Download, Convert HD Videos/Movies on Windows 8.1 (Pro)
Postod JeanLiu » 20.01.2015 11:47
Summary: Want to find an easy way to play MKV, VOB, Divx, AVI, Tivo, WMV, MTS, MXF, M2TS, FLV, F4V, 3GP, M4V on Windows 8.1(Pro) ? Check out this tutorial on how to convert all kinds of HD videos with supported video format to Windows 8.1(Pro).
“After upgraded Windows 8 Pro 64bit, I found the players work with the files sometimes, and sometimes display that my favorite HD videos or whatever it is. and other times the files play the audio, but display the green thing. Just like stuttering video, choppy video playback, or poor display performance can happen when I play videos, they aren’t working properly. My problem is that not all these formats are supported by windows. How to watch these movies easily on Windows 8.1(Pro) with ease? Is it fixable?”
As we know, We can't play MKV, AVI, VOB, WMV, MPG, M4V, Flash video(FLV/F4V) , etc. HD videos on Windows 8.1(Pro) directly. Well, to play MKV, VOB, MPG, Tivo, MTS, FLV/F4V on Windows 8.1(Pro), the easy way is that to convert HD video to Windows 8.1(Pro) with compatible MP4 format using Video Converter for Windows 8.1.
Here Pavtube Video Converter Ultimate is your best choice. It can support windows 8.1/pro with easy quick interface, and great final file quality. It supports batch conversion and you can also trim, crop, add special effect, deinterlace or edit audio to your video files.Great News!!! Pavtube Software officially released its 2014 Christmas Deal. UP to 50% off is provided lasting to January 31th 2015. Don't miss it! And find more 2014 Christmas Crazy Promotion at Pavtube Facebook.
Money Saving Boundles:
How to Enable HD Videos/Movies to playback on Windows 8.1(Pro)?
Step 1. Load HD Video files.
Fistly download it. After downloading, install and run the best HD Video Converter Ultimate on your PC, And click “Add Video” button to load your MKV, MOV, MTS, M2TS, VOB, AVI, AVCHD, Tivo...video files.
Step 2. Select compatible video format.
Click “Format”, find “Commen Video” -> H.264 Video (*.mp4)” as Windows 8.1(Pro) most compatible format.
As your Windows devices, you you need to set a format for 1080p/720p HD video to Windows 8.1/8 tablets/phones conversion. Click “Format”, find “Windows” -> Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)”.
If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish. According to my experience, the file size and video quality is based more on bitrate than resolution which means bitrate higher results in big file size, and lower visible quality loss, and vice versa.
Step 3. Start Converting.
When the above mentioned steps finished you can click the big red "Convert" to start converting MKV, AVI, VOB, MPG, Tivo, WMV, MTS, M4V, FLV/F4V to Windows 8.1(Pro) at fast speed.
After the conversion, click "Open output folder" in conversion window or "Open" in main interface to get the generated mp4 files and transfer them to your all portable devices for joy. Have fun!
To enjoy all the HD videos, Blu-ray movies, ISO/IFO files and DVDs on your Windows 8.1(Pro), Pavtube can also solve your problems.
Source:http://filmholics.tumblr.com/post/95273134610/convert-hd-video-to-windows-8-1-pro
