How to edit MTS files directly using Adobe Premiere Pro
Postod lydia622520 » 25.09.2013 9:35
Summary: Does MTS just go straight into Adobe Premiere Pro? In this article, we will give you the tips how to import and edit AVCHD MTS files in Adobe Premiere Pro CS3/CS4/CS5/CS6 without problems.
Just happen to have some video footage in AVCHD .mts format? That would be "Advanced Video Coding High Definition"—you know—HD video files. If you've got some of those MTS files from a Sony, Canon or Panasonic camcorder, you want to open in a program that doesn't support them, like Adobe Premiere Pro, then you're going to have to convert them to a different format. Here's a way to convert MTS to Adobe Premiere Pro without losing the quality.
Although Adobe claimed that Premiere Pro CS5 and above offer much better native AVCHD support than its predecessor, there are still some video, audio codec problems while importing/editing AVCHD MTS clips in Premiere Pro. Plus, even the Adobe program can ingest your MTS files directly, it takes a long time for rendering. The best method to avoid any problems and save time is to transcode MTS footage into a Premiere Pro most compatible format like MPEG-2.
Brorsoft MTS Converter for Mac is a highly-recommended video converting tool for you to convert MTS files to Adobe Premiere (CS3/CS4/CS5/CS6 included) compatible format without loosing quality. With it, you can convert any video shooting in party or birthday with AVCHD camcorders to popular video format like MOV, AVI, WMV, MP4, FLV, etc. What’s more, the conversion is easy to handle and only with a few simple clicks, you can finish the conversion without facing any glitches. For Windows user, please get MTS/M2TS Converter. Download the program and you can edit MTS in Adobe Premiere Pro smoothly as you wish.
Steps to convert MTS videos to Adobe Premiere Pro acceptable format
1. Import MTS to the converter
Run the MTS to Premiere Pro converter and click the Add Files button to import the MTS videos to be converted. The converter supports converting multiple files at a time.
2. Choose MPG/MOV as the output format
Click "Format" drop-down bar to select a proper video format. To edit AVCHD videos in Adobe Premiere, then Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg) is the suitable one.
3. Start MTS conversion with a click
Hit the big Convert button on bottom of the main windows and the conversion from MTS to Adobe Premiere Pro will begin immediately.
Tips & Tricks:
1. Adjust audio and video settings
The Mac MTS to Premiere Pro Converter enables users to adjust audio and video settings before transcoding AVCHD files to MPEG-2. Click "Settings" button, then you will enter the following interface, on which you are allowed to customize size, bit rate, frame rate, sample rate, and audio channel to your required ones.
2. Basic video editing (optional)
This Mac MTS converter enjoys a built-in video editor, so you can touch up the video with basic video editing functions. The supported video editing operations are: Trimming, cropping, appending artistic visual effects, adding watermarks and load subtitles to the videos. Just note that this step is skippable if you want to keep the original video effects.
After the conversion is complete, get the resulted files via clicking the Open button and then you can import MTS to Adobe Premiere Pro for further editing without any hassle.
Related Articles:
How to covnert, edit and join 3D MTS files
Importing 60p AVCHD footage to Sony Vegas Pro
Tricks for Editing AVCHD .mts/m2ts files in Pinnacle Studio
Converting M2TS to ProRes .mov for Final Cut Pro on Mac
Easy way to open M2TS files in Sony Vegas Pro
Avid MXF to FCP - Can FCP import Avid MXF Files on Mac
Source:Converting MTS to use in Adobe Premiere Pro on Mac
lydia622520
Re: How to edit MTS files directly using Adobe Premiere Pro
Postod jacknjchn » 05.10.2013 5:38
Summary: To get Final Cut Pro working perfectly with AVCHD .mts files, a best way is to convert MTS to ProRes MOV, something ensuring best results when using .mts files in FCP. Read on to learn details.
As you see, the incompatibility of AVCHD .mts files exists among different camcorder manufacturers. Mostly, the MTS footage captured by Sony Handycam is encoded with H.264/AVC codec which does not work well with video editing software except for few ones. Despite of this, H.264 codec is acknowledged as a universal codec for camcorder videos, especially for HD contents. The advanced compression method of H.264 results in much less storage and the same picture quality comparing with MPEG-4. However, the highly-compressed content is not so friendly for editing software. Then, how to get Final Cut Pro working perfectly with AVCHD MTS footage? A best way is to convert MTS files to ProRes .mov, something ensuring maximum editing quality and efficiency when working with FCP.
If you have problems when using MTS files in Final Cut Pro and want to make a smooth editing, you can read on the article to learn more. Here I will outline how to transcode AVCHD MTS files to ProRes MOV for smoothly importing and editing in FCP 6/7/X.
