How to burn Torrent movies to DVD?
Postod hath80 » 19.05.2014 8:42
“How to burn Torrent to DVD to play on TV? I have tried this about 4 times and each time it won’t play in my DVD player or XBOX. I don’t get it. I have DVD-R which is totally supported by my DVD player. Is it because of the movie file format I downloaded from torrent site? Anyway, how can I convert and burn Torrent movies to DVD which can be played on my home DVD player? Thanks!”
DVD Creator serves as one of the best and most reliable torrent to DVD converter which has the capability to burn almost any types torrent videos to DVD successfully. Now you don’t have to convert a movie downloaded as a torrent into a format that can be burnt on a DVD. With DVD Creator, you can burn the torrent file to DVD directly thus saving your time and efforts.
Check out the step-by-step guide below to learn how to easily convert and burn Torrent movies to DVD for playback on TV. (If you are running Mac OS, you can always use DVD Creator for Mac to burn Torrent to DVD on Mac, including Snow Leopard and Lion.)
Step-by-step Guide to Burn Torrent to DVD with Torrent to DVD Burner
1 Download and Install DVD Creator
To burn Torrent to DVD on Mac/Windows, just download Torrent to DVD Creator according to your OS, and install it.
2 Import Torrent Movies
Now run DVD Creator and click on Source button which enables you to find and import your targeted torrent movies to the program. Alternatively, simply drag & drop your files to the tool. You can add multiple movies at a time to fit a DVD disc. Both DVD-5 and DVD-9 are supported.
3 Select and Customize DVD Menu (Optional)
If you want to make a real cool DVD disc, you may use the feature of DVD menu. You can choose from the various delicate built-in DVD menus or customize your own one. Alternatively, you may select No menu to go to next step.
4 Convert Torrent to DVD
Click on Preview button and you will see how your DVD disc will look like. Ready? Click on Burn button and get started the torrent to DVD burning process. (Make sure you have inserted a DVD disc into your computer drive.)
Once the task is done, you can play the DVD disc on your home DVD player sharing with your families and friends. Have fun.
More:
How to burn Torrent movies to DVD to play on TV?
How to burn VLC media files to DVD format?
How to convert/transfer/record VHS to DVD effectively?
How to burn DivX to DVD disc and watch on DVD player?
How to burn BBC iPlayer programmes to DVD?
How to convert and burn M2TS to DVD for home DVD player?
hath80
Postova:  55
