Convert Samsung/Sony/Canon/JVC MTS to ProRes 422 for FCP X
Postod JerryEdison001 » 07.12.2013 19:39
MTS format is a high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony, Canon, Panasonic. .MTS files are used primarily with Sony hardware. Camcorders make use of MTS in the form of AVCHD, a recording format made specifically for camcorders. Some camcorder models from Canon also use MTS files. These files are also present on Blu-ray disc compilations, therefore they are capable of storing quite a large amount of information and data tracks. MTS is not the compatible format for editing systems on Mac like Final Cut Pro X. FCP X, the latest version of Final Cut Studio, was released in 2009 by Apple software. The favorable format for FCP X is Apple ProRes.
Many HD camcorder users often search the internet for answers to questions, like how to convert the AVCHD MTS files for FCP X? And how to bring MTS clips to FCP X with all of them into one clip? Is there an easy way to convert AVCHD MTS to ProRes 422 HQ at 29.97 frame rate?
You got the right place! UFUSoft HD Converter for Mac is a best assistant of AVCHD MTS camcorders from Panasonic, Sony, Canon, JVC, Samsung, Hitachi, etc, with efficient processing system to convert, edit and merge MTS files to Final Cut Pro X for Editing. Here are 4 steps, really easy to show you how to convert and merge AVCHD MTS videos to ProRes 422 HQ at 29.97 frame rate. Let’s take a look!
How to transcode Panasonic/Sony/Canon/JVC/Samsung MTS to ProRes 422 at 29.97 frame rate for FCP X on Mac?
Step 1: Load original AVCHD MTS videos to this top UFUSoft HD Video Converter for Mac.
You can put all MTS files in one folder and load them into UFUSoft HD Video MTS to FCP X Converter for Mac by clicking “Add file”.
Step 2: Choose Apple ProRes 422(HQ) (*.mov) as output format.
Click the “Format” option, and choose “Final Cut Pro > Apple ProRes 422(HQ) (*.mov)” for converting AVCHD MTS videos to MOV with Apple ProRes codec (Frame Rate:29.97) for Final Cut Pro X. The output video will be kept as high definition 1920×1080.
Step 3: Merge AVCHD MTS files
Check all the files and then click “Merge”, and UFUSoft HD Video Converter for Mac will join and combine the MTS video clips into a single file as output.
Step 4: Set audio frame rates at 29.97
You can set audio frame rate at 29.97 and audio bitrate as high quality to keep high audio and video quality of output MTS to ProRes 422 HQ MOV at 29.97 frame rate for FCP X for post-production in FCP X. Besides, you can also set profiles according to specific needs.
Step 5. Convert AVCHD MTS to ProRes 422 HQ for FCP X
Click the convert button, the UFUSoft HD Video Converter for Mac starts convert and merge AVCHD MTS to ProRes 422 HQ MOV for editing in Final Cut Pro X. You can also put merged AVCHD MTS files in iMovie, Avid, Adobe Premiere, FCE, etc for editing on Mac.
Other Tips:
1. canon c300 mxf to fcP, canon xf105 plugin for fcp,mxf converter, sony mxf file converter, mxf to prores, canon xf305 fcp plugin, canon xf100 fcp plugin, canon xf fcp plugin
2. avchd to fcp, avchd to fcp converter,avchd into fcp, avchd to fcp 7, import avchd fcp converter, avchd to fcp final cut, prores 422 fcp for editing, import avchd final cut pro, m2ts to fcp
3. Logiciel de Lecteur Blu-ray,Lecteur Blu-ray pour Mac,Comment Lecture Blu-ray sur Windows 8,Télécharger Lecteur Blu-ray pour Windows 7,Lire les Blu-ray sur Windows 8/7 avec VLC,PowerPoint en Vidéo Convertisseur,Convertir PPT en AVI,PowerPoint en AVI Convertisseur,Convertir PPS en AVI/WMV/MKV/MP4,Convertir PPT, PPS, pptx à la vidéo,convertir avchd en avi gratuit
4. remove drm protection,drm removal software,drm removal itunes, video drm removal, wmv drm removal,drm removal itunes movie, drm removal itunes 7/8, drm crack itunes, drm converter itunes
5. ufusoft blu-ray player,vlc blu ray,ufusoft mac blu-ray player,aacs codec,ufusoft mxf converter for mac,vlc blu ray windows 8,media composer mov full hd,blu ray player for windows 8,panasonic ag-hvx200 conversor
JerryEdison001
Postova:  16
Pridružio se:  24.11.2013 13:01
Re: Convert Samsung/Sony/Canon/JVC MTS to ProRes 422 for FCP
Postod Gost » 03.09.2014 17:44
I downloaded MXF Converter free trial version last week, and I converted many MXF videos for playing on QuickTime. This software is good at converting any HD MXF, MTS, TOD, MP4 to MOV videos. With this perfect MXF converter for mac software, you can convert MXF to H.264 MOV for QuickTime, convert MXF to AIC MOV for editing in iMovie, convert MXF files to ProRes MOV for FCP X importing
Gost
