Copy/Rip DVD to Surface Pro 3 without DVD drive
Postod JeanLiu » 13.11.2014 11:59
Tags: dvd to surface pro 3, play dvd movies on surface pro 3, surface pro 3 video format, transfer dvd movie to surface pro 3,
Do you want to have an amazing weekend? After you did the weekly exercies, wash a clean bath and you can lying on the couch and started enjoying wonderful DVD movies on the surface pro 3. Can is it be possible? This article will tell you the quickest and easiest way to enable DVDs playback on Surface Pro 3. If you wanna do this, you need transfer DVD to MP4 format at first.
Why You Need to Rip DVD to Microsoft Surface Pro 3?
1. DVD Video is in VOB format and Surface Pro 3 cannot play it
2. Many DVDs are protected. That's why you need to pick up a DVD ripping tool to assist you to remove DVD protections and put your precious DVD movies to Surface Pro 3. To bring more convenience to all Surface Pro 3 users, I will make a brief share with all of you.
What’s the further information for Surface Pro 3 users?
If you are a movie fan, you may also have lots of Blu-ray discs, MKV files to save more space, AVI on NAS, other video files downloading from Youtube, you can also do transfer from Pavtube software.
How to Play DVD on Microsoft Surface Pro 3 at ease ?
Preparations:
1. DVD disc ready for backup
2. DVD ripper for Surface Pro 3(for this case, I recommend you Top DVD to Surface Pro 3 DVD Converter - Pavtube DVDAid).
Step 1. Run this DVD Converter ; load disc.
Click the top left icon, you can choose to import DVD from ROM, DVD folder or DVD ISO/IFO. It will check the main title by default; moreover, ISO files could also be recognized automatically so that you no longer need to run virtual drive to mount it.
Step 2. Choose format.
Click "Format" drop-down list and choose "Windows > Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)" as the compatible MP4 preset for playing on Surface Pro 3 with best video quality.
Tips: You can Adjust specs or edit video before conversion (Optional).
If you want to customize output video size, bitrate, frame rate and others, just click "Settings" to enter profiles settings window. And you can click the pencil-like icon on the top to crop, trim, edit audio/subtitles/ or add watermarks before conversion.
Step 3. Start Conversion.
You can hit the big red "Convert" to start converting DVD to Surface Pro 3 MP4 with best video settings. After the conversion, click "Open output folder" in the conversion window, or "Open" in main interface to quick locate the converted video.
If you are facing problems when getting the converted movies files, and try to find a way to transfer them to Surface Pro 3.
Source:http://bd-dvd-copying-ripping.blogspot.com/2014/06/transfer-blu-ray-to-surface-pro-3.html
Money Saving Boundles:
