Sync and Play 2014 FIFA World Cup MPG video files on Apple T
Postod Anncarrie » 30.06.2014 8:45
Tags: convert MPG to MP4,World Cup MPG to Apple TV,2014 World Cup Video Converter,play MPG files on Apple TV,put MPG on Apple TV
Summary: How to Play 2014 FIFA World Cup MPG video files on Apple TV is one of the most sought informations by newbies to digital video. In the short article below, i will address this question for you to watch World Cup MPG movies on Apple TV flawlessly. Check it out.
Just few days ago, 2014 FIFA World Cup has been held. This is a huge and exciting footaball fans for most fans who cannot wait for it any more. This month is a big month for the fans. I think the more exciting news for most fans is that they can watch their favourite World Cup videos now on portable devices now. Here we explains below how to convert 2014 World Cup mpg on Apple TV.
The reason you cannot direcly view World Cup MPG videos on Apple TV is simple: the default and downloaded player on the iOS device cannot find a suitable decoder for the file. Assuming that you want enjoy World Cup MPG files on your Apple TV tablet, you’ll need to get some help from 3rd-party software to convert MPG files to H.264 or MPEG-4 encoded MP4 videos for Apple TV.
To achieve your goal smoothly, here I will take Pavtube Video Converter Ultimate (Alternative Mac Version) for an example to show you how to shows you how to converting World Cup MPG to Apple TV supported video formats. The program is easy to use and produces excellent results for the Apple TV. Conversion speed seems fine and the converted videos look decent on Apple TV as original. Just download it and follow the steps below to realize the way getting 2014 FIFA World Cup MPG files to play on Apple TV smoothly.
Converting World Cup MPG files for Apple TV playback smoothly
1. After downloading, install and run the 2014 World Cup Video Converter on your PC, then click “Add Video” button to load your MPG files. The software supports batch conversion so you can convert several files in one go.
2. Select output format.
Click the Format drop-down list, choose "Apple > Apple TV 3 1080P Dolby Digital Pass-through(*.m4v)" which works well for Apple TV. Or you can choose other presets if you don't need full size videos.
3. Start the conversion process.
Tip – Set Qaulity: Back to step 2, you can click “settings” button to adjust the output parameters of the video. Remember the file size is based more on bitrate than resolution which means bitrate higher results in big file size, and lower visible quality loss.
Once the process completes, sync and transfer the result MP4 videos to your Apple TV via iTunes. In this way, you can enjoy 2014 FIFA World Cup MPG files on Apple TV as you like.
Read more:
Transfer Internet torrents movies to Apple TV with with high quality
Convert TiVo to Mac H.264-compliant videos for iPad 3, iPod and Apple TV 3 playing
Apple TV 3 WorkFlow - Setting Up ATV 3 for streaming HD videos with Dobly Digital 5.1 sounds
From: http://comfortable-media-device.over-blog.com/converting-world-cup-mpg-files-for-apple-tv
Anncarrie
Postova:  92
