Working with Panasonic HC-X920 AVCHD in Final Cut Pro 7
Postod AbbyCarrie11 » 12.12.2013 15:31
Panasonic HC-X920 3MOS Ultrafine Full HD Camcorder features three 1/2.3″ BSI MOS sensors for recording Full HD 1080/60p video in the AVCHD format. The 12x Leica Dicomar zoom lens has a fast max aperture of f/1.5 and a 35mm equivalent of approximately 29.8-399.2mm, and the optical zoom is supplemented by an 25x Intelligent Zoom. Built-in Wi-Fi enables real time streaming and remote control via a smartphone or tablet. Other features include a 3.5″ LCD touchscreen monitor, Five Axis Hybrid OIS, 5.1-channel surround sound, and iA Plus Mode.
Final Cut Pro 7 is new released with powerful new features like expanded ProRes codecs, improved speed/XML interchange/media management, etc and some time-saving improvements like automatic transfer, easy export, and so on. However, this new released FCP 7 supports AVCHD with at 1080p 24/25/30, 1080i 50/60, 720p 24/25/30/50/60, so the 1080 60p/50p MTS/M2TS is still incompatible with Mac FCP 7 NOW!
So if you want to edit HC-X920 1080 60p/50p 28Mbps in Final Cut Pro 7, you are recommended to use aPubsoft AVCHD Converter for Mac, which is the superior Mac Panasonic 60p/50p MTS to FCP 7 converter for Mac OS X 10.9 Mavericks, Mac OS X 10.8 Mountain Lion, Mac OS X 10.7 Lion or Mac OS X 10.6 Snow Leopard. It does not only convert Panasonic 1080 60p/50p AVCHD to Apple ProRes 422 Codec MOV, H.264 MOV on Mac, but also merges 1080 60p/50p MTS files for import into Final Cut Pro 7.
Here is the step-by-step guide for you to import and edit Panasonic HC-X920 60p/50p MTS to ProRes MOV, H.264 MOV for Final Cut Pro 7 on iMac/MacBook Pro/Mac Mini/MacBook Air with Mac OS X like Mavericks, Mountain Lion, Lion, Snow Leopard, Leopard, Tiger.
Step 1. Load AVCHD 1080 60p/50p videos to aPubsoft AVCHD Converter for Mac.
After transferring .mts files from Panasonic HC-X920 camera, run aPubsoft AVCHD Converter for Mac as the best Mac 1080 60p/50p MTS to ProRes MOV, H.264 MOV converter, and click the “Add File” button to load .mts videos.
Step 2. Choose ProRes MOV or H.264/AVC MOV output format.
Click the “Format” option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) or HD video > HD MOV Video (*.mov) as output format. We are choosing .mov format, as this is the Mac compatible file extension. You can keep the 60fps by clicking the “Settings” button and enter 60 for the frame rate option.
Step 3. Merge Panasonic AVCHD files. (optional)
Select all the files and then click “Merge”, and the Panasonic HC-X920 1080 60p/50p MTS converter will join and combine the video clips into a single file as output.
Step 4. Convert HC-X920 MTS to MOV for Final Cut Pro 7.
Click the convert button under the preview window, the Mac Panasonic MTS converter starts converting 1080 60p/50p MTS videos to ProRes Mov or H.246 .mov, and joining the MTS files for editing in Final Cut Pro 7.
After converting and merging the MTS files, just import the output files to Final Cut Pro 7 and the video is in HD 1920×1080. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
If you are using Final Cut Pro 5 or lower version, you can also choose Final Cut Pro > Apple ProRes 422 (*.mov) or HD video > HD MOV Video (*.mov) as output format for editing on Mac.
Read More:
Final Cut Pro X/7/6 Workflow:Canon C300 MXF Compatible with Mac OS X, MXF to ProRes MOV
AVCHD Workflow using Canon XA 10 from shooting to Export to FCP 7 for Editing
How to Convert/Sync/Transfer Flash FLV/F4V Video to Apple iPad Air for Playing?
P2 MXF Upload to Mac-Convert Panasonic P2 DVCPRO MXF to FCE/FCP/iMovie/Avid
solutions of MXF Importing to Adobe Premiere CS5/CS6 by Making MXF Compatible
Rip DVD ISO Image to MP4 for iPad Mini 2 on Mac Mavericks/Mountain Lion/Lion
AVCHD to FCE 4/Adobe Premiere Pro-Import MTS/M2TS to FCE 4 or Premiere Pro CS5/CS6/CC7
Play Blu-ray/DVD Movies on Microsoft Surface 2,Enjoy Blu-ray/DVD on Surface Pro 2
AbbyCarrie11
Postova:  20
Pridružio se:  01.12.2013 15:22
