Compatibility issues to import mts from Canon XA25 to FCP X
Postod kelly456 » 07.09.2013 9:49
Compatibility issues with importing mts from Canon XA25 to FCP X
Description: Follow this article to learn how to edit Canon XA25 AVCHD in Final Cut Pro X on Mac. The latest Mavericks is also supported!
Q: "Recently I got a Canon XA25 as gift for summer holiday. I shot lots of footages and really enjoy it. I saw my friends shared his Canon XA20 videos edited in FCP BUT when I try to playback the footage (I can only found the AVCHD file in memory card), quicktime did not like to open it nor did FCPX. Did I miss something?"
Canon XA25 is a newly released professional camera which is designed for "run and gun". It shoots exactly the same footages like XA20: Full HD 1080 60p/60i/30p/24p footages in AVCHD MTS and 1080 60p/30/24p as well as 720/360 30p/24p in MP4 format. The key different could be that Canon XA25 supports HD/SD-SDI output, which enables "direct connection to a microwave van, satellite uplink or other TV transmission system" and it’s also capable of recording uncompressed HD/SD-SDI signal.
Canon XA25 Reviews
Canon XA25 outputs video in extraordinary quality and does a great job in preventing shaking. You may have already taken this camera in summer holiday and shot lots of valuable moments. How do the footages like when playing back? Do you have any ideas about getting it editing in NLEs on Mac?
You may have learned that NLEs on Mac will not accept AVCHD MTS natively, especially for Final Cut Pro 6/7/X, iMovie, Avid Media Composer, etc. Each of them has its preferred video format/codec. For FCP, it’s the Apple ProRes codec.
Now follow this guide to learn how to import your Canon XA25 AVCHD MTS to Final Cut Pro 6/7/X.
1. This powerful Mac Canon XA25 MTS to FCP Converter is highly recommended for its simple interface, efficient work flow and reliable video quality.
2. This Mac FCP Converter includes many presets for different editing programs and devices. For FCPX users, the best preset is "Final Cut Pro>Apple ProRes". The Apple ProRes 422HQ is recommended for its good video quality for normally using.
For professional users, the Apple ProRes 4444 could suits you better.
3. click "Settings" to customize video size, bitrate, frame rate, audio channels and other settings.
Before converting Canon XA25 MTS/MP4 to Apple ProRes mov, you can click the "Edit" button, trim or crop the videos, add watermark or 3D effect, add subtitles to your videos, etc.
FAQs: How to add subtitle to video files?
4. Click "Convert" to start converting Canon XA25 AVCHD footages to best video format for FCPX.
You can also click "Open" to locate the convert video directly.
You can Read How to import the converted video into Final Cut Pro X?
Additionally, the Pavtube HD Video Converter for Mac can also be helpful in converting MTS/MP4 files to Adobe Premiere Pro, iMovie, FCE, Avid Media Composer support formats for editing; or convert MTS/MP4 videos to any Tablets, Smartphones, TVs, etc. devices for playing. Or you can try the all in all converting Program- iMedia converter for mac (20% off) from Pavtube, which can handle MTS, common video, DVD and Blu-ray videos, which is more powerful.
Refer to the related guides:
Edit Canon XA25/XA20 mts files in iMovie/FCE
Convert Canon XA25 AVCHD to QuickTime MOV
Import Canon XA25 AVCHD mts to Premiere Pro/After Effects CS6
Canon XA25 AVCHD work with into Avid MC and Xpress Pro
http://www.pavtube.com/guide/import-video-files-to-final-cut-pro-x.htmlConvert Canon XA25 MTSto Apple FCP and Aperture 3
Never miss Pavtube Pavtube Back to School Givaways and Click Pavtube Special Offer page to get more discount:
ChewTune for Mac($29) + iMedia Converter for Mac($65) = Only $75, Save $19
iMedia Converter for Mac($65) + DVD Creator for Mac($35) = Only 65$, Save $35
ByteCopy for Mac($42) + iMix MXF($45) = Only $70, Save $17
Source: Convert Canon XA25 AVCHD MTS/MP4 to Final Cut Pro X on Mac
