Last Day! 20% OFF best MKV DTS 6.1 to AC3 Converter
Postod JeanLiu » 15.09.2014 11:21
Professional MKV films DTS 6.1 to AC3 converter software
Tags:best mkv video converter, convert mkv dts to ac3, best software for mkv, encode mkv dts to ac3
Summary: Here is a simple tutorial for the conversion of DTS 6.1 audio format to AC3 audio of a MKV films.
Are you still complaining the long and time consuming methods that converting DTS 6.1 to MKV AC3? Here, This guide applies to:
I have one mkv files that has dts-es(Or any other extra dts)6.1 or 7.1 channels and i want to make it into dts-core 5.1 channels.
convert DTS to MP3, WAV, AAC, Flac, etc and MP3, WAV, AAC, Flac, etc to DTS.
When trying to save space during a conversion between MKV and MKV.
Does anyone have a concise method for converting DTS 6.1 streams to AC3? I am trying to convert some MKV films, and the audio is only provided in DTS format for english. To solve this problem, I try several other DTS decoders, among which, Pavtube Video Converter Ultimate is best to convert DTS-HD, DTS and DTS-MA codec to AC3 and AAC encoded video formats and various audio formats.
With this converter, you can easily decode DTS to AC3 with 4 steps. And the program can export file without affecting any audio and video quality of your original MKV files. Besides, if you have many DVD or Blu-ray Discs collection, with the hard-burn and forced subtitle function, the multiple video supported conversion program can rip MKV movies with subtitles. This guide will show you how to convert MKV DTS 6.1 to AC3 5.1 sound step by step. You may download demo version of Pavtube MKV DTS 6.1 to AC3 converter and try it out.
Note: For Mac users, the operation is extraordinarily similar as below steps with iMeida Converter for Mac.
Step 1: Load DTS MKV file
Click "add video" to load MKV file. You can also directly drag and drop DTS 6.1 files this software . If you would prefer to combine multiple MKV files as one file, you can tick the checkbox "Merge into one file".
Step 2: Choose HD MKV as output format
Click "Format" and select an optional format. There are customized formats for different devices and application. Here you can choose "HD Video->>MKV HD Video(*.mkv) for best playing on TV.
Step 3: Set the output audio as AC3.
Click “Settings” to set audio codec as AC3. Here you can also adjust aspect ratio, bit rate, frame rate, sample rate, audio channels, etc.
Step 4: Conversion.
Click "Conversion" icon and the Pavtube Video Converter Ultimate will do convert MKV with DTS 6.1 to MKV AC3 at fast speed. With just a click on "Open output folder", you can locate the export video quickly.
There you have it. Pretty simple. Now you are free to get MKV AC3 out of your sound system. Have fun!
Releated Articles:
Streaming HD movies on Apple TV 3 with Dobly Digital 5.1 sounds
Create AC3 5.1 channel MKV for WD TV from Blu-ray/DVD
Source:http://open-media-community.com/2014/08/28/convert-mkv-dts-6-1-to-ac3/
