How to convert movies from Vuze to DVD?
Postod hath80 » 13.07.2014 8:21
How to convert and burn Vuze movies to DVD? Vuze (previously Azureus) is a BitTorrent client used to transfer files via the BitTorrent protocol. By using it, you can download almost any movies you want and after that you can watch the movies on your computer. However, you may face problems if you downloaded many movies. How to save memory on hard disc to downloaded even more Vuze movies? How to watch Vuze downloaded movies on home DVD player? Burning Vuze to DVD solves them all. Read on to figure out how.
What we use is DVD Creator which is able to burn all types of Vuze movies to DVD which can be played on most home DVD player easily. If you are looking for advanced features, this Vuze to DVD burner lets you edit videos, adding DVD menus, and more you can explore. Check out the step-by-step guide below to learn how to burn DVD from Vuze. (If you are running Mac OS, you can always use DVD Creator for Mac to burn Vuze to DVD on Mac, including Snow Leopard, Lion.)
Step-by-step Guide to Burn Vuze to DVD with Vuze to DVD Burner
1 Download and Install DVD Creator
Depending on which operating system you are running, download Vuze Burner and install it on your computer to proceed.
2 Import Vuze Movies
Now you may open this Vuze to DVD converter, find where you saved your Vuze movies and drag-drop them to the program. If you have photos, you can also add them and burn onto DVD with Vuze movies together.
(Note: Depend on the size and quality of Vuze movies, you may add more than one movie to fit a DVD disc. At the bottom, the blue bar will show how full the DVD disc is.)
3 Select and Customize DVD Menu (Optional)
DVD menu is able to make your DVD more professional and unique. There are various built-in DVD menu templates in DVD Creator which you can choose from to personalize your DVD. Alternatively, you may select No menu to go to next step.
4 Convert Vuze to DVD
Done with everything, click on Preview button to make sure everything is going as you wish. If you are ready, click on Burn button to get started Vuze to DVD conversion. (Make sure you have inserted a DVD disc into your computer drive. Check out DVD format knowledge.)
Once done, you can watch the DVD disc on your home DVD player or simply store it for future entertainment. Have fun. (Learn more at Video DVD Converter.)
1. Edit Vuze Videos before Burning (Optional)
For videos, here you can crop, trim, add watermark, plug in subtitles or adjust video effects, according to your specific request.
2. Vuze DVD Burning Error
a. Burning Error/wrong disc
If you have burnt the DVD and plays on your DVD player which keeps saying wrong disc, it’s because you didn’t finalize the DVD. To play on DVD player successfully, you need to burn a Video DVD instead of data disc. (Video DVD means finalizing DVD which is exactly what DVD Creator does.)
b. Can’t Load File
If you used Nero or other programs to burn Vuze DVD, the file can’t be found/located or dragged to your program, most likely it’s because the video format of the Vuze movie is not supported by your DVD burning tool. DVD Creator works with all popular and HD video files.
More:
How to convert movies downloaded from Vuze to DVD?
How to convert and burn VOB files to DVD disc?
How to burn TOD to DVD playable on a DVD player?
How to convert and burn home movies MOD to DVD?
M4V to DVD Mac/Win: How to convert M4V to DVD for TV?
2 Methods to Burn iMovie Projects to DVD Disc
hath80
Postova:  55