Converting MTS files to ProRes MOV for Editing in Final Cut Pro
The quick workaround is to use the easy-to-use yet professional app called Brorosft MTS/M2TS Converter for Mac which can be used as a AVCHD MTS to FCP Converter under Mac OS X 10.9 Mavericks, 10.8 Mountain Lion, 10.7 Lion, Snow Leopard 10.6, etc. It is free, clean and safe to install and use. With it, you can effortlessly transcode MTS to Apple ProRes 422, ProRes 422 HD, ProRes 422 LT, ProRes 4444 for FCP, MPEG-2 for Premiere Pro, DNxHD .mov for Avid MC, etc., and it works well and converts flawlessly. If you running a Windows computer, please turn to the alternative Windows version – MTS Converter. Below is how.
Step 1. Add MTS footage to the MTS to FCP Converter.
Once you run it, click “Add Video” button or “Add from folder” button to load your source MTS files. When the MTS files are loaded to the MTS to FCP Converter, you can view the videos from the Preview window. Simply select an item and click the “Play” button. When the video is playing, you are allowed to take snapshoot.
Step 2. Choose ProRes MOV as output format for MTS to FCP conversion.
Brorsoft MTS Converter Mac offers optimized format presets for Final Cut Pro, “Final Cut Pro -> Apple ProRes 422 (*.mov)", “Final Cut Pro -> Apple ProRes 422 HQ (*.mov)", etc. Choose a one you need.
If the default settings do not fit your needs, you can click “Settings” button to adjust audio and video parameters as you like.
Step 3. Convert MTS to ProRes MOV for importing to Final Cut Pro.
Click “Convert” button and the selected MTS files will be converted to Apple ProRes encode mov files. You may check the converting progress and set auto shutdown in the conversion window. After conversion, click “Open” folder to find converted footage for importing to Final Cut Pro 6/7/X.
Additional tips:
The versatile AVCHD MTS Converter Mac is not only designed for converting MTS files for Final Cut Pro. It is also professional in making AVCHD files editable in Adobe Premiere Pro, FCE, Avid Media Composer, iMovie, etc to meet your different needs.
More Guides:
Using Canon H.264 MOV files in Sony Vegas Pro smoothly
What if iMovie won't import MP4 files
JVC Everio MTS files and iMovie/FCE/FCP/Avid MC/Premiere Workflow
jacknjchn
Postova:  53
Postod JeanLiu » 09.01.2015 10:54
Pavtube Unlocks Up to 50% Off 2014 Christmas Deals along with upgrading
To celebrate the biggest festival Christmas, Pavtube offers up to 50% off promotion and discount on its all Blu-ray, DVD Copy and Video Converters. Never miss!
Tags: pavtube christmas deals,2014 christmas gift,christmas promotion at pavtube
The year may be coming to a close, but entertainments as well as deals are still in full swing. To celebrate the biggest festival Christmas, Pavtube Studio, which aims at creating expert multimedia software applications, provides the biggest discounts and sends their Christmas joys with their registered users and potential customers.
At its released 2014 Christmas special page, all Blu-ray, DVD and Video Converters are on sale with up to 50% off promotion. This activity starts now and expires on January 31, 2015. Seize the opportunity and enjoy the Christmas joyfulness with Pavtube Studio!
Slika 2014 Christmas Promotional Items
1. 20% OFF - 30% OFF Gifts
20% OFF Pavtube DVDAid (Win/Mac)
20% OFF Pavtube Video Converter Ultimate (Win/Mac)
30% OFF Pavtube ByteCopy (Win/Mac)
30 % OFF Pavtube BDMagic (Win/Mac)
2. Extra $9.9 to Get Another
Buy one converting tool, you just need to pay extra $9.9 to get another one. Just contact [email protected] or [email protected] and get your perferable combination!
3. Share to Facebook to get 50% OFF Gifts
Click "Share on Facebook" button, insert "#PavtubeChristmas2014",choose "Public", and click "Share Link". Then send us the screenshot by email to [email protected] or [email protected]. You will receive a 50% OFF discount link of any Blu-ray/DVD converter from Pavtube within 24 hours on week days. Please do not forget to invite your families and friends to join in, and we’ll appreciate your action!
Follow this link to check our deals and find Christmas wallpapers, games, and ringtones to decorate their Android, Apple and Windows devices.
Everything you need on Christmas Day can be found on Pavtube 2014 Christmas Deals page. Hurry up now! Get greatest discounts on these must-have tools and get your wonderful Christmas gifts with half price! What Pavtube can do for you:
All-in-one Blu-ray/DVD to any video solution
Full disc copy with original BD/DVD structure, no quality loss
Customize Blu-ray/DVD with built-in video editor
Professional video editing tool with trim, crop, split, merge and other options
What's new in the recent upgraded Pavtube products:
Add H.264 baseline/main/high output profiles
Support H.265/HEVC decode
Support H.265/HEVC encode
Support latest Blu-ray movies
At last, enjoy your most wonderful Christmas season this year! Merry Christmas and Happy New Year!
Money Saving Boundles:
Source:http://open-mobile-share.com/pavtube-2014-christmas-deals/
