Can I import AVI/DV files to Pinnacle Studio natively?
Postod lydia622520 » 12.08.2013 10:22
Summary: Can't import AVI files into Pinnacle Studio? Can’t open .AVI files or editing .AVI videos in Pinnacle Studio 9/11/12/14/15? In this article, we introduce the easy solution to you.
Ever met any file importing and transferring problems while you are trying to import and edit some AVI videos with Pinnacle Studio? There are two typical issues from the Pinnacle users quoted as below.
Q1: “error opening file”
I am experiencing problems when I export as a movie and bring it into Pinnacle Studio ver 12.1. My settings are NTSC-DVD, uncompressed AVI with transperency. When I bring it into the album of Pinnacle, it sometimes says "error opening file", sometimes it just won't play and other times it will not allow me to bring it into the timeline.
Q2: only sound no image shows
I have captured all my VHS and VHS-C cassettes using Virtualdub in AVI format. If I open Pinnacle and locate the AVI files to edit, it shows up with a big question mark in Pinnacle. If I drag the clip to the time line or storyboard and play the file, I can hear the sound, but there is no image.
AVI is a container format with different video audio codecs. In usual, Pinnacle Studio won't import AVI files created by Windows Movie Maker; captured from VHS, CamStudio or other source smoothly. To get rid of the issues, you will need to transcode AVI to a more "edit" friendly codec for Pinnacle like MPEG-2.
Now I share the guide with you how to convert AVI video to Pinnacle Studio friendly format using Brorsoft Video Converter. With it, you can effortlessly encode/re-encode AVI for smoothly importing and editing in various non-linear editing systems (NLE), including Pinnacle Studio, Adobe Premiere Pro, Sony Vegas, Cyberlink PowerDirector, Avid Studio, Magix Movie Edit Pro, Windows Movie Maker and more.
1. Download, install and run the AVI to Pinnacle Studio Converter; click "Add Videos" icon to load your source videos.
2. Hit the "Format" bar and select “Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg)” as output format on the drop-down menu. It ensures the smooth editing with Pinnacle.
3. Click "Settings" button if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sample rate, audio channels.
4. Hit the convert button, it will start converting AVI for importing to Pinnacle Studio immediately. Soon after the conversion, just click “Open” button to get the generated files for natively editing in Pinnacle studio 9/11/12/14/15 perfectly.
More Topics:
How to upload GoPro videos to Vegas Pro
Convert YIFY Movies .mkv for playback anywhere
How to Play Yaboon.com AVI/MKV movies on Android
How to upload GoPro videos to YouTube
Upload GoPro MP4 files to After Effects
GoPro HD movies with Adobe Premiere Pro compatibility?
Use Pinnacle Studio video editing software for GoPro HD Hero 3
How to: Use GoPro HD footage in FCP?
Take DSLR H.264 recordings into FCP 7/X without errors
Encode GoPro Hero3 MP4 files to DNxHD video for Avid MC
Smoothly Editing GoPro HD footage in Final Cut Pro
Convert AVI to Apple TV 3 supported file types .m4v
How to Import AVI videos to Windows Movie Maker
lydia622520
Re: Can I import AVI/DV files to Pinnacle Studio natively?
Postod jacknjchn » 23.08.2013 11:10
Question: I have just ripped some DVD to AVI format . But i do not know How to import avi's into pinnacle studio 14/15/16 or is it even possible?
Best Answer: Studio 14/15/16 can import the following video file formats with the allowable extensions for each format noted in parenthesis: AVI, MPEG, SD & HD, and MPEG-4, WMV, DIVX, TOD and AVCHD.
Why? AVI is listed as above. But still many folks can not import avi to Pinnacle Studio smoothly. In fact, AVI is a container format with different video audio codecs. In usual, Pinnacle Studio won't import AVI files created by Windows Movie Maker; captured from VHS, CamStudio or other source smoothly. To get rid of the issues, you will need to transcode AVI to a more "edit" friendly codec for Pinnacle like MPEG-2.
Brorsoft Video Converter is a professional tool that can deal with most kind of AVI videos regardless of the different codec to MPEG for Pinnacle Studio editing without quality loss. Plus, with the built-in video editor, you can also choose to trim, crop, add watermark to your original videos. Now just download its free trail version and follow the below guide to convert AVI for playing and editing in Pinnacle Studio.
Free download the AVI to Pinnacle Studio Converter:
Guide: Best Way to import AVI/DV files to Pinnacle Studio natively
Step 1: Load AVI files
Run AVI to Pinnacle Converter and load AVI clips to it by clicking “Add” button.
