Converting Canon XA20 MTS files for Avid Media Composer
Postod lydia622520 » 28.10.2013 8:54
Summary: Having issues when importing and editing Canon XA20 AVCHD mts files in Avid Media Composer? Get the best Canon XA10 video converter here and problems would be solved effortlessly.
The Canon XA20 is a compact, "run-and-gun" HD camcorder with an impressive optical performance from a powerful new Genuine Canon 20x HD Video Lens with a new 8-Blade Circular Aperture, capable of focusing down to just 23.6 inches (60cm). It supports multiple HD/SD recording rates - including 24p for a "cinematic" look - together with a choice of industry-standard MP4 (up to 35 Mbps) and AVCHD (up to 28 Mbps) codecs. If you record some 1080p AVCHD .MTS/M2TS files and wanna do further editing in Avid Media Composer, you are in the right place from where you can get the tips for Canon XA20 MTS and Avid Media Composer workflow.
Well, something frustrating, when enjoying the stunning HD image quality from Canon XA20, many folks are having problems when importing Canon XA20 1080 60p AVCHD to Avid MC. In fact, very few NLE's can support 60p AVCHD video including Avid Media Composer, Final Cut Pro, iMovie, etc. Actually, 60fps at 1080 is a non-standard format and Avid only works with standard film and broadcast formats. Although, Avid MC has added some plug-ins, actually background converters for the high-definition video format AVCHD, the importing process are unbelievably slow.
In order to import XA20 60p MTS footage into Avid Media Composer for smoothly editing, you can use 3rd-party software to re-wrap and convert 60p MTS to MOV encoded in DNxHD codec first, which is a native format for Avid. It’s a great way to achieve your goal smoothly. First of all, downloading the App- Brorsoft MTS/M2TS Converter for Mac
It can aid you to change AVCHD (*.MTS) files to standard DNxHD mov for Avid Media Composer without losing any quality. In fact, it's an all-in-one converter for fast transcoding, deinterlacing AVCHD MTS footage from Canon, Panasonic, JVC, Sony full HD camcorder/cameras on Mac OS X(Leopard/Snow Leopard/Lion/Mountain Lion) that makes the MTS editing work much easier with Non-Linear Systems. If you are on Window, please turn to Brorsoft MTS/M2TS Converter.
Transcoding Canon XA20 MTS recordings to Avid Media Composer
Step 1: Install and Launch the MTS Converter for Avid on your Mac and load your .mts/.m2ts files from XA20 to it.
Step 2. Click “Format” bar to choose Avid Media Composer -> Avid DNXHD (*.mov), this format is best presetted for Avid Media Composer editing.
Tip: Tap Settings” button in the main interface to customize the Video Codec, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels as you want.
Step 3. Click the “Convert” icon under the preview window, and the Mac MTS to Avid MC Converter will start transcoding Canon XA20 MTS to DNxHDMOV for Avid Media Composer on Mac.
After the conversion, click the “Open” button to locate converted files, then load .MOV files to Media Composer. Now you can successfully and easily transfer Canon XA20 60p videos to Avid Media Composer 5/5.5/6/6.5 for editing with the best quality.
Tips on AVCHD Converter for Avid MC:
1. Joining files: Tick the box "Merge into one" on the main interface.
2. Preview: Double click on the file and you can get a preview on the converter.
3. Crop: Edit --> Crop and you can get the imported videos cropped as you want.
4. Auto shutdown: Click Option and tick the box “Shut down the computer after conversion” before conversion starts.
See more:
How to import Canon XA25 footage to Final Cut Pro
Ingesting Convert XA20 MTS video to DNxHD for Avid MC
Edit Canon XA10 AVCHD MTS with FCP, iMovie, FCE
When i try to import Canon XA20 files in Final Cut X got generic error
Best way make Canon T5i footage editable in Vegas Pro
Convert MTS to MOV on Mac (Mavericks/Mountain Lion included)
Source:Convert Canon XA20 MTS to DNxHD .mov to work with Avid MC
lydia622520
