To stream AVI files to Apple TV 3 gen for playback
Postod jacknjchn » 13.08.2013 3:15
[size="4"]To stream AVI files to Apple TV 3 gen for playback, you may have to convert AVI to Apple TV 3 supported file types first. Below is a guide for you.[/size]
Convert AVI to Apple TV 3 supported file types .m4v
The 3rd generation of Apple TV (ATV 3) devices boosts the internal processing power and provides long-overdue 1080p HD playback. On this basis, we are allowed to stream higher quality movies to Apple TV 3 for playback on our TV set.
But there is a problem that Apple TV 3 supported video formats are limited, nearly the same as the new iPad, it only supports H.264/MPEG-4 .mp4, .m4v, .mov and M-JPEG .avi file formats. This means that common 1080p or 720p AVI movie files can't be used by Apple TV 3 suitably. For this case, we have to convert AVI to Apple TV 3 compatible video formats first. At the same time, people whose Home Theater supports 5.1 surround sound, may hope to keep the 5.1 channel, today, i will give you a perfect solution to convert AVI movies to Apple TV 3 with 5.1 channel.
Note:
Only when your movie has 5.1 channel, you will get the real 5.1 surround sound effect.
First you need to download Brorsoft Video Converter (available for Windows and Mac users), a powerful high-quality video converter, editor and player. It has a special Apple TV 3 5.1 channel preset. With few clicks, you will finish the conversion. And the perfect result video quality is also impressive. If you are streaming and playing AVI, MKV, TiVo, MPG, MPEG, WMV etc. HD/Full HD videos to Apple TV 3, chances are you already installed this great free utility. If not, download it from below.
Tutorial on transcoding AVI to Apple TV 3:
The process uses Video Converter windows screenshots. The way to encode AVI to ATV 3 on Mac is the same.
Step 1. After installation, run the Mac 1080p AVI to Apple TV 3 converter. and click “Add Video” button to load your source files. You can either load your source videos one after another or directly load from a folder.
Step 2. Select output format. Click on "Format > Apple TV > Apple TV 3 Dolby Digital Pass-through (*.m4v)", this profile is just what you need. This format will ensure you 1080p quality with Dolby Digital 5.1 surround sound pass-through.
Tips: When you choosing “Apple TV 3 Dolby Digital Pass-through (*.m4v)” as output, an AC-3 encoded audio track will also be included for Apple TV 3 to Pass-through Dolby Digital 5.1 sound (also know as AC3 5.1), so that it will work in surround sound when Apple TV 3 is connected to audio receiver, and in stereo when Apple TV Gen 3 is connected with TV only.
Step 3. Start the 1080p AVI to Apple TV 3 conversion by clicking on "Convert" button.
After the short conversion, you ill be able to get the output files for Apple TV 3 via clicking on “Open” button effortlessly. Now you can transfer AVI movies to the new Apple TV 3 for enjoying with high quality and 5.1 sorround sound. You should know, for streaming media from a Mac or PC, iTunes must be 10.6 or later. And to get 5.1 sorround sound, AV Reciever is necessary.
Related Guides:
Convert 1080p video to the new Apple TV 3
Brorsoft Apple TV Column - Provides Apple TV Converter
Connect the new Apple TV 3 to iTunes- Sync movies, music to the new Apple TV 3
Connect Apple TV to Mac OS X Lion— Sync video from iTunes to Apple TV
Play AVI on Apple TV( ATV 2/3) on Mac/Win(Windows 8 included)
Backup Blu-ray/DVD movies to iTunes 11 for Apple TV
How to Convert MKV files to Apple TV 3 (Mountain Lion)
Best tool for transferring Canon S10 to FCP/iMovie
Convert Sony EX1/EX3 MP4 clips to DNxHD for Avid MC
Rip and Convert Blu-ray/DVD in Windows 8
Get movies off Blu-ray/DVD discs and onto Surface RT
Can I import AVI/DV files to Pinnacle Studio natively?
How to Import AVI videos to Windows Movie Maker
jacknjchn
Postova:  53
Re: To stream AVI files to Apple TV 3 gen for playback
Postod lydia622520 » 15.08.2013 11:39
Summary: AVI is a container which contains media streams(subtitles, audio, video, chapters). Due to this, lots of people have issues to play AVI videos on Apple TV (2/3) . The following guide is written for Apple TV 2/3 owners who feel like downloading their movie library including AVI movies and various other formats of 1080p, 720P videos to Apple TV(ATV 2/3 gen)for playback on the go.
The new Apple TV comes with some minor changes like A5 chipset, iCloud video support and 1080p support. According to me the Apple TV 3 is the best for people who own iOS device and have much spent much of their cash in Apple’s online movie. It still has features such as iCloud backup of the TV, iTunes Match, Photo Stream, etc.
