Pavtube Software officially released its 2014 Christmas Deal. UP to 50% off is provided lasting to January 31th 2015. Don't miss it! And find more 2014 Christmas Crazy Promotion at Pavtube Facebook.
Money Saving Boundles:
Just like the way it is dealing with 1080p videos, this upgraded version supports converting NX1 H.265 videos in any formats faultlessly. With it, you can fast convert NX1 H.265 videos to QuickTime playable format with least quality loss on Windows 8.1/8. And you are free to customize the output resolutions to any size the users want.
How to play, view Samsung NX1 H.265 videos in QuickTime Player
STEP 1. Load NX1 H.265 footage
Launch the NX1 H.265 Video Converter. Drag & drop NX1 H.265 files to the program directly and your files would be added instantaneously. Or you can head to the "Add Video" button to locate the NX1 H.265 videos you want to add. Also you can convert XAVC for QuickTime playback.
STEP 2. Select output format
Click format you choose MOV as target format. This video app offers the QuickTime Movie Format for you. Or, you can also choose "Common Video -> MOV - QuickTime (*.mov)" as the output format.
STEP 3. Tweak video, audio settings
Click "Settings" button; you can adjust video and audio settings, including codec, aspect ratio, bit rate, frame rate, sample rate, and audio channel. To down-convert NX1 H.265 to 1080p for easier playback, you just need to adjust video size to 1920*1080.
STEP 4. Start NX1 H.265 to QuickTime conversion
Hit the "Convert" button to let this smart converter start encoding NX1 H.265 to QuickTime .mov on Windows 8.1/8. When the conversion is done, you can play the converted NX1 H.265 videos in QuickTime player without hassle.
Additional Tips: Some guys recommend third-party H.265 video player apps like VLC, DivX Player, but all of them can't be an ultimate solution for all NX1 H.265 videos. To have a smooth NX1 H.265 playback on Windows/Mac, this professional NX1 H.265 Converter is the best choice.
With it, you can also convert your NX1 H.265 video to Premiere, Avid Media Composer for editing.
Source:http://compatibleformat.snappages.com/blog/2015/01/14/play-nx1-h-265-videos-with-quicktime-on-windows-8-18
