Encode Advanced Systems Format to Surface RT for playback
Postod JeanLiu » 25.08.2014 10:06
Tags: Microsoft, convert asf to surface rt, asf to surface rt, best format to surface rt
What is ASF?
Advanced Systems Format is Microsoft's proprietary digital audio/digital video container format, especially meant for streaming media. ASF is part of the Windows Media framework. ASF is the container format for Windows Media Audio and Windows Media Video-based content. The extension wma or wmv is used to specify an ASF file that contains content encoded with the Windows Media Audio and/or Windows Media Video codecs.
Note: From the formats table, you can know Surface RT can play MP4, MOV, M4V, etc formats well, but frustratingly, the other files such as ASF etc are not compatible with Surface RT.
This article will show you how to convert Advanced Systems Format to Surface RT for playback smoothly. The tool you need is Best Surface RT Video Converter.
The tutorial about how to convert ASF to Surface RT supported file format:
1. To begin, free download this Top Surface RT Video Converter, install and run it on your computer.
2.Add videos. You can choose to import videos or the entire folder by clicking the top left two icons.
3.Choose a proper format for Surface RT. Click "Format" drop-down list and choose "Windows-> Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)" as the compatible MP4 preset with best video quality.
4.Customize video specs for Surface RT (Optional). If you are not satisfied with the default output video specs, click the "Settings" beside "Format" bar to enter Profiles Settings interface. Hit to adjust target video size, bitrate, frame rate and other settings here. Usually the higher bitrate you choose; the larger file size and better video quality it will be.
5.Start convert ASF files to Surface RT Conversion. You can hit the big red "Convert" to start converting ASF to MP4 with best video settings for Surface RT. After the conversion, click "Open output folder" in the conversion window, or "Open" in main interface to quick locate the converted video. Finally, you can transfer ASF files to Surface RT for smooth playback without any problem.
As you see, now you can effortlessly watch Advanced Systems Format videos on Microsoft Surface RT tablet and enjoy the show.
If you have no idea about rip Blu-ray/DVD, ISO/IFO, and convert various formats of 720p/1080p HD videos in MKV, AVI, TiVo, VOB, MPG, MTS, etc. to your Microsoft Surface RT, you can also find the Answers on Microsoft Surface RT/Pro Column.
Source:http://surfacevideoconverter.over-blog.com/convert-asf-to-surface-rt
Releated Articles:
Rip and Transfer DVD movies onto Surface RT tablet
Play DRMed Amazon Instant WMV Video on Microsoft Surface RT
Convert Temptation Blu-ray to Surface RT for playing with subtitles
Recommended Video Formats For Surface Family
Get and Watch DVD ISO on Your Surface RT Tablet
Enjoy MKV videos on your Surface RT/Pro tablet effortlessly
