Can U Import and edit TS files in Final Cut Pro
Postod jacknjchn » 06.11.2013 9:37
Summary: Here is the step by step guide on how to easily convert TS files to Final Cut Pro most compatible format Apple ProRes with great output quality for easy editing work.
What is TS?
TS is short for Transport Stream. TS files are MPEG-2 video files and it is a standard format for transmission and storage of audio, video, and data, and is used in broadcast systems such as DVB and ATSC.
How to import TS files to FCP?
Import TS files to Final Cut Pro for editing from your many TS files? But at this time, you are into a predicament that you can't import ts video into FCP directly. TS files are MPEG-2 video files and recordings of television broadcasts in high definition. FCP is part of life which most familiar for Mac users, but it is not compatible for TS files.
How to solve this problem easily? Brorsoft Video Converter for Mac, as a professional TS to FCP Converter, is your best helper. With this converter you can convert ts files into ProRes .mov for Final Cut Pro(X), FCP 6/7 with least quality loss. Download it and follow the tutorial below showing the detailed steps on how to encode TS files.
Step 1: Add files- Press “Add File” button to locate and open your TS files and then import to the Mac TS converter. You can also directly drag ts files to program.
Step 2: Select output format- Click on “Format” drop-down list, you could easily choose Final Cut Pro, Final Cut Pro >> Apple ProRes 422 as the target format.
Step 3: Advanced Settings- You can adjust video/audio parameters such as bitrate, sample rate, frame rate, codec, channels, etc after clicking on “Settings” icon.
Step 4: Convert TS to FCP- Press “Convert” button to start the TS conversion on Mac. It will be finished with high output quality and fast converting speed.
After the conversion is done, locate the converted file in the folder you specified and go ahead to import to Final Cut Pro 6/7/X to enjoy your work now.
Additional Tips: If you want to edit TS files in iMovie, please select iMovie and Final Cut Express" > "Apple InterMediate Codec(AIC) (*.mov) as output format with this top TS File Converter for Mac.
See more tips and tricks:
How to import TiVo TV shows to Final Cut Pro/iMovie
How to import VOB files into Final Cut Pro X
Convert MVI to AVI, WMV, FLV, MOV, DVD
Can U add or transfer AVI/VOB/WMV to iPhone 5S/5C MP4 format
Can U Make AVI file Playable on Kindle Fire HDX
Best method to import without quality loss
Source:The best solution to working TS files in FCP
jacknjchn
Postova:  53
