How to Rip Movie DVDs to MOV Format on Mac Computer
Postod Anncarrie » 30.06.2014 8:47
Have some awesome DVDs but don't want to carry all of them together during a family trip? Or you would like to convert your favorite DVD movies to your Mac,in cases like these, you can rip your DVDs to MOV files on Mac with a Mac DVD to MOV ripper.
What is MOV format?
MOV is a file extension used by the QuickTime-wrapped files, which was created by Apple Computer to work with multimedia files often used for saving movies and other video files, using a proprietary compression algorithm developed by Apple Computer, compatible with both Macintosh and Windows platforms. The format specifies a multimedia container file that contains one or more tracks, each of which stores a particular type of data: audio, video, effects, or text (e.g. for subtitles). Each track either contains a digitally-encoded media stream (using a specific format) or a data reference to the media stream located in another file. The advantage of MOV files is the ability to contain abstract data references for the media data. That means that they can be easily edited - no need to rewrite all media data after editing.
But QuickTime movies could not be played directly on DVD player, it should be converted DVD to MOV files first and What's more, the new generation of digital cameras not only takes still photos with amazing clarity, but also records high-quality video in QuickTime format (MOV). So converting DVD to MOV files is not avoidable. Maybe you found some free conversion software, but pavtube customer feedback shows that they are many inadequacies, such some of DVD discs can not to be imported, and they are not taking advantage of multi-MOV, this means that they does not support multi-track output. Now let us learn how to rip Movie DVDs to MOV Format on Mac Computer by Pavtube BDMagic for Mac. If you want to multitrack output, Pavtube ByteCopy for Maccan help you.
Step 1: Download and install the Pavtube BDMagic for Mac
Tip: Pavtube offers free use of thirty days.
Step 2: Load DVD into the program
You need to insert a DVD disk into the DVD drive firstly. Then click "File" to load DVD disk. You can see all loaded DVD files in Source Filename list. The preview screen is provided to watch these videos.
Step 3: Select the format "Common Video > MOV - QuickTime(*.mov)"
Tip: If you are using the Pavtube ByteCopy for Mac, you can choose the "Multi-track Video > Multi-track MOV(*.mov)"
Step 4: DVD to MOV Conversion on Mac completed
After you have set up all the conversion output profile and parameters, you can hit the "Convert" to start converting. After converting finished, open the output directly and just enjoy the movie on Quicktime now.
More articles
Copy DVD Disc for playback on Mac with multi-track MOV format
Convert Blu-ray to multi-track AVI on Windows 8.1/8
How to Put DVD Videos onto YouTube for Sharing
Anncarrie
Postova:  92