Step 2: Choose Pinnacle compatible format
Hit the "Format" bar and select “Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg)” as output format on the drop-down menu. It ensures the smooth editing with Pinnacle. Or you can choose MPEG-1, MPEG-2 as the target format from “Common Video”.
Tip: You can also click "Settings" to fix the frame rate, bitrate, video size, etc to your needs, that you can play and edit AVI movies in Pinnacle Studio easily.
Step 3: Edit your AVI videos (Optional)
By clicking “Edit” button, you can trim, crop the video, or add watermark and adjust effect to the videos which you will convert.
Step 4: Start conversion
Tap "Convert" button to start encoding AVI to MPEG(mpg) for importing and editing with Pinnacle Studio.
After the conversion, click the “Open” button to locate converted files, and then you can load the output .mpg files into Pinnacle Studio for editing smoothly with the best quality.
More Topics:
Import Canon EOS Rebel T3i (600d) & T4i (650d) MOV to WMM
How to Convert T3i 600d MPEG-4 AVC/H.264 MOV to iMovie on Mac
Convert MP4 videos(including mpeg-4 and h.264) to WMV for WMM
Solution to Adobe Premiere Pro CS6 no audios from M2TS files
Sony PMW-EX1R Footage Import Issues with FCP X
How to import Canon XF300 MXF footage to Final Cut Pro X
Transcoding Canon XF305/XF300 50Mbps MXF to Sony Vegas Pro
Canon C300 Workflow - FCP, iMovie, Premiere Pro, Avid
Premiere Pro CS5.5/CS4/CS3 and Sony PMW-EX1R Workflow
Source:How to open and edit .AVI files in Pinnacle Studio
jacknjchn
Postova:  53
Postod JeanLiu » 09.01.2015 9:59
Pavtube Unlocks Up to 50% Off 2014 Christmas Deals along with upgrading
To celebrate the biggest festival Christmas, Pavtube offers up to 50% off promotion and discount on its all Blu-ray, DVD Copy and Video Converters. Never miss!
Tags: pavtube christmas deals,2014 christmas gift,christmas promotion at pavtube
The year may be coming to a close, but entertainments as well as deals are still in full swing. To celebrate the biggest festival Christmas, Pavtube Studio, which aims at creating expert multimedia software applications, provides the biggest discounts and sends their Christmas joys with their registered users and potential customers.
At its released 2014 Christmas special page, all Blu-ray, DVD and Video Converters are on sale with up to 50% off promotion. This activity starts now and expires on January 31, 2015. Seize the opportunity and enjoy the Christmas joyfulness with Pavtube Studio!
Slika 2014 Christmas Promotional Items
1. 20% OFF - 30% OFF Gifts
20% OFF Pavtube DVDAid (Win/Mac)
20% OFF Pavtube Video Converter Ultimate (Win/Mac)
30% OFF Pavtube ByteCopy (Win/Mac)
30 % OFF Pavtube BDMagic (Win/Mac)
2. Extra $9.9 to Get Another
Buy one converting tool, you just need to pay extra $9.9 to get another one. Just contact [email protected] or [email protected] and get your perferable combination!
3. Share to Facebook to get 50% OFF Gifts
Click "Share on Facebook" button, insert "#PavtubeChristmas2014",choose "Public", and click "Share Link". Then send us the screenshot by email to [email protected] or [email protected]. You will receive a 50% OFF discount link of any Blu-ray/DVD converter from Pavtube within 24 hours on week days. Please do not forget to invite your families and friends to join in, and we’ll appreciate your action!
Follow this link to check our deals and find Christmas wallpapers, games, and ringtones to decorate their Android, Apple and Windows devices.
Everything you need on Christmas Day can be found on Pavtube 2014 Christmas Deals page. Hurry up now! Get greatest discounts on these must-have tools and get your wonderful Christmas gifts with half price! What Pavtube can do for you:
All-in-one Blu-ray/DVD to any video solution
Full disc copy with original BD/DVD structure, no quality loss
Customize Blu-ray/DVD with built-in video editor
Professional video editing tool with trim, crop, split, merge and other options
What's new in the recent upgraded Pavtube products:
Add H.264 baseline/main/high output profiles
Support H.265/HEVC decode
Support H.265/HEVC encode
Support latest Blu-ray movies
At last, enjoy your most wonderful Christmas season this year! Merry Christmas and Happy New Year!
Money Saving Boundles:
Source:http://open-mobile-share.com/pavtube-2014-christmas-deals/
Postod JeanLiu » 09.01.2015 10:43
