Split a double-layer Blu-ray into two parts for burning
Postod JeanLiu » 14.11.2014 11:20
How to split a double-layer Blu-ray into two parts for burning into two blank Blu-rays? This article will tell you how. Just follow it.
When I have a 45gig movie in a double-layer Blu-ray (Like Gone With The Wind), I would like to break it in half and burn on two BD-R's. Any suggestions on software or process. Have rippers, but they don't seem to go from Bluray to Bluray.
As far as I know, one tool for splitting blu ray movies is tsMuxeR, but how to use tsmuxer to get the exact time is the issue I'm concerned. I have used the split function but it only lets you use minutes, seconds, or milliseconds, not both for instance 45m 8s, I would have to use 2708 seconds to get it exactly right.
And here is an effective way for you: Split a large Blu-ray movie to several single video files in small sizes at first, and then burn them into single-layer Blu-Ray (BD25).
Part I: How to split a double-layer Blu-ray?
Here Pavtube BDMagic provide you a easy way to split Blu-ray when you do the video conversion. No matter whether you need to edit or re-encode the video file, you can do split video easily during formats conversion process. Read the step by step guide below to learn how to split video.
Step 1: Free download Pavtube BDMagic, install and run the program.
Step 2: Load Blu-ray.
You can click "Load file(s)" to input your inserted Blu-ray from your BD drive.
Step 3: Split Blu-ray into clips.
Click "Split selected task" to do split video settings.
When the Video Split window pops up, tick off Enable > Split file size (MB), and either enter the desired maximum size of each file chunk or choose an appropriate size from the available drop down option. 25 GB is equal to 25,600 MB, so in my case I entered 25,600 MB for each chunk of file.
Step 5: Convert and split Blu-ray.
Once you have finished these settings, you can click "OK" and back to the main interface to click Convert. Pavtube BDMagic will convert the source file to your desired format and split it into several files with desired file size.
Tip:
Besides splitting by file size, you can also split the selected video file by specifying the clip quantity and duration time for each chunk.
Part II: Burn converted video into single-layer Blu-Ray
As far as I know, ImgBurn is the best free DVD burning software. Actually, it also can create ISO image file from DVD or DVD folders, but it's true that ImgBurn is also a free Blu-ray Disc burner (compatible with BD R/RE). To burn a Blu-ray Disc with free Blu-ray burner ImgBurn, see the detailed steps.
Easy steps to burn Blu-ray Disc with ImgBurn
Note: To play the Blu-ray folders on PC, you could use the free Blu-ray player to play the movies on hard drive.
1. Load ImgBurn!
2. Click the 'Write files/folders to disc' button.
Note: This is basically the same as switching the 'Mode' to 'Build' and setting 'Output' to 'Device'.
You should now see a screen like this:
3. Insert a blank (or erasable) Blu-ray disc in your burner.
Note: The message in the status bar should now say something along the lines of 'Ready'.
4. Add the files/folders you want to burn to the 'Source' box.
For a Blu-ray video disc that'll be the BDAV / BDMV folder and the CERTIFICATE folder.
To add those folders you can:
A. Type their names in manually (one at a time!) and click the '+' button.
B. Click the 'Browse for a folder...' button, navigate to and select the appropriate folder.
C. Drag and drop the folders from an Explorer window into the 'Source' box.
D. Drag and drop the folders from an Explorer window onto the 'Drop Zone' - assuming you've activated it via the 'View' menu of course!
When that's done your source box should look something like this...
4. Now we configure the program for burning a compliant Blu-ray disc.
Switch to the 'Options' tab and configure the settings as shown below.
5. Back on the 'Information' tab, you can now click the 'Calculate' button if you want to see the size of your compilation.
When it's finished calculating the screen should look something like this:
6. Now we're ready to burn so click big 'Build' button!
When/If you're prompted for a volume label, you can either use the one suggested by the program or type in a new one. Click the 'OK' button when you're happy with it.
When/If the 'Image Information' box pops up, assuming everything looks alright, click the 'OK' button.
The program will then burn your files to the disc.
The End!
