Solved! Confused about copying DVD to Sonology Diskstation?
Postod catpav520 » 23.01.2014 15:54
Description: More and more people keep an eye on how to protect your favorite DVD disc from scratched. This article mainly tells you how to backup/copy DVD discs on a sonology diskstation for wathing or syncing.I wanted to store my DVD collection on a sonology diskstation, then I can watch the videos from any mobile device or on my tv when I connect my laptop. How to make it?
DVDs, as with all kind of optical media, is that they are pretty easy to damage. DVD players need the DVD to be in a specific format. To can easily play DVD content from sonology disk station with no restrictions and without needing the DVDs every time. You need to use a DVD ripping software to rip and transfer the DVDs to sonology disk station for watching.
So I'm looking for the best software to copy dvd digitally without sacrificing the picture quality on the internet for quite a while until I met this Best Blu-ray Ripper. I like that it's simple to use as I'm not a computer technician. The ripped video works well on my galaxy s4, iPad 2, and a laptop.
Overall, this Blu-ray Ripper is a professional Blu-ray/DVD converting program which works with 1:1 backup solution and convert Blu-ray/DVD to MKV/MP4/MOV/M4V/MPG/FLV/AVI/WMV, etc. Well I haven't got the chance to try every profile, but it's really the best Blu-ray/DVD backup tool I've met ever; I mean it's ease of use, not fuss and simple to follow. This best Blu-ray Ripper can rolls off Blu-ray/DVD disc protection, supports loseless 1:1 Blu-ray backup and keeps all the disc titles and chapter structure perfectly.
Don't you like to have a try?
They provide free trial (no time limitation) before purchase; and you can reach the Mac version here. Both are 20% off now.
How to backup DVD disc on a sonology disk station with best video quality
Step 1. Import DVD discs to Pavtube Blu-ray Ripper.
Run the best DVD backup software, click "Load files" icon to load the DVD discs. After successful 100% load, click the select main title you are able to preview the whole movie in the preview window, which works just like a media player.
I also noticed if you have a ISO file to import, it will recognize the ISO file automatically with no need to run virtual driver and mount ISO files firstly. Good design.
Step 2. Different ways for copying DVDs to sonology disk station.
Here I will show you two different ways of lossless backup DVD disc:
Method 1. Full disc copy: 1:1 backup the entire disc with original structure and chapter marks
If you want to copy a 3D/2D DVD discs and remain 3D/2D in output files for further playback, or keep the original structure of disc for further creating ISO files or DVD discs, that is what exactly "Full disc copy" can do for you.
Click "Copy the entire disc" icon on the interface and you are brought to conversion progress immediately.
After conversion, go to "Open output folder" you will get a generated folder combined with two folders: "BDMV" and "CERTIFICATE". All the M2TS files are located in BDMV folder.
Method 2. Directly Copy: 100% backup the intact main movie of DVD discs
If you just want to copy the main movie for playback without the menu and promotional clips etc, "Directly Copy", which will takes less time for conversion and occupies less space than Full disc copy, is right for you.
Click "Format" menu and go to "Copy" option, choose "Directly Copy" for output format.
Then click "Convert" button to start coping. Once finished, you will get a converted file in M2TS format for DVD disc.
Every time when the conversion is finished, "Open" button on the main interface will help you to locate the generated files. If you try to copy one DVD disc in different ways, you do not need to worry about that the previous one will be covered because of the same file name. In this case, the software will automatically add number 1, 2, 3… in the end of file name because of built-in setting of renamed the same file name.
You can choose any way of them to copy your DVD disc without quality loss. Now connect your sonology diskstation to computer and transfer them into it, then share them with your family or friends.
Related articles:
Sync 3D Blu ray discs via WDTV
Backup Blu-ray/DVD to AC Ryan Player on Mac for TV
Lossless backup Blu-ray to HiMedia 900B with mutli-track MKV on Mavericks
From: http://mediaconverting.blogspot.com/2014/01/backup-dvd-on-sonology-diskstation.html
catpav520
Postova:  44
Korisnici koji su trenutno na forumu: Nema registrovanih korisnika i 49 gostiju
