Can't Import XAVC 50Mbps-MXF from PXW-X70 into FCP X
Postod Anncarrie » 03.12.2014 7:43
Meet troubles when opening Sony PXW-X70 XAVC (MXF) files in Final Cut Pro X for a nice editing? Maybe here you can find some effective solutions.
Whatever for Mac users or Windows users, some popular editing software you may take as good assistants if you are a professional video editor. As Windows users have Sony Vegas, Mac users look the Final Cut Pro as their favorite. With hundreds of features worthy of listing, ***some sync problems or unwanted gaps may appear when editing.**** For example, MXF files to FCP X with no video image?
'Just got the Sony PXW-X70 and I can't seem to open the .mxf or even successfully transcode the video files into something that can be read on the mac. (Running 10.9.5). I downloaded some Video Converters and neither of them works. They just are able to import the audio but not the video portion. Very frustrated here, any advice? Thanks!'
How to open Sony PXW-X70 XAVC 50Mbps (MXF) in FCP X in a nice way? Due to the special container format, common video converters cannot handle it well. Here may I introduce you a professional XAVC (MXF) assistant for you?***** Pavtube XAVC to FCP X Converter for Mac, (Windows version) *****which has the strong ability of working MXF videos, and transcoding XAVC 50Mbps (MXF) from Sony PXW-X70 to Apple ProRes 422 as output format.
See Also: Three Medias Used in FCP X: Native vs. Optimize vs. Proxy
Let me show you how this XAVC MXF to FCP X converter works: From the official website, you can download and install the program nicely. Two items there we can choose to load our original videos in, 'Add video' to load your MXF with clips,while 'Add form folder' for a complete file folder. Next, on the output list, 'Final Cut Pro'>>'Apple Prors Codec 422(*.mov)' is waiting for your selection. Totally five types of Apple ProRes you can selects here.
To own the output result with perfect effect, I suggest you to get into the 'Settings' interface to adjust your videos before starting your conversion, okay? Select the video codec you want, set the 'video size, bitrates, frame rate, or even the audio channel with your own style.
The work will be done if you click the "Convert" button to start after you make the preparation well.
For a further importing and editing the converted XAVC footage in Final Cut Pro X with your camcorder footage? Here we also offered some necessary steps for you:
How to Connect Your Camcorder To Final Cut Pro X
How to import videos and photos to FCP X?
Surprise! Want a big discount on 2014 Thanksgiving Day? *****On the Pavtubepromotion page, you can get more surprises! Only expires on Dec.10th*****, so you must not miss the chance, right?
Forher guides about different editing tools, you can check the paper listed below.
Source: http://mediaconverting.blogspot.com/2014/11/open-pxw-x70-mxf-in-fcp-x.html
Anncarrie
Postova:  92
