Enable Sony Xperia Z2 Tablet to Play DVD (ISO) Image Files
Postod JeanLiu » 15.05.2014 12:37
Sony Xperia Z2 Tablet is a powerful, well-balanced slate that needed a slight bump in screen quality to truly compete with the best. One of the highlights of the Xperia Z2 is its screen. It’s 10.1 inches across and 1920 x 1200 pixels in resolution. It is perfect for playing games, listening to music, and watching a TV show on Xperia Z2. However, if you want to get your personal movies off of DVD discs with ISO files and onto the Sony Xperia Z2 Tablet for playback, you may have to do some work in advance. I mean you’ll need to rip and convert DVD to Sony Xperia Z2 Tablet compatible video formats first since there is no BD drive on gadget. Learn the details.
If you have large quantity of ISO files transferred to Xperia Z2 Tablet, the best way is to convert the DVD ISO files to a playable format (e.g. MP4) by Xperia Z2 Table on your Windows PC. You can just download the Pavtube Xperia DVDAID, which is an easy-to-use yet video converting tool which can help you encode/re-encode more than ISO files to Xperia Z2 tablet compatible videos with original quality in perfect ISO files sync on Windows 8/XP/7/Vista. In addition, if your movie isn’t already in one of the supported formats or it’s still on a DVD, you can also get this all-in-one DVDAID to help you.
Convert DVD ISO files to Play on Sony Xperia Z2 tablet smoothly
The below guide uses DVDAID Windows screenshots. The way to encode ISO files to your Xperia Z2 Tablet on Mac is almost the same. Just make sure you get the right version.
Step 1: Download, install and launch it, And then click “Load from disc” or “Load from folder” to import your source materials in. Batch conversion is supported so that you can add multiple files.
Type your new text here.
Step 2: Choose the output video format and output folder.
Click “Format” bar and move mouse to “Sony” column, you can easily find the profile of “Sony Xperia Tablet Series Video(*.mp4)”. The output videos could fit on your device perfectly. And choose the destination folder to save the converted videos.
If you like, you can click “Settings” to change the video encoder, resolution, frame rate, etc. as you wish.
Step 3: After above settings, you can start the ISO to MP4 Conversion for Xperia Z2 tablet.
Once the process completes, download and transfer the converted MP4 videos to your Xperia Z2 tablet. Then you are free to enjoy and play ISO files on your Sony Xperia Z2 tablet as you like.
See also:
Best solutions: Convert/Rip DVDs for Sony Xperia Z2/Z1 smartphones
How can I make Sony Xperia Z1 play DVD movies that I own?Blu-ray to Xperia
Z1 Conversion - Rip Blu-ray movies for Xperia Z1 Transferring
Blu-ray/DVD/MKV/VOB/AVI/MPG/FLV to Sony Xperia Z1
Rip DVD movies on Sony Xperia Z2 in multi-track MP4 format
Source:Enable Sony Xperia Z2 Tablet to Play DVD (ISO) Image Files
