How to encode WLMP files to Surface 2/Surface Pro 2
Postod JeanLiu » 07.08.2014 12:47
Tags: convert wlmp files to surface, best surface 2 wlmp converter, wlmp to surface 2, encode wlmp to surface pro 2
Surface 2 or Surface Pro 2 are both great as media players or game machines to meet our personal entertainment needs. However, the Surface 2 and Surface Pro 2 only supports limited video format as: DivX, XviD, WMV, MP4 (H.264, MPEG-4 video codec )etc. Is it possible to enjoy WLMP video files on your Surface 2/Surface Pro 2? In this guide, we show you the best solution to convert WLMP video files to Surface 2/Surface Pro 2 supported format.
Overview:
WLMP usually refers to the movie/file project generated by Windows Live Movie Maker, which is widely used by home video makers. After editing a movie project, the file will be save as *.wlmp by default. However, as WLMP is not a valid video format, it is impossible for users to directly play it with common media players like VLC, Windows Media Player, iPhone, Surface, Kindle Fire HDX, etc.
To solve the issue, you would like to convert WLMP to MP4. I would say that’s the smartest and the correct choice! But how to convert .WLMP to .MP4? Yes, that is a piece of cake if you own the most professional WLMP to MP4 Surface Converter. With it, you can facilitating the conversion between WLMP and MP4, MOV, AVI, MKV, FLV, WMVand so forth. Now let’s take a have a look at how it works:
Step-by-step guide: How to Convert WLMP to MP4 for Surface 2/Surface Pro 2
Step 1. Load WLMP video files.
Download this best WLMP to MP4 Surface Converter and lauch it, then Click “Add Video” button to add the WLMP file.
Step 2. Choose format.
In this case, you are suggested to select “Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)” as the best MP4 preset for Surface 2/Pro 2.
Step 3. Adjust specs or edit video before conversion (Optional).
Click “Settings” button to configure file quality for Surface 2/Pro 2. After entering “Profile Settings” panel, you are allowed to adjust video and audio parameters such as bit rate, frame rate, sample rate and more.
Step 4. Start conversion.
Now hit the big red “Convert” to start converting WLMP movies to Surface 2/Pro 2 MP4 with best video quality for playback. After the conversion, you can get the converted MP4 files by clicking the “Open” or “Open output folder” icon and transfer the result videos to your Surface 2/Pro 2 via USB cable.
Source:How to encode WLMP files to Surface 2/Surface Pro 2
Releated Articles:
Convert DVDs to Surface 2, Surface Pro 2
Watching Blu-ray movies on Surface 2
How to get Blu-ray ISO image file on surface pro 3
Korisnici koji su trenutno na forumu: Nema registrovanih korisnika i 12 gostiju
