Convert VOB to Sony Vegas Pro without loss of quality
Postod jacknjchn » 17.12.2013 10:23
Summary: In this article, I recommend you a best VOB to Vegas Pro App that can help you easily convert VOB to Sony Vegas Pro friendly MPEG-2 files with best quality & fast speed.
VOB standards for "Video Object". It is a video format to store video on a DVD disc. If you have some VOB files and want to import VOB files to Vegas Pro for further editing, you will be disappointed to find that the program can’t support the format. Fortunately, there is an easy way to solve the issue. You can do as follows to change VOB to Vegas Pro compatible files, like MPEG-2.
A VOB file usually contains one or several audio tracks and subtitle tracks that are multiplexed together into one stream form, it is not so easy to playback or edit. To convert VOB to Sony Vegas Pro, without losing video quality, Brorsoft Video Converter would take the convenience of VOB to MPG conversion as a quick and simple-accessible task. With the user-friendly software you can achieve your aim in only three steps. After the conversion, all you need to do is to drag the result videos for prompt editing.
Note: If VOB files are still in your DVD discs, or in VIDEO_TS folder, you need Blu-ray Video Converter Ultimate for help. It’s a package tool that can help you convert BD, DVD and kinds of common video files.
How to Convert VOB for Editing in Sony Vegas Pro smoothly
1. Add VOB files to the best VOB to Vegas Pro App
Launch the VOB converter. To add VOB files, you can just drag video from your file folders to the list in the operating window, or head to Add button to choose the file you want to convert.
2. Set output format
Click the format icon to open the format list, then choose Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg) as the target format.
Tip: This VOB to MPEG-2 Converter also enables you to edit the video before the conversion by trimming, cropping, changing video effect, adding subtitles, etc. Click the Edit button to do it.
3. Start to convert VOB videos
Click "Convert" to start converting your video from VOB to MPEG-2 for smoothly editing in Sony Vegas Pro.
P.S. This VOB to Sony Vegas Pro Converter can also help you convert VOB to MP4, WMV, AVI, FLV, MOV and more popular video formats to meet your needs.
More Guides:
How to Convert VOB to MOV on Mac
How to Convert VOB to AVI/MP4/WMV/MKV/FLV
Get the Best DVDFab Alternative in OS X Maverick
Sony PMW-F3 XDCAM EX Workflow for Final Cut Pro
Importing MP4 video clips to Sony Vegas Pro for further editing
How to Load Sony PMW-F3 XDCAM EX MP4 to Adobe Premiere Pro
Source:How to Convert and Open VOB files in Sony Vegas Pro
jacknjchn
Postova:  53
