20% OFF Get XDCAM EX mp4 media readable in After Effects CS4
Postod kelly456 » 07.09.2013 9:45
XDCAM EX and After Effects-20% OFF Get XDCAM EX mp4 media readable in AE CS4
Description: As a Sony XDCAM EX user, are you annoying the import problem with After Effects CS4? Here you will find the solution. The article will tell you how to import Sony XDCAM EX footage to After Effects CS4.
Adobe After Effects?CS4, the popular postproduction tool for video professionals, is good at digital?motion graphics,?visual effects?and?compositing. And it is often used in the?post-production?process of?filmmaking?and television production, and used as a basic?non-linear editor?and a media?transcoder. The options in After Effects expand to work with the latest video formats, including P2, XDCAM, EX, and XDCAM HD, as well as Web applications.
However, when you import some Sony XDCAM EX footage with full HD resolution as either 1920?x?1080 or 1280?x?720, you may still meet some import problem.
"I'm having a nightmare trying to use footage from my EX3 in After Effects CS4. When I import the raw footage, it shows up clearly, and even plays properly in RAM previews, but when I export, it freezes for a bit, then skips several frames, then repeats the process till the end of the video."
Since it isn't the greatest thing to use in AE CS4, it's certainly better to convert XDCAM EX footage to compatible format with After Effects CS4 for editing. Pavtube Video Converter Ultimate will help you to get XDCAM EX footage working well in After Effects CS4. It is capable of converting a variety of video formats to another format. And meanwhile it supports to convert to many mobile devices and editing software, like After Effects C4/C5/C6, Sony Vegas, Adobe Premiere Pro, and more. CUDA acceleration will give you faster conversion speed. Go to free download and install it now. Mac users should go to iMedia Converter for Mac.
Surprising news! It's time for back to school 2013. In this 2013 back to school sales season, Pavtube is holding a Back to School Campaign till Sep. 30th. Get it now you will have 20% discount for Pavtube Video Converter Ultimate and iMedia Converter for Mac. And there are free or up to 50% off on much other video software.
How to convert XDCAM EX footage to After Effects CS4?
1. Load XDCAM EX footage.
Two ways for loading: click "Add video" to load source from Sony XDCAM EX, or click "Add from folder" to import the entire folder.
Tips: If you want to joint several videos into one, "Merge into one file" will help to convert multiple videos into one output video.
2. Select format for After Effects CS4.
Click "Format" menu to choose output format. Go to "Adobe Premiere/Sony Vegas" to choose the target format.
Tips: You can select the output video and audio settings to optimize the output files, like bitrate, frame rate, codec, audio channels, etc. But for the best output video quality you’d better keep the original settings of source files.
3. Start conversion.
Once conversion is completed, click Open to locate the generated files for After Effects CS4
Other features:
1. It can rip and convert latest DVD and blu-ray disc. And it is a great tool to backup discs: "Copy the entire disc" will 1:1 backup the whole movie with original structure, and "Directly Copy" can copy the main movie of the disc without menu and titbits.
2. You are allowed to edit the video, such as trim, crop, add watermark of text, image and video, attach subtitle, etc
This integrated software will give you more than you have to do. Go to import the generated video into After Effects CS4 to enjoy editing, and try more other functions now.
Refer to convert Sony XDCAM file to other editing software as below:
Transfer Sony XDCAM footage to QuickTime
Import Sony XDCAM footage to FCP on Mac
Convert Sony PMW-350 XDCAM MXF to iMovie/FCE
Transfer Sony XDCAM EX MP4 footage to Aperture 3
Editing Sony PMW-EX3 XDCAM MP4 clips with Mac
Importing Sony XDCAM HD files to Pinnacle Studio and Sony Vegas
Edit Sony PDW-700 XDCAM HD MXF in Sony Vegas Movie Studio 12
Working with Sony XDCAM EX media on Windows
Source: Convert Sony XDCAM EX MP4 footage to After Effects CS4, CS5, CS6 for editing
Korisnici koji su trenutno na forumu: Nema registrovanih korisnika i 35 gostiju