Specs for Apple TV Highlight:
Video Formats:
●H.264 video up to 1080p, 30 frames per second, High or Main Profile level 4.0 or lower, Baseline profile level 3.0 or lower with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
●MPEG-4 video up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
●Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
Audio Formats:
●HE-AAC (V1), AAC (16 to 320 Kbps), protected AAC (from iTunes Store), MP3 (16 to 320 Kbps), MP3 VBR, Audible (formats 2, 3, and 4), Apple Lossless, AIFF, and WAV; Dolby Digital 5.1 surround sound pass-through
Yes, there is a problem that Apple TV 3 supported video formats are limited, nearly the same as the new iPad, it only supports H.264/MPEG-4 .mp4, .m4v, .mov and M-JPEG .avi file formats. This means that common 1080p or 720p AVI movie files can't be used by Apple TV 3 suitably. For this case, we have to convert AVI to Apple TV 3 compatible video formats first.
Today, i will give you a perfect solution to convert AVI to Apple TV 3 supported file types .m4v with 5.1 channel.
Note:
Two versions available: Video Converter for Apple TV (supports Slika2000/XP/Vista/Windows 7/Windows Slika and Apple TV Video Converter for Mac (supportsSlika Mac OS X Leopard/Snow Leopard/Lion/Mountain Lion).
How to complete the AVI to Apple TV (3) conversion on Mac/Windows (Windows 8 included) quickly and easily:
The process won’t take much time. Wait for a short while, you will get the converted video files. Then just drag and drop the converted AVI videos to iTunes for streaming to Apple TV! Now you can sync and copy AVI movies to the new Apple TV 3 for enjoying with high quality, Great Job!
Related Guides:
Natively edit Panasonic V700 1080/50p 60p MTS in FCP
Rip and Convert Blu-ray and DVD discs to Windows 8 OS
Top 5 Blu-ray Ripping Programs Ranking and Review
Importing GoPro HD Hero2/Hero3 video to Sony Vegas Pro
Panasonic Lumix DMC-LX7 Workflow: Avid, FCP, iMovie, Premiere Pro
Convert Blu-ray/DVD/ISO to Galaxy Tab 3 8.0 best video format
Tips to Watch HD Movies on Asus Vivo Tab RT Windows RT Tablets
lydia622520
Postod JeanLiu » 09.01.2015 10:01
Pavtube Unlocks Up to 50% Off 2014 Christmas Deals along with upgrading
To celebrate the biggest festival Christmas, Pavtube offers up to 50% off promotion and discount on its all Blu-ray, DVD Copy and Video Converters. Never miss!
Tags: pavtube christmas deals,2014 christmas gift,christmas promotion at pavtube
The year may be coming to a close, but entertainments as well as deals are still in full swing. To celebrate the biggest festival Christmas, Pavtube Studio, which aims at creating expert multimedia software applications, provides the biggest discounts and sends their Christmas joys with their registered users and potential customers.
At its released 2014 Christmas special page, all Blu-ray, DVD and Video Converters are on sale with up to 50% off promotion. This activity starts now and expires on January 31, 2015. Seize the opportunity and enjoy the Christmas joyfulness with Pavtube Studio!
Slika 2014 Christmas Promotional Items
1. 20% OFF - 30% OFF Gifts
20% OFF Pavtube DVDAid (Win/Mac)
20% OFF Pavtube Video Converter Ultimate (Win/Mac)
30% OFF Pavtube ByteCopy (Win/Mac)
30 % OFF Pavtube BDMagic (Win/Mac)
2. Extra $9.9 to Get Another
Buy one converting tool, you just need to pay extra $9.9 to get another one. Just contact [email protected] or [email protected] and get your perferable combination!
3. Share to Facebook to get 50% OFF Gifts
Click "Share on Facebook" button, insert "#PavtubeChristmas2014",choose "Public", and click "Share Link". Then send us the screenshot by email to [email protected] or [email protected]. You will receive a 50% OFF discount link of any Blu-ray/DVD converter from Pavtube within 24 hours on week days. Please do not forget to invite your families and friends to join in, and we’ll appreciate your action!
Follow this link to check our deals and find Christmas wallpapers, games, and ringtones to decorate their Android, Apple and Windows devices.
Everything you need on Christmas Day can be found on Pavtube 2014 Christmas Deals page. Hurry up now! Get greatest discounts on these must-have tools and get your wonderful Christmas gifts with half price! What Pavtube can do for you:
All-in-one Blu-ray/DVD to any video solution
Full disc copy with original BD/DVD structure, no quality loss
Customize Blu-ray/DVD with built-in video editor
Professional video editing tool with trim, crop, split, merge and other options
What's new in the recent upgraded Pavtube products:
Add H.264 baseline/main/high output profiles
Support H.265/HEVC decode
Support H.265/HEVC encode
Support latest Blu-ray movies
At last, enjoy your most wonderful Christmas season this year! Merry Christmas and Happy New Year!
Money Saving Boundles:
Source:http://open-mobile-share.com/pavtube-2014-christmas-deals/
