How to convert VOB files to QuickTime MOV files
Postod lydia622520 » 22.10.2013 10:40
Summary: In this article, I recommend you a best VOB to QuickTime App that can help you easily convert VOB to QuickTime MOV files with best quality & fast speed.
VOB standards for "Video Object". It is a video format to store video on a DVD disc. If you have some VOB files and want to convert VOB to QuickTime for playback on QuickTime Player or other media devices like iPad, iPhone; or you want to edit them with iMovie, FCE, Final Cut Pro, you can do as follows to change VOB to MOV files, the Apple products compatible format.
To convert VOB to MOV, without losing video quality, Brorsoft Video Converter for Mac (Mavericks, Mountain Lion, Lion supported) would take the convenience of VOB to MOV conversion as a quick and simple-accessible task. With the user-friendly software you can achieve your aim in only three steps. And if you wanna do the same job in Windows, you can get VOB to QuickTime Converter.
Note: If VOB files are still in your DVD discs, or in VIDEO_TS folder for Mac users, you need iMedia Converter for Mac for help. It’s a package tool that can help you convert BD, DVD and kinds of common video files.
1. Add VOB files to the best VOB to QuickTime App
Launch the VOB to MOV Mac converter. To add VOB files, you can just drag video from your file folders to the list in the operating window, or head to Add button to choose the file you want to convert.
2. Set output format
Click the format icon to open the format list, then choose MOV out from "Common Video" category. If you are about to use MOV files on QuickTime, iPhone, iPad, iPod, iMovie or Final Cut Pro, you can select the presets for them under a certain category.
Tip: This VOB to MOV Converter for Mac also enables to edit the video before the conversion by trimming, cropping, changing video effect, etc. Click the Edit button to do it.
3. Start to convert VOB to MOV in Mac OS
Click "Convert" to start converting your video from VOB to MOV on any Mac OS including Mavericks, Mountain lion, and Lion.
P.S. This VOB to QuickTime App can also help you convert VOB to MP4, WMV, AVI, FLV and more popular video formats to meet your needs.
More Guides:
How to import VOB files into iMovie/FCE
How to open AVI files in Sony Vegas Pro 10/11/12
Enable VOB files to work within Final Cut Pro X
VOB to iMovie: How to convert and import VOB files to iMovie
How can I add WMV and VOB files to iTunes
How to Convert and Import AVI to Sony Vegas Pro
Source:How to Convert VOB to QuickTime MOV on Mac/Windows
lydia622520
Re: How to convert VOB files to QuickTime MOV files
Postod jacknjchn » 24.10.2013 9:19
[size="4"]You may come across lots of problems when you import VOB files into QuickTime App. Fortunately, there is an easy way to fix the issue. Let's find it out here! This tutorial is for anyone who uses mac and has problems playing their .vob files on Quicktime. [/size]
[size="4"]Why convert VOB to MOV (QuickTime supported format)?[/size]
VOB is used as a container format in DVD-video media. You can commonly find it in the VIDEO_TS folder at the root of a DVD. VOB files can be played by many players such as VLC, MPlayer, ALLPlayer, GOM Player and more. Maybe you want to edit VOB in iMovie, or play these files on your iPad, iPod or iPhone, etc.,. Unfortunately, the vob format is note Apple products compatible format.
And the most popular video format on the Internet is QuickTime; the video quality is excellent and all users have to do to watch QuickTime videos is download and install the QuickTime player, which is free. If you have QuickTime Pro installed, you can convert VOB to MOV directly. Just choose MOV as the output format by selecting "Save as". If you don't have QuickTime Pro installed or QT pro can't convert the VOB successfully, you can use this professional yet easy-to-use VOB to Quicktime Converter to do the VOB to MOV Mac converting task. This Mac app enables you to convert any video or audio in all popular formats with ease.
Download & install the Best VOB to MOV Converter
Slika (Note: Click here for OS X 10.5) Slika
[size="4"]How to Convert VOB Files to Quicketime MOV Format on Mac[/size]
Step 1: Load VOB videos to this Mac VOB to MOV Converter
Launch launch the VOB to Quicktime Converter on your Mac and click the "add video" button to browse your computer hard disc and load the VOB video files you want to convert to the software.
Step 2: Click Format column and choose best video format for output. You can choose QuickTime Movie Format. Or, you can also choose "Common Video -> MOV – QuickTime (*.mov)" as the target format.
Note: If you want to convert VOB video for portable device and don't know what formats your device supports, you can just select the format according to the device name.
Also: You can click settings button to customize the output video parameters as you want, such as video resolution, video bitrate, etc.
Step 3: Tap the conversion button to start converting VOB files to QuickTime MOV. After conversion, tap the Open button to get the output files. Later, you can use VOB files with QuickTime player or edit, share, upload on Mac as you want.
More Topics:
Edit Canon XA10 AVCHD MTS with FCP, iMovie, FCE
Edit MP4 files with iMovie program on Mac OS X
How to Convert and Import AVI to Sony Vegas Pro( Vegas Pro 10/11/12)
Import Nikon D3S/D7100 MOV files to Premiere Pro
Source:How to Convert VOB to Quicktime Movie Format MOV on Mac
jacknjchn
Postova:  53
