How to convert and burn WMV videos to DVD disc?
Postod hath80 » 08.05.2014 4:56
What is WMV file?
Windows Media Video (WMV) is a compressed video compression format for several proprietary codecs developed by Microsoft. The original video format, known as WMV, was originally designed for Internet streaming applications, as a competitor to RealVideo. The other formats, such as WMV Screen and WMV Image, cater for specialized content.
How to convert and burn WMV videos to DVD?
WMV file has become one of the most popular video which you may find on the Internet. If you have downloaded some videos which are WMV files, you will have no problem playing them on your computer using media players like Windows Media Players. However, if you want to view WMV movies on your home DVD player, then you will have to convert and burn WMV to DVD. DVD Creator is one of the most professional WMV to DVD converter which lets you convert and burn WMV videos to DVD in simple steps. Want to know how? Check out tutorial on how to achieve WMV to DVD conversion.
Step 1 Download DVD Creator
Free Download WMV to DVD converter to you computer and follow instruction to install it.
Step 2 Load WMV videos
Launch WMV to DVD Converter and locate your WMV files. Import WMV files to the tool. Drag and drop loaded WMV videos to the storyboard below to proceed with WMV to DVD conversion.
Step 3 Edit WMV movies (Optional)
If you are interested in editing WMV videos before burning, the plug-in video editor lets you edit videos quickly and easily. Select a video file in storyboard and click on Edit selected video file button to crop, trim, add watermark, plug in subtitles or adjust video effects, according to your specific request within minutes.
Step 4 Burn WMV videos to DVD
Now comes the final step of burning WMV to DVD. Click “Burn”, select “DVD” option in the “Burn to” field, select your TV Standard and output Aspect Ratio, and click “Start” to burn WMV to DVD.
Soon the WMV to DVD burning will be completed. And then you will be able to enjoy them on your home DVD players through TV. Try it out yourself today. Learn more at DVD Creator Converter.
More:
How to convert and burn MPG/MPEG files to DVD?
How to convert and burn H.264 files to DVD?
How to easily convert and burn FLV videos to DVD?
How to burn High Definition MTS/TS/M2TS videos to DVD?
Step by Step Guide: How to burn AVCHD to DVD easily?
hath80
Postova:  55
