How to Watch Video TS Files
Postod JeanLiu » 22.12.2014 10:10
http://forums.techeblHow to Watch Video TS Files
This article mainly discusses convert Video TS files from your DVD disc to play on Windows/Mac without limitation.
The video files on a DVD are encoded using the MPEG 2 format, which can also be played on most computers using multimedia playback software. However, a DVD's file structure requires the MPEG 2 videos to be stored in a very specific way, beginning with the files all being added to a folder called "Video_TS." As all DVD discs are required to use this specific file and folder structure, most multimedia playback packages for your computer are able to recognize Video_TS folders and decode the MPEG 2 files stored within.
Option 1: GOM Player
Step 1
Download an AC3 audio codec to your computer (see Resources), right-click the file and select "Extract Here."
Step 2
Double-click the setup file and allow the codec to install. This enables your computer to decode the audio component of the DVD files stored in the Video_TS folder.
Step 3
Download and install GOM Player on your computer, using the "Standard Installation" option when prompted (see Resources). This associates all compatible files with GOM Player, making it your computer's default multimedia player.
Step 4
Open the Video_TS folder on your computer and double-click the "VIDEO_TS.IFO" file. GOM Player automatically launches and displays the "Codec Finder" function. Click the "Find Codec" button. A search page opens in your computer's Web browser with a link to the required MPEG 2 video codec.
Step 5
Click the link to download the MPEG 2 video codec, and then double-click the file to install it once download has completed.
Step 6
Click the "VIDEO_TS.IFO" file in the Video_TS folder again. GOM Player automatically launches and playback of the Video_TS file begins.
Option 2: KMPlayer
Step 1
Download and install KMPlayer on your computer and launch it once installation is complete (see Resources).
Step 2
Click the "File" menu and select "Add Folder."
Step 3
Navigate to the Video_TS folder on your computer, select it and click "Open." Playback of the files within the Video_TS folder begins.
Opiton 3: Media Player Classic
Step 1
Download and install Media Player Classic on your computer and launch it once installation completes (see Resources).
Step 2
Click the "File" menu and select "Open."
Step 3
Navigate to the Video_TS folder on your computer.
Step 4
Click the "VIDEO_TS.IFO" file in the Video_TS folder and click "Open." Playback of the files stored within the Video_TS folder begins.
Tips
  • You may not need to install the MPEG 2 and AC3 codecs for a new multimedia playback package if they have previously been installed on your computer by a different multimedia package.
  • Media Player Classic and KMPlayer have the MPEG2 and AC3 codecs built into their software, negating the need to install them separately.
  • You do not need to select each individual file in the Video_TS folder. After clicking the "VIDEO_TS.IFO" file, your multimedia playback software detects the other files stored in the folder and opens them automatically as required during playback.
  • An "Audio_TS" folder is also present on a DVD disc, but isn't typically required for playback on your computer.
However,due to codec issue, you will find that Video TS files are not supported by some media players or mobile devices by default. To play Video TS Files in Windows/Mac without any crashing issues when watching, a quick workaround is to convert the Video TS to common formats (like AVI, MOV, MPEG, WMV, etc) to fit the local media player with Video Converter Ultimate from Pavtube.
Money Saving Boundles:
ByteCopy($42) + DVD Creater($35) = Only $44.9, Save $32.1
ByteCopy($42) + Vidpie($29) = Only $54.9, Save $16.1
ByteCopy($42) + MXF MultiMixer($45) = Only $69.9, Save $16.1
If you are Mac users, you can try Pavtube iMedia Converter for Mac.
Below is easy steps for you, you can convert Video TS files to compatible formats for watching on Win/Mac.
Step 1: Add Video TS video files
Run Pavtube Video Converter Ultimate, and then click "Add Video" add to import the Video TS video files to the converter.
Step 2: Choose output format to fit your media player.
In “Format” drop down list box, you may select best video format for plaing.
For example,
You can choose "WMV HD(*.wmv)" from "HD Video" for Windows Media Player.
And select "MOV - QuickTime(*.mov)" from "Common Video" for QuickTime Player.
Step 3: Start Convert
Click “Convert” in the main interface to start transcoding Video TS videos.
After conversion, you can use converted Video TS files for playback easiliy and smoothly on your media player. Now choose the best method to play Video TS extension video files on PC and Mac!
References
GOM Lab: How Do I Watch DVDs With GOM Media Player?
FileInfo.com: What is the Purpose of the VIDEO_TS Folder On My DVD?
See also:
Can WD TV (Live, Plus, Hub) play DVD VIDEO_TS folder?
Best solution to view VIDEO_TS files on Windows 8.1/Mavericks
How to Convert DVD Folder Video_TS to MKV format
Play Video_TS files on Android and iOS tablets
Samsung Galaxy Note Edge Media Formats and Media Files Transfer
Pavtube iPhone 6 Topic to Maximize Your Entertainment
Source:http://device-camcorder-tips.blogspot.com/2014/01/play-video-ts-file-on-pc-or-imac.htmlog.com/images/icons/icon1.gif
