Recalling 2014 FIFA World Cup Video on Apple TV 3
Postod JeanLiu » 22.07.2014 12:39
Replay World Cup Tivo/MXF/FLV Video on Apple TV 3
Summary: How to replay 2014 FIFA World Cup videos on Apple TV 3 is one of the most sought informations by newbies to digital video. In the short article below, I will address this question for you to recalling World Cup MPG movies on Apple TV 3 flawlessly. Check it out.
2014 FIFA World Cup Brazil has come to an end, but its spirit and enthusiasm will never fade away. For those who went and watched World Cup by themselves, or enjoyed through live broadcasting, video recording device is a must to record wonderful football matches and moments.
This article will tell fans how to permanently retain the 2014 World Cup Match video, and then replay them on our any devices, such as Apple TV 3.
But you will find a problem, you cannot directly view World Cup videos (Tivo, MXF, MPG, FLV) on Apple TV 3, the reason is simple: the default and downloaded player on the iOS device cannot find a suitable decoder for the files. So, if you want to replay the World Cup videos in any formats on your Apple TV 3 or any other device without time & place restrictions, you need to get some help from 3rd-party software to convert World Cup videos (Tivo, MXF, MPG, FLV) to H.264 or MPEG-4 encoded MP4 videos for Apple TV 3.
To achieve your goal smoothly, here I will take Pavtube Video Converter Ultimate (Alternative Mac Version for an example to show you how to shows you how to converting World Cup videos (Tivo, MXF, MPG, FLV) to Apple TV 3 supported video formats. The program is easy to use and produces excellent results for the Apple TV 3. Conversion speed seems fine and the converted videos look decent on Apple TV as original. Just download it and follow the steps below to realize the way getting 2014 FIFA World Cup Video files to play on Apple TV 3 smoothly.
Converting World Cup videos (Tivo, MXF, MPG, FLV) for replay on Apple TV 3 smoothly
1. After downloading, install and run the 2014 World Cup Video Converter on your PC, then click "Add Video" button to load your any World Cup Video files. The software supports batch conversion so you can convert several files in one go.
2. Select output format.
Click the Format drop-down list, choose "Apple > Apple TV 3 1080P Dolby Digital Pass-through(*.m4v)" which works well for Apple TV 3. Or you can choose other presets if you don't need full size videos.
3. Start the conversion process.
Tip – Set Qaulity: Back to step 2, you can click "settings" button to adjust the output parameters of the video. Remember the file size is based more on bitrate than resolution which means bitrate higher results in big file size, and lower visible quality loss.
Once the process completes, sync and transfer the result MP4 videos to your Apple TV 3 via iTunes. In this way, you can enjoy 2014 FIFA World Cup videos (Tivo, MXF, MPG, FLV) on Apple TV 3 as you like. Now you need know a complete Apple TV 3 WorkFlow - Setting Up ATV 3 for streaming HD videos.
Read more tips:
Transfer Internet torrents movies to Apple TV 3
Convert TiVo to iPad 3/Apple TV 3 on Mac
Source: http://comfortable-media-device.over-blog.com/converting-world-cup-mpg-files-for-apple-tv
