Tips for Converting AVCHD MTS files to FCE editable format
Postod kelly456 » 20.12.2014 4:53
Summary: If you want to edit AVCHD MTS footage on Final Cut Express and FCE does not take the AVCHD files from your camcorder, the best way is converting all MTS files to FCE editable formats - AIC MOV, ProRes MOV. Pavtube MTS to FCE Converter is the easiest and fastest tool for users who cann't import MTS to FCE. The following are the details.
Final Cut Express doesn't actually edit AVCHD MTS files, it Log and transfer MTS to Apple Intermediate Codec(AIC), which is a much more editing friendly HD supporting codec.Final Cut will only handle AVCHD files when it finds them in their original file structure (either by connecting the camcorder or using a memory card reader), not isolated .mts files. The biggest problem will be storage. For doing that type of work AIC takes a lot more space then AVCHD. figure a multiple of 3-7x the file storage size for a single video file, then multiply that by 3 or 4 to account for working space. So, for example, let's say you have videos to import, the videos total about 6 gig on your camcorder, they will take 18 – 42 gigs of hard drive space just to import the footage. Figuring 3 to 4x that for editing space, you're gonna need between 54 and 168 gig to edit the video.
Give Compressor up. I recommed convert AVCHD MTS to AIC or Apple's ProRes 422 codec with Pavtube MTS/M2TS Converter for Mac. The app save me 2 hours and even more.
Note: You can also choose other MTS to AIC MOV converter for Mac softwares. There are list of five MTS/M2TS Converter for Mac review, you can take a look, choose the most suitable for you.
How to transcode MTS to Apple Intermediate Codec(AIC) for Final Cut Express faster?
Step one. Free Download and install the great MTS to AIC Converter for Mac. Click 'Add' button, browse to the AVCHD MTS files and load them to the MTS to AIC converter. You can check the files and take thumbnails in Preview window.
Step two. Select the items to be converted, and click on 'Format' bar to specify output format. FCE compatible formats such as Apple Intermediate Codec(AIC), MP4, MOV, MPG, DV, AVI can be found in the profile list. For instance, you could follow Final Cut->Apple Intermediate Codec(AIC)(*.mov).
Step three. Click the 'Settings' button and set proper video/ audio parameters. My advice is to set the video size, bitrate and fame rate to be exactly as the footages so that you will suffer least quality degradation. For example, when the video is shot at 1920*1080, 5mbps, 30fps, you could set Size-1920*1080, Bitrate-original, Frame rate-30. If you would like to use default settings, simply skip this step.
Step four. Click the 'Browse' button next to the Export to field and select a location on your HDD for the output video file.
Step five. Click the 'Convert' button to start converting AVCHD MTS files to AIC for FCE on Mac (Mac OS X 10.10 Yosemite and Mavericks 10.9 included).
After conversion you can click the 'Open' button to locate converted video files, and open up Final Cut Express, follow File > Import > Files… to browse and load the MTS files you need. Now you can edit the MTS footages with FCE for playback on QuickTime connected to your HDTV, Mac, as well as upload to Youtube.
See also:
Professional Movie Producer's Choice: To Transcode AVCHD into ProRes
Import AVCHD footage to Premiere Pro
iMovie Does Not Accept .m4v Files on Mac Mavericks?
Easiest Way to Edit AVCHD Wedding Files in Pinnacle Studio 16
Let's Import Sony NX30 AVCHD MTS Videos into FCP
Importing Panasonic HX-WA03 1080P Videos to FCP 7/X
Playing MKV on Mac with QuickTime or iTunes?
Transcode Sony PMW-200 XDCAM MXF to ProRes HQ 422 for FCP.
No Audio when Editing MTS files in Adobe Premiere Pro CC?
Good news! Pavtube Bundles Deals are coming! It's a time for taking a break from work and relaxing. And now you can enjoy your colorful time with good featured products at "Pavtube Bundles Deals". Go ahead and click the link to get your coupon. Save up to $44.1! Never miss!!!
MTS/M2TS Converter for Mac($29) + MXF Converter for Mac($29) = Only $29.9
MTS/M2TS Converter for Mac($29) + MKV Converter for Mac($29) = Only $29.9
MTS/M2TS Converter for Mac($29) + FLV/F4V Converter for Mac($29) = Only $29.9
iMixMXF($45) + HD Video Converter for Mac($35) = Only $54.9
The original from: http://camcorder-video-tips.over-blog.c ... 52951.html
