How to easily convert MOV videos to DVD?
Postod hath80 » 19.05.2014 8:38
The QuickTime (.MOV) file format is a file extension used by the QuickTime-wrapped files. The format was created by Apple Computer to work with multimedia files. Though MOV files are quite often found in the web, to play them on Windows computer one has to install an extra component or convert to other format. MOV is a container format and can contain video, animation, graphics, 3D and virtual reality (VR) content or text (for subtitles, for example).
Want to learn the easiest way to convert MOV to DVD or convert QuickTime to DVD? Check out our tutorial below. So while away, you used your digital camera to make home/holiday videos which come as .MOV files. Or you may have downloaded some video clips to your computer and they are .MOV files. Is there a proper and efficient way to convert and burn MOV to DVD so that you can play your videos on a home DVD player attached to a television? Well, with DVD Creator which serves as the best MOV to DVD converter, you can convert QuickTime/MOV videos to DVD in a simple way without complicated steps. Read on and learn the simplest way to convert QuickTime/MOV to DVD.
(Tips: If you want to convert & burn MOV to DVD on Mac OS X, you may check out our professional DVD Creator for Mac.)
Step 1 Load QuickTime/MOV videos
Click on Load Video button in the upper left interface to locate QuickTime/MOV files, and add them to this QuickTime/MOV to DVD converter. Drag and drop loaded QuickTime/MOV videos to the storyboard below to proceed with QuickTime/MOV to DVD conversion.
Step 2 Edit QuickTime/MOV movies (Optional)
The plug-in video editor lets you edit videos quickly and easily. Select a video file in storyboard and click on Edit selected video file button to crop, trim, add watermark, plug in subtitles or adjust video effects, according to your specific request within minutes.
Step 3 Burn QuickTime/MOV videos to DVD
Once you’ve added videos to the program, now you can convert and burn QuickTime/MOV videos to DVD directly. Of course, you may personalize your DVDs by adding transition effects, customize DVD menu templates, and edit downloaded movies, etc.
Burn QuickTime/MOV to DVD disc: Click “Burn”, select “DVD” option in the “Burn to” field, select your TV Standard and output Aspect Ratio, and click “Start” to burn your project.
Burn QuickTime/MOV to ISO or DVD Folder: Click “Burn”, select the “DVD Folder” or “ISO file” option, specify a folder to save generated DVD files, then click “Start” to start converting QuickTime/MOV to ISO or DVD folder.
So, you just have finished burning QuickTime/MOV to DVD, now you can play your MOV files on home DVD player in your living room through TV. Also, now you may share your favorite movies with your friends. Enjoy. Learn more at DVD Creator Converter.
More:
How to easily convert QuickTime (.MOV) videos to DVD?
How to burn DivX to DVD for playback on DVD players?
How to convert and burn MOD movies to DVD format?
How to convert and burn TOD movies to DVD disc?
How to convert and burn MSWMM file to DVD format?
How to convert and burn digital videos (.DV) to DVD disc?
hath80
Postova:  55
