Ripping children's movie to iPad 3/iPad Air for use in car
Postod catpav520 » 25.02.2014 8:33
Description: With the n ew iPad 3/iPad Air in hand and do you want to copy children's movies to the iPad from Windows or Mac computer easily? If so, this article will give you a simply way.
Though competition has stiffened with the growing quality of Android tablets, the Apple iPad still reigns supreme. The unbeatable high resolution and fast performance make it an incredibly versatile device. When you get down to it, one of our favorite uses for the tablet is media consumption, but have you been in the same dilemma below?
"My children have many Disney DVD movies and recently I bought the Frozen(2013) for them. I want to put these movies on my iPad for use in car. I understand that it needs MP4 or quicktime format to play movies on the iPad, so could anyone recommend good software to do this?"
As the customer mentioned, if the videos compatible with iPad 3/iPad Air (iPad supports H.264, MPEG-4 videos in .m4v, mp4, and .mov file formats), you could easily add them to your iTunes library and then sync to your iPad. However, due to iPad does not support play DVD or Blu-ray movies directly and the formats are beyond the support format, which confused my people want to view Blu-ray and DVD movies on iPad.
Don't worry. Pavtube Blu-ray Ripper is just designed to solve the problem. It is capable of backing up BD/DVD Disc content to local computer or external devices like Apple, Samsung, and so on. The conversion speed is high and output video quality is great. If you are a Mac user, please go to Pavtube Blu-ray Ripper for Mac. Now get the Blu-ray/DVD converter and no longer be bothered by the format limitation!
Tip:
Pavtube Blu-ray Ripper also support to rip movies to watch on TV over LAN
How to convert children's movies to iPad 3/iPad Air friendly format
Step 1. After downloading, install and run the movie to iPad 3/iPad Air converter. Click "Load Files" icon to load the movies you want to convert. The added movies can be previewed in the preview pane on the right of the main interface.
Step 2. Select "iPad" under Format > iPad 3/4 (New iPad) Full HD Video(*.mp4) as output format. The software has preset the video settings for you. If you want to customize the video parameters, you can click "Settings" to change the video bitrate, frame rate, etc.
Step 3. Click the "Convert" button and the video converter will automatically convert your movies to iPad supported videos. After the conversion, click "Open" to locate the converted iPad friendly videos.
How to transfer the output videos from PC or Mac to iPad 3/iPad Air
1. Connect your iPad to your PC or Mac, and open iTuned if it doesn't fire up automatically. Then select your connected iPad from the list of devices. (You'll find this on top-right or on the sidebar if it's enabled. You can enable the sidebar from the View menu option.)
2. Under the device, you have an option called Movies. Select this. (If you've got videos on the iPad already, they'll be shown as a list). Then drag and drop the video files that you want to copy. You should see a progress bar that will indicate how long it will take to copy the file.
When everything is done, you could view the new released children movies on your iPad 3/iPad Air with your children in your car or everywhere you want.
Read More:
iPad Air Supported Video Format
Five products unveiled at CES 2014 for Apple
How to Backup Blu-ray/DVD/VCD to play on Apple TV 3
Source: http://open-media-community.com/2014/02/20/make-childrens-movies-to-be-played-on-ipad-3-ipad-air/
catpav520
Postova:  44