Read more:
Souce: http://video-tips.jimdo.com/2014/08/19/split-blu-ray-for-burning/
Re: Split a double-layer Blu-ray into two parts for burning
Postod JeanLiu » 16.11.2014 12:36
50% OFF Pavtube Video Converter Ultimate! Only $32.5! Last 3 days!
Hello everyone, here's the crazy discount ever - Last 3 days to get your 50% off Pavtube Video Converter Ultimate on Pavtube Facebook - A best and cheapest (3D)Blu-ray, Blu-ray MV, DVD, CD, ISO/IFO and SD/HD Video Converter tool.!
https://www.facebook.com/pavtubefans/app_198826126804423
How do the Pavtube Video Converter Ultimate tool work for you?
Pavtube Video Converter Ultimate is the best (3D) Blu-ray/DVD/Video solution for Windows users to backup BD/DVD, compress disc and transcode video clip to almost all popular video and audio formats. This Video Converter Ultimate can be regarded as Blu-ray/DVD backup workaround to copy the entire disc content from hard disc to computer drive and save a complete Blu-ray M2TS/DVD VOB movie without extras; it can also be used as a Blu-ray/DVD ripping tool to compress your Blu-ray and DVD collection to MP4, MKV, M4V, AVI and play on Apple/Android/Windows tablet/phones, iTunes, QuickTime, VLC, game consoles, HD media players, 3D TV, projector and more.
What's more, this all-inclusive program is a HD video converter as well, and you can feely convert TiVo, MXF, MOV, and other HD videos to almost all formats. Besides, it is a professional video editing software to assist users with trimming, cropping, splitting, merging, attaching subtitles...to create your own videos.
1. Almost all video/audio formats supported. A large number of file formats are accepted by this package, Blu-ray, DVD, MP4, MOV, MKV, MXF, TiVo, JPEG, BMP, etc. More than 200 formats are listed under Format pane for output.
2. Output playable videos/movies for all popular devices. Easily create an optimized file from this toolbox for your favorite devices: iPad Air (2), [b]iPhone 6 plus
, iPad Mini 3/2/1, Samsung Galaxy Tab S, Galaxy Tab Pro, Galaxy Note 4, Galaxy Note Pro, Galaxy S5/S4, Google Nexus 6/9, Surface Pro 3, Kindle Fire tablets, Sony Xperia Z3/Z2, Xbox One, PS4, PSP, PS3, and more smartphones, tablets, Laptop, media players and game consoles.
3. HD videos like MTS, MXF are incompatible files with editing programs Avid Media Composer, DaVinci Resolve, Adobe Premiere Pro (CC, CS6, CS5, CS4, CS3), After Effects CC, Sony Vegas Pro 13/12, Sony Movie Studio 13 Platinum, Windows Movie Maker, Pinnacle Studio 17/16/15, Avid Xpress Pro, MAGIX Movie Edit Pro HD, etc. This all-round video conversion tool converts camcorder videos (AVCHD, MXF, MTS, M2TS, XAVC, AVI, MP4, MOV, MOD, TOD), TV shows (TiVo, TS), Flash videos (FLV, F4V), common videos and audios (MOV, MP4, AVI, WMV, MKV, RM, RMVB, AAC, AC3, MP3, WMA, WAV, etc.) to editable formats for Avid, Pr, AE…with ease. Or you can upload the converted videos to Youtube, Vimeo, etc. video website.
4. Backup BD/DVD with high quality. Copy the entire BD/DVD disc content to computer hard drive with original structure and all audio/subtitle tracks and chapter markers preserved
5. Copy Blu-ray/DVD without extras.
6. Create 3D movies out of 2D sources. Assist users to convert both 2D/3D Blu-ray/DVD to 3D MKV, 3D MP4, 3D MOV and 3D AVI.
7. 6X Faster Conversion Speed. Fully optimized for the NVIDIA CUDA technology and AMD Accelerated Parallel Processing (APP), to largely accelerate video encoding speed when transcoding/converting/ripping video files from one format to another by using H.264 codec.
Give it a try, and you will find more thoughtful and useful features, only $32.5 for last 3 days:
P.S. If you want to learn more Money-saving Tips, pls view our special offer page, saving up to $35.1!
Link: http://www.multipelife.com/special-offer
To receive customer support, you are free to contact [email protected] or [email protected]
