How to import Canon T5i MOV files to Sony Vegas Pro
Postod jacknjchn » 16.10.2013 10:12
Summary: How to import Canon Rebel T5i (EOS 700D) MOV to Sony Vegas Pro to edit? This article will introduce an easy way to convert Canon T5i MOV videos to Vegas Pro compatible MPEG-2/WMV for editing in Vegas Pro 9/10/11/12.
For Canon fans, it’s glad to hear the new Canon 700D (Rebel T5i) with a better user experience. Its external body switches to the texture of the particle coating has a better touch feeling, slip resistance and better. While, you may find it’s a painful experience to import video files from Canon T5i to Sony Vegas Pro for editing.
“I recently purchased the canon rebel t5i and is starting to get into film making. I just shot my first video and am trying to edit it by using the Sony Vegas Pro 11. But every time i try to import a video clip from the canon rebel t5i nothing comes up on the Vegas Pro 11 screen. why is this happening please help! ”
In order to edit your Canon T5i MOV footage in Sony Vegas Pro smoothly, you should transcode MOV format to WMV or MPEG-2 format, which is best supported by Vegas Pro.
Brorsoft Video Converter is best choice to get the work done. I have used this tools for a long time, and I also transcode Canon MOV files to Sony Vegas Pro. This software can deal with almost all kinds of videos including AVI, MOV, MKV, MTS, MXF, etc. With it, you can effortlessly transcode the Canon T5i videos for smoothly editing in Sony Vegas Pro 9/10/11/12. Just take a look at the brief guide below.
How to import Canon T5i videos to Sony Vegas Pro for smoothly editing
Step 1. Download, install and launch the Canon MOV Converter, and then click the button “File” to add H.264 .mov footage to the program.
Step 2. Click "Format" bar to determine output format. For smoothly editing in Vegas, you are recommended to choose Adobe Premiere/Sony Vegas -> WMV (VC-1) (*.wmv), this format is best for Sony Vegas Pro editing. MPEG-2 is anther choice for you.
Step 3. If you would like to customize the video and audio parameters, you can click "settings", adjust the parameters as you want, like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels.
Step 4. Click "Convert" to start to convert Canon T5i to Sony Vegas Pro.
Note: Before start the conversion, click Edit button and you can trim, crop, add watermark, adjust video effect, add subtitles if you need.
With this Canon MOV to Sony Vegas Pro converter, it becomes easy for you to convert Canon video to Vegas Pro smoothly for editing.
Related articles:
Editing Canon T5i .MOV files in iMovie/FCE
How to import Canon T5i video to Final Cut Pro
How to transfer Canon T3i/T5i footage in Windows Movie Maker
How to upload video clips from Canon T3i/T4i to Sony Vegas Pro
Canon T5i/T4i/T3i video footage Transcode to Sony Vegas Pro Tutorial
MP4 Converter Download For iMovie editing mp4 file
Source:Best way make Canon T5i footage editable in Vegas Pro
jacknjchn
Postova:  53
