Lossless backup Blu-ray to MKV for HiMedia 900B on Mac
Postod Anncarrie » 12.02.2014 9:28
Description: This article introduces how to lossless backup a Blu-ray to MKV format on Mac, so that you can watch the movie on TV via HiMedia 900B.
HiMedia 900B is a conventional specialist Media Player which supports all file formats including 3D movies. With it and a HDMI cable, you can watch most videos on TV without format problems.
HiMedia Supported Formats:
Video: RM/RMVB, H.264, VC1, WMV, MPEG 1/2/4, MP4, DIVX, XVID, BDMV, BD-ISO, MKV, TS, M2TS, MTS, FLV, AVI, DVD-ISO, VOB, MPG, DAT, ASF, TP, TRP, SWF, 3D-SBS, VCD, DVD, AVCHD, MINIBD, RBD, BD-3D, 3D BD-ISO, FRAME PACKED 3D
Audio: FLAC, APE, LC-AAC, HE-AAC, MP3, OGG, WMA, WAV, AC3, DTS, DTS-HD MA, TRUEHD, CD
Although it supported Blu-rays natively, it's still not a good idea to take out Blu-ray discs frequently due to scratch issues. Also, as I own a large collection of Blu-rays, I also built a home NAS with large storage, so the file size is not the case. Like I said, generally I just want a tool that can backup Blu-rays to MKV without quality loss on Mac.
So I started to search online for an ideal tool. However, it's rather disappointing that most ripping software simply compress my Blu-ray to MKV container format with codec like H.264, AVC, ect., the converted video is downsized which doesn't work for me. At last one of my colleague recommended Pavtube ByteCopy for Mac and wow, it works like a charm! It's so easy to use, converts very fast and output lossless videos. Below is my workflow on Mac.
Required Tool: Pavtube ByteCopy for Mac | Review
Operation system:
  • Mac OS X 10.9 Mavericks, 10.8 Mountain Lion, 10.7 Lion, Snow Leopard 10.6.
  • 1G Hz or above Intel processor.
  • 1GB physical RAM (memory) or above.
  • 1024*768 or higher resolution display.
  • Optical Drive: DVD drive (BD drive is required for ripping Blu-ray disc)
1. There's 6 times limitation if you use the trial version to output lossless MKV files;
2. this program also has a Windows version which works for Windows 8.1/Windows 8/Windows 7/Windows Vista/2003/XP find the ByteCopy (windows) here.
How to lossless backup Blu-ray to MKV for HiMedia 900B and keep multi-track?
Step 1. Launch Pavtube ByteCopy and load disc.
Firstly you need an external blu-ray drive; there's no special requirements of the drive model as long as it's supported by your Mac.
Click the top left icon and it will detect the inserted Blu-ray disc, click disc name to load them.
Step 2. Choose lossless format.
Click "Format" list and select "Multi-track Video>Lossless/encoded Multi-track MKV(*.mkv)" as below.
Step 3. Adjust V/A settings.
Click "Settings" to enter Multi-track video profile window; switch to "Video" and find the "Encode" box which is unchecked by default, so if you want a lossless MKV copy, do not touch it.
The switch to "Audio", check wanted audio track; so does the "Subtitles".
Step 4. Start backing up Blu-rays to lossless MKV
Click the big "Convert" to start the conversion. It takes about 40 mins for my Macbook to backup a Blu-ray disc, but the conversion speed also depends on your computer configuration. My suggestion is not to play or edit videos when it's converting. After conversion, click "Open" or "Open output folder" to quick locate converted files.
Ok now the lossless MKV files are prepared; transfer them to your hard drive and connect it to HiMedia, now you can enjoy Blu-ray movies on TV without quality loss!
Money saving bundles:
ByteCopy($42) + Blu-ray Video Converter Ultimate($65) = Only $80, Save $27
ChewTune($29) + ByteCopy($42) = Only $54, Save $17
ChewTune for Mac($29) + ByteCopy for Mac($42) = Only $54, Save $17
ByteCopy($42) + DVD Creator($35) = Only $60, Save $17
ByteCopy($42) + MXF MultiMixer($45) = Only $70, Save $17
Related articles:
Rip BD/DVD to AC Ryan Player on Mac for viewing on TV
Convert DVD to Full HD MKV (5.1) for playback on Himedia 900B
Remultiplex Blu-ray/DVDs without re-encoding Audio and Video streams
How to View Blu-ray movies (ISO image files) on projector via WDTV
Source: http://open-media-community.com/2014/01/23/lossless-backup-blu-ray-to-himedia-900b/,and you can search fgzp513.edublogs to know more!
Anncarrie
Postova:  92
