5 Tips You Should Keep in Mind While Selecting Reliable DVD
Postod JeanLiu » 19.12.2014 11:02
5 Tips You Should Keep in Mind While Selecting Reliable DVD Ripper
Tags:top dvd ripper,best dvd converter,select dvd ripper,converting dvds,play dvd on portable devices
With so many DVD Rippers available on the market, it can be tough to know exactly which one to choose. Here are 5 Tips You Should Keep in Mind While Selecting Reliable DVD Ripper and select the best one for DVD entertainment.
Portable devices bring entertainment to our life, like, games, music, video, TV shows, etc. Due to their high audio video quality and big memory, it will be a wonderful experience to watch movies and videos on the move. If you have a collection of DVDs, you can also watch beloved DVD movie on these mobile devices like iPhone, iPad, iPod, Apple TV, Android, PSP, PS3, Xbox, etc.
However, different multimedia devices support different formats, then you need a professional DVD Ripper to convert DVD movie to video formats which can fit for you portable devices, and your ripping process will become very easy if you have the correct software. With so many converting tools in the market which may make you lost and drop you into the dilemma because you don’t know which one you should choose.
Followed are 5 tips for you to help you find the most suitable converter.
1. Select easy-to-use converter with intuitive interface and all the formats it supports should be clearly written in an understandable manner.
2. Choose the converter provided free trial since the easiest software is of no use if it doesn’t seem easy particularly to you.
3. Make sure the converter is compatible with popular formats so that you can convert DVD to play on portable devices like iPhone, iPod, iPad, Samsung, HTC, Nokia, etc.
4. Purchase converter equipped with free lifetime technical support.
5. Make sure the converter can ensure high output audio & video quality.
Here I will recommend Pavtube DVDAid - a powerful DVD Ripping & coping tool which is a reliable DVD ripping software and can fully meet these standards. Surprisingly we found it's on 40% off at Pavtube New Site Special.
Overall, Pavtube DVDAid is designed as a professional DVD converting program which works with 1:1 backup solution and convert DVD to Apple/Android/Windows Devices for watching. Well I haven't got the chance to try every profile, but it's really the top DVD backup tool I've met ever; I mean it's ease of use, not fuss and simple to follow.
Don't you like to have a try?
They provide free trial (no time limitation) before purchase; and you can reach the Mac version here (Also 40% off now).
Rolls off DVD disc protection and rip DVD to fit for your portable devices
Step 1. Run Best DVD Ripper and import disc.
Click this icon to load disc from ROM, IFO/ISO or folder. I also noticed if you have a ISO file to import, it will recognize the ISO file automatically with no need to run virtual driver and mount ISO files firstly. Good design.
Step 2. Choose format.
Click "Format" drop-down list and choose proper format for different using.
For people who want to watch DVD on Apple/Android/Windows devices, you can choose "Common Video > H.264 Video (*.mp4)”, or select corresponding video from “iPad” or “Android” or other option, to get a suitable video compatible with your device.
Tip: If you simply want to back up DVD to external hard drive, here are two solutions:
1. Click the "computer" icon on the top to output 1:1 DVD file exactly the same as original.
2. Select "Copy>Directly Copy" in format list to output an intact m2ts file of the main title.
Step 3. Change video specs. (Optional)
If you are not satisfied with default specs, then click "Settings" to enter Profiles Settings windows. You can customize video frame rate, bitrate, size and other settings freely.
(It does not work for directly copy)
Step 4. Start conversion.
Click the big red "Convert" to start backing up or converting your DVDs. Usually backup will be quicker because it does not need to do trancoding.
After the conversion, click "Open output folder" to quick locate converted files. Now start to enjoy your DVD movies on your portable devices with this reliable DVD Ripper.
Money Saving Boundles:
See also:
How to Easily Compress DVD Files with high resolution
Rip and Stream Blu-ray/DVD discs for playing on HDTV
2014 Top 5 DVD Movie Converter for Portable devices, HDTV and HD Media Players
Edit G2M WMV videos in MovieMaker & FCP for Upload Vimeo
QuickTip: Convert MKV, TiVo, M2TS, VOB to QuickTime MOV on Mac
Source:http://techmovieshare.blogspot.com/2014/05/choosing-the-best-dvd-ripper.html
