Playing Blu-ray movies on Microsoft Surface Pro 2
Postod JeanLiu » 13.05.2014 15:02
Tricks for playing "The Wolf of Wall Street" Blu-ray movies on Microsoft Surface Pro 2
Summary: Want to put hottest "The Wolf of Wall Street" Blu-ray movie onto Surface Pro 2 for watching on the go, but don't know what to do? Get the solution below that teaches you how to convert BD movies to Surface Pro 2 for playback smoothly.
For windows followers, this will be a big news. Now, you can throw away heavy Notebook, take surface with you on your road. With Surface, you may do the same work which notebook can do, share, work or enjoy HD movies. Surface Pro 2 Windows 8.1 Pro supports video playback up to 1920×1080 pixels now. Enjoying movies on such high resolution screen will be a pleasure. Want to enjoy your loved blu-ray movies on Surface Pro 2? No problem, with this great Blu-ray ripper, you can easily enjoy them on your Surface Pro 2.
The software program is Pavtube Blu-ray Ripper, a powerful and simple tool including Blu-ray Ripper, DVD Ripper and ISO/IFO File Converter, which can rip latest 2D/3D Blu-ray to Surface Pro 2 friendly playback format in few steps, here is our customer’s experience.
Read More:First of all, you need download and install a free trial version of the best Blu-ray Ripper for Surface Pro 2 on your computer [url=http://download.pavtube.com/blu-ray-ripper/blu-rayripper_setup.exe]
for windows
. It is a 100% clear software and allows you to access all the functions.
1.If you’re a Mac user, please turn to the equivalent Mac version – Surface Pro 2 Blu-ray Ripper for Mac, which can transfer Blu-ray and DVD movies to Surface Pro 2 tablet on Mac OS X (Mac OS X 10.9 Mavericks and Mountain Lion included).
2.If you want to keep multiple audio tracks (language) and subtitles, do not miss thisBlu-ray to Surface Pro 2 Ripper Pro!
Tutorials: How to transfer "The Wolf of Wall Street" Blu-ray movies to Surface Pro 2?
Step 1. Run Blu-ray to Surface Pro 2 Converter; load Blu-ray.
Download and run Pavtube Surface Pro 2 Blu-ray Ripper or Blu-ray Ripper for Mac, load your Blu-ray movies into it.
Pavtube Blu-ray Ripper will detect and list the main title (the full length of this movie) and check it by default.
Step 2. Choose format.
Highlight the movie title you want to rip, and then you can click the dropdown menu below “Subtitles” and “Audio” respectively, you will see many presets for difference devices and programs.
In this case, you are suggested to select “Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)” as the best MP4 preset for Surface Pro 2.
Step 3. Adjust specs or edit video before conversion (Optional).
Click “Settings” button to configure file quality for Surface Pro 2. After entering “Profile Settings” panel, you are allowed to adjust video and audio parameters such as bit rate, frame rate, sample rate and more.
The recommended video settings for Surface Pro 2:
Video Codec: h264
Size (pix): 1920×1080
Bitrate (kbps): 1500~2500
Frame Rate (fps): original
If you prefer a much better video quality and don’t mind the output file size, you can rise the video bit rate higher than 1500. Generally speaking, the higher video bit rate will result in the larger output file size, and vice versa.
Step 4. Start conversion.
Now hit the big red “Convert” to start converting Blu-ray movies to Surface Pro 2 MP4 with best video quality for playback.
After the conversion, you can get the converted Blu-ray rips in .mp4 format by clicking the “Open” or “Open output folder” icon and transfer the result videos to your Surface Pro 2 via USB cable.
Tip:Steps to transfer files to Microsoft Surface via USB wire.
1.Copy files onto a USB flash drive or memory card on your other computer.
2. Insert the USB flash drive or memory card into Surface Pro 2.
3.Tap or click the notification that appears in the upper-right corner of the screen.
4.Tap or click Open folder to view files.
5.Select the files or folders you want to add to Surface, tap or click Home, and then tap or click Copy to.
6.Select a location. For example, choose Documents if the flash drive or memory card contains documents.
Now, you are able to watch “The Wolf of Wall Street” on Microsoft Surface Pro 2 anytime and anywhere.
Related Articles:
How to convert MKV videos to Surface 2 on Windows/Mac?
Ripping DVD movies to watch on Surface 2/Pro 2
Put DVD ISO/IFO movies on surface 2/pro 2 without DVD drive
Re: Playing Blu-ray movies on Microsoft Surface Pro 2
Postod JeanLiu » 16.11.2014 7:09
Copy/Rip DVD to Surface Pro 3 without DVD drive
Tags: dvd to surface pro 3, play dvd movies on surface pro 3, surface pro 3 video format, transfer dvd movie to surface pro 3,
Do you want to have an amazing weekend? After you did the weekly exercies, wash a clean bath and you can lying on the couch and started enjoying wonderful DVD movies on the surface pro 3. Can is it be possible? This article will tell you the quickest and easiest way to enable DVDs playback on Surface Pro 3. If you wanna do this, you need transfer DVD to MP4 format at first.
Why You Need to Rip DVD to Microsoft Surface Pro 3?
1. DVD Video is in VOB format and Surface Pro 3 cannot play it
2. Many DVDs are protected. That's why you need to pick up a DVD ripping tool to assist you to remove DVD protections and put your precious DVD movies to Surface Pro 3. To bring more convenience to all Surface Pro 3 users, I will make a brief share with all of you.
What’s the further information for Surface Pro 3 users?
If you are a movie fan, you may also have lots of Blu-ray discs, MKV files to save more space, AVI on NAS, other video files downloading from Youtube, you can also do transfer from Pavtube software.
How to Play DVD on Microsoft Surface Pro 3 at ease ?
Preparations:
1. DVD disc ready for backup
2. DVD ripper for Surface Pro 3(for this case, I recommend you Top DVD to Surface Pro 3 DVD Converter - Pavtube DVDAid).
Step 1. Run this DVD Converter ; load disc.
Click the top left icon, you can choose to import DVD from ROM, DVD folder or DVD ISO/IFO. It will check the main title by default; moreover, ISO files could also be recognized automatically so that you no longer need to run virtual drive to mount it.
Click "Format" drop-down list and choose "Windows > Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)" as the compatible MP4 preset for playing on Surface Pro 3 with best video quality.
Tips: You can Adjust specs or edit video before conversion (Optional).
If you want to customize output video size, bitrate, frame rate and others, just click "Settings" to enter profiles settings window. And you can click the pencil-like icon on the top to crop, trim, edit audio/subtitles/ or add watermarks before conversion.
Step 3. Start Conversion.
You can hit the big red "Convert" to start converting DVD to Surface Pro 3 MP4 with best video settings. After the conversion, click "Open output folder" in the conversion window, or "Open" in main interface to quick locate the converted video.
If you are facing problems when getting the converted movies files, and try to find a way to transfer them to Surface Pro 3.
Source:http://bd-dvd-copying-ripping.blogspot.com/2014/06/transfer-blu-ray-to-surface-pro-3.html
Money Saving Boundles:
