Batch convert VOB, WMV to iTunes 11 supported format
Postod lydia622520 » 09.09.2013 8:43
Summary: Since installed the new iTunes 11, many users can’t successfully add videos to iTunes 11 in various situation. This tutorial just aims to solve iTunes 11 won’t import VOB, WMV video issues.
When you add video files like WMV, VOB to iTunes 11 library, you'll be disappointed since iTunes natively doesn't support the .wmv, .vob format. First of all, have a look at the related issues:
Q1: I have latest update of iTunes 11 on a PC running on XP. I have a few WMV files I'd like to add to iTunes and convert for my iPod Touch. According to the help files I should be able to drag and drop the files or go to Files>Add File To Library. Nothing happens with either option. And yes I have already searched this forum. No one seems to want to answer this question. Can someone give it a go please?
Q2: Is there a way to convert .vob files to be able to upload them to iTunes 11 so that I can put them on my 3rd generation iPad? I am having trouble finding a way to put my own videos onto my iPad. Need help!
As we know, iTunes can only support .mp4, .m4v, or .mov format. That means in order to import WMV, VOB to iTunes 11, you need to convert WMV/VOB to iTunes supported video formats first and then transfer the converted videos to iTunes for playback.
Here Brorsoft Video Converter is recommended as the most appropriate tool to convert WMV, VOB, MTS, MKV, AVI, MPG, etc files to iTunes MP4, MOV or M4V fast yet with high output video quality. This program is fully compatible with Windows 8/7/XP/Vista. If you're using a Mac, simply get the equivalent Mac Video Converter to convert WMV, VOB to play in iTunes on Mac OS X (Lion and Mountain Lion included). Download WMV/VOB to iTunes Converter and start the conversion.
How to convert WMV/VOB to iTunes 11 playable video
1. Open the program and load the WMV, VOB video files from your computer or devices in either of the 2 ways: 1> Click Add Files to browse and select videos for conversion. 2> Directly drag the files to the program interface to load them.
2. Since iTunes supports MP4, M4V and MOV formats, you can click Format bar and choose any of the three from Common Video as the output file format.
Tip: If you want to transfer .wmv, .vob to iTunes for playing on iPhone, iPad, iPod, Apple TV, etc., you can also directly select a format from decent device preset like iPad.
3. Hit Convert button to start converting the added WMV, VOB to iTunes MP4. When the process is done, click Open button to locate the converted videos.
4. Now open iTunes and click File > Add Files to Library to import the converted video files to iTunes library. Now you can play the WMV, VOB files in iTunes without any troubles or just transfer them to your iPhone, iPad, iPod without any restrict.
More Guides:
How to transfer Blu-ray movies to iTunes (iTunes 11)
How to rip and copy DVD to iTunes (iTunes 11)
How to Use Samsung Galaxy Note 3 to Watch HD Videos
How to Convert Blu-ray to iTunes 11 for Apple TV 3
Playing Blu-ray with VLC Media Player on Mac
Import AVI movies to iTunes 11 library
Source:How can I add WMV and VOB files to iTunes
lydia622520
Re: Batch convert VOB, WMV to iTunes 11 supported format
Postod JeanLiu » 28.03.2015 9:36
Play downloaded Web videos on mobile devices
This simple guide outlines the best way to play downloaded Web videos on mobile devices by converting Web video to playable mp4 format on PC and Mac.
As an active web video consumer, maybe you've downloaded some online movies or TV shows in FLV, F4V, AVI format and try putting these downloaded Web videos on mobile devices for playback on the move.
However, you will soon notice that you are not able to get all of them played smoothly since different Mobile Device has different format limitations. To solve this problem, you are required to convert downloaded Web videos to MP4 or other Mobile Devices compatible formats for a change first.
Preparation:
Pavtube Video Converter Ultimate (Read Review) which is perfect application for converting downloaded Web videos to Mobile Device easily. This is a powerful video converter, editor and player, which offers an optimized preset most popular devices like iPad Air, iPhone 6, iPhone 6 Plus, Galaxy Note 4, Kindle Fire HD, Nexus 7, Surface Pro, etc. Besides, this program also supports NVIDIA CUDA technology and its advanced video and audio sync technology makes it possible to get the converted video files at highest speed without quality loss.
Below is the step-by-step guide for converting downloaded Web videos to Mobile Device for smoothly playback.
Step 1: Import video files to Web Video Converter.
Launch Pavtube Video Converter Ultimate. Click the button "Add Video" to add video files. You can tick the box in front of the file you want to convert. If it is necessary, you can double click the each file to have a preview.
Step 2: Select an output format for Mobile Device and set the output folder.
Click on the dropdown menu of "Format", if you want to sync Web videos into a device like iPad, you can directly move you pointer to formats under "iPad" profile list. Or just search the device you want to play to by enter the name in the serch box and find the profile. Then you can set the output folder by clicking "Browse" icon as you need.
Step 3: Adjust audio and video parameters.
Click the "Settings" icon and you will go into a new interface named "Profile Settings". You can adjust codec, aspect ratio, bit rate, frame rate, sample rate and audio channel in the interface according to your needs and optimize the output file quality.
Step 4: Start converting your downloaded Web video files to Mobile Device.
Click the "Convert" button; it will start converting Web video to Mobile Device immediately. You can find the process in the "Conversion" interface.
After the Web video conversion, you will be able to get the output files for your Mobile Device via clicking on "Open" button effortlessly. And now you can transfer the converted video to your preferable media player on Mobile Device, and then you can have a smooth movie playback without any trouble.
Good News: Now you can get DVD Creator + Video Converter Ultimate as bundled series to help you convert videos as well as burn videos into DVD. It only cost you $64.9 (even cheaper than Video Converter Ultimate alone)!
See also:
Enable Handbrake to Directly Rip Blu-ray Collection
Rip Blu-ray/DVD to Tivo format on Mac?
Copy DVD to NAS or USB Flash Drive for Smart TV
View Blu-ray ISO Movies on Gear VR via XBMC
Transfer music/video from iTunes to Windows Media Player
Enjoy Blu-ray on 75 inch Samsung UHD TV through Plex
Compress Video for Email, YouTube, Vimeo, Facebook
Source: http://compatibleformat.snappages.com/blog/2015/02/05/convert-downloaded-web-videos-to-play-on-your-mobile-device
Postod JeanLiu » 21.05.2015 16:43
Pavtube Releases All-In-One Mac BD/DVD/Video to H.265 Converter
Pavtube upgraded iMedia Converter for Mac to version 4.8.5.1 to support Blu-ray/DVD/Video to H.265 MP4 encoding and H.265 video decoding on Mac.
Good News on May 15th, 2015! Pavtube upgraded its best-selling iMedia Converter for Mac to version 4.8.5.1, which features strong and perfect support for Blu-ray/DVD/Video to H.265 MP4 encoding and H.265 video decoding on Mac.
New features of iMedia Converter for Mac v4.8.5.1:
1. Supported to decode/encode the H.265/HEVC codec
2. Fix the XAVC MXF codec importing issues
3. Optimize coding parameters
4. Fix some bugs
This updated Pavtube iMedia Converter for Mac can act as best Mac H.265 Video onverter, which ensures you to complete 2D/3D Blu-ray, DVD, ISO and 4K/H.265 MP4 video conversion on Mac OS X 10.10 Yosemite, 10.9 Mavericks, 10.8 Mountain Lion at one go for enjoying with Windows 10, H.265 players like DivX Player, PotPlayer, PowerDVD 14 Ultra, etc, and for storage on Mac. And as a Mac H.265 decorder, it enables users to both decode H.265 videos to almost all video and audio formats like MP4, MOV, WMV, AVI, WMA, MP3 and convert H.265/HEVC for playback on iPhone, iPad, Apple TV, Chromecast, Android mobile and tablets, etc.
What's more, it is also an all-in-one mac toolkit to which can not only copy 2D BD, 3D BD and standard DVD with original structure, and convert all BD/DVD collection to virtually any video and audio format for iPhone, iPad, Apple TV, Android, Windows Phones, Xbox, PS3, and other devices, but also transcode between virtually all video and audio formats and add practical video editing functions to export media files playable on iOS, Android, Windows, game consoles, etc. on Mac.
For windows users, read this H.265/HEVC video decoder and encoder Review.
Wondering how to do the conversion?
Start Using Pavtube iMedia Converter for Mac
Pricing and Availability
For all the new Mac (especially Mac OS X Yosemite 10.10) users, iMedia Converter for Mac now is offering with $65 with a lifetime free upgrade.
Download sites:
Pavtube Official Website | CNET Download Site
Other three upgraded Mac products are listed below:
Pavtube DVDAid for Mac
Pavtube BDMagic for Mac
Pavtube ByteCopy for Mac
All Mac users are welcome to get these upgraded hottest and comprehensive mac products. Get more money-saving boundles at http://www.multipelife.com/special-offer. Come on!
Further Reaing:
Import H.265/HEVC to FCP X on Mac
Upload H.265 Video to YouTube
Play H.265 MP4 Blu-ray Movies on WDTV
The world's Top Blu-ray to H.265 Converter
Rip DVD to H.265/HEVC MP4 on Windows 8.1/8
Play Blu-ray movies on Samsung 4K UHD TV
Add Music & Live Music DVDs to iTunes Library on Mac
Get 3D Contents on Gear VR through Oculus Cinema
From: http://iappsnow.com/2015/05/pavtube-imedia-converter-for-mac-upgrade/
