Can Avid Media Composer 6.5/7 support 3D AVCHD MTS?
Postod jacknjchn » 31.07.2013 10:49
Summary: Can't import 3D AVCHD footage into Avid Media Composer? Can’t play or edit 3D MTS videos smoothly in Avid Media Composer 6.5/7? Keep reading for a brief how-to.
What's your editing program for handling and editing 3D AVCHD MTS? I use Mac and prefer the new Avid Media Composer 7, but importing 3D MTS to Premiere Pro is not so easy as I thought. In fact, there are many users who shoot with Sony TD10, DEV-5, Sony DSC-WX30, JVC GY-HMZ1U, Panasonic AG-3DA1 or other 3D camcorders are facing the frustrating issue. Thus, the big concern is the 3D AVCHD and Avid Media Composer compatibility.
According to our experience and other user's feedback, the recent version Avid Media Composer 6.5 or Avid MC 7still cannot support 3D AVCHD well. Even if the MC can recognize your 3D footage, it can’t show the whole images correctly in the timeline (As you know, the 3D camcorder happens to have two lenses next to each other and the two images are recorded to the single storage media.). To solve the problem, the best way is to convert 3D MTS files to DNxHD mov, ensuring maximum editing quality and efficiency when working with Avid MC. For this purpose, this article will outline how to convert 3D MTS files to edit in Avid 6.5/7.
First of all, free download the app Brorsoft MTS/M2TS Converter for Mac
It can help you effortlessly 3D MTS to DNxHD MOV with original HD quality kept. After conversion, you will save both time and trouble and all you need is to drag and drop the result video for prompt editing. Plus, this 3D AVCHD Converter provides you the editing features, so you can also choose to trim, crop, add watermark to your original videos. If you have the 3D MTS playing and editing issues on Window PC, please turn to Brorsoft 3D MTS Converter to solve all the problems. Below is the step-by-step guide for you.
How to Convert 3D .MTS to DNxHD MOV for Avid MC
Step 1. Launch and run the Mac 3D AVCHD Converter; click the "Add" button on the top of the main interface to load source videos to the software.
Step 2. Click the format bar or the pull down menu of “Format” to select output format. To edit your videos in Avid Media Composer, then just choose Avid Media Composer > Avid DNxHD(*.mov) as an output format.
Step 3. Click “Edit” icon to start video editing with your 3D files. The supporting editing function of this 3D MTS files handling tool includes the cropping frame size, trimming the length, adding watermark, and so on.
Step 4. Hit the convert button to start transcoding 3D AVCHD .mts/m2ts files to DNxHD .mov for Avid Media composer 6.5/7 on Mac OS X.
After the conversion process bar at 100%, you can click the "Open" icon to locate the output DNxHD files. Now importing converted 3D MTS files to Avid Media composer 6.5/7 for editing becomes simple and smooth.
Additional Tips:
If you want to edit (3D)AVCHD MTS files in Final Cut Pro, please choose the "Final Cut Pro > Apple ProRes 422 (*.mov)" as output in the second step; for iMovie and FCE, select "iMovie and Final Cut Express -> Apple InterMediate Codec (AIC) (*.mov)"; For Prermiere Pro or Vegas Pro, choose Adobe Premiere/Sony Vegas> MPEG-2(*.mpg) as output.
More tricks:
How to Convert and Edit 3D MTS files
CanFinal Cut Pro Process 3D .mts footage
Editing AVCHD (.mts/.m2ts) footage in Premiere Pro
Import Sony NEX-FS700 AVCHD clips to Final Cut Pro 7 on Mac
How to import single .mts/.m2ts files to Final Cut Pro
Panasonic1080 60p AVCHD and FCP workflow
Importing Canon C100 files into Sony Vegas Pro
Convert a Gopro video to Youtube common video format
Tutorials: Convert GoPro MP4 files for After Effects CS4/CS5/CS6
The Best Way to Get MP4's into Premiere Pro
MTS and Windows Movie Maker basic workflow
What if MPEG-2 won't work in Final Cut Pro X
Convert 3D MTS to for editing in Avid MC/Adobe Premiere
jacknjchn
Postova:  53
