Guide to Putting DVD movies onto Samsung Galaxy Tab 3 8.0
Postod jacknjchn » 31.07.2013 8:52
Summary: The article shows you the easiest way to convert DVDs to Samsung Galaxy Tab 3 8.0 highly supported video formats on Mac and Windows so that you can watch DVD movies on Galaxy Tab 3 anywhere.
Easiest Way to Put a DVD on your Galaxy Tab 3 8.0
The Samsung Galaxy Tab's light, bright colorful 1280 x 800 screen makes the 8-inch gadget great for watching movies. If you have some DVD movie collections and want to put your favourite DVD movies on Galaxy Tab 3 8.0 for amusement on the go, first you need to convert DVD movies to Galaxy Tab 3 supported video format.
The tutorial is about how to rip videos from DVD to Galaxy Tab 3 8.0 highly compatible video format so that you can play DVD movies on Galaxy Tab 3 8.0. To get the work done, we need to get some help from third-party softwares. DVD ripping software varies. You may be confused about choosing a most suitable tool. If so, I recommend you try Brorsoft DVD Ripper (available for Windows or for Mac users). It's easy to use for editing and conversion and makes great quality copies of my DVDs.
Frankly, the program is a dynamic DVD ripping tool that can help you transfer DVD to Galaxy Tab 3 8.0 hihgly supported MP4 video files with high output video quality and fast ripping speed. The audio/video synchronization is very good, the size of the subtitles too. Just get it and follow the simple tutorial below to copy DVD movies to Samsung Galaxy Tab 3 8.0 for playing in just a few clicks!
How to Rip and Put a DVD movie on Galaxy Tab 3 8.0
The quick start guide below uses DVD Ripper Windows screenshots. The way to rip DVD movies to Galaxy Tab 3 8.0 on Mac is almost the same. Just make sure you get the right version according to your computer's operating system.
Step 1. Insert your DVD disc into computer's DVD-Rom and then launch the DVD to Galaxy Tab 3 Converter. Click DVD disc button to load the DVD movies. You can also import ISO files, IFO files or DVD folder (DVD folders files name appear like "Video_TS") for conversion.
Step 2. Choose output profile via clicking the Format bar. Here I recommend you select "Samsung > Samsung Galaxy Tab 3 Video(*.mp4)" as the export format. The output videos could fit on Galaxy Tab 3 8.0 perfectly.
Tip: If you think the video size and image quality are not suitable for your Samsung tablet, you can first choose any one of the provided types, then change the settings. Please remember the file size is based more on bitrate than resolution which means bitrate higher results in bigger file size, and lower visible quality loss.
Step 3. When everything is OK, just press "Convert" button to start to rip DVD to Galaxy Tab 3 8.0 mp4 videos.
There, now you know how to get DVD movies onto your Samsung Galaxy Tab 3 8.0 so you can watch them on that gorgeous screen! Keep in mind that some of the settings can be tweaked to improve the video quality but it's a balance between quality and size.
[size="4"]Additional Tips[/size]
If you are considering to get a powerful all-in-one tool to convert videos, Blu-ray movies and DVDs to your Galaxy Tab 3 8.0, Galaxy Tab 2 10.1, Samsung Galaxy S IV, Samsung Galaxy S3, Nook HD, Kindle Fire HD, Nexus 7 and other devices at the same saving time and effort, Blu-ray Video Converter Ultimate will a nice choice for you. If you are running a Windows PC, iMedia Converter Mac is the alternative.
See Also:
Tutorials: Convert GoPro MP4 files for After Effects CS4/CS5/CS6
How to Rip Blu-ray for playback with Galaxy Tab 3 8.0
Galaxy Tab 3 AVI Playback tips
How to Play VOB files on Galaxy Tab 3
How to view 1080p MKV movies on Galaxy Tab 3 8.0
How to Put and Add DVD ISO image files to Galaxy Tab 3 8.0
Add/Copy VOB files to Galaxy tab 3
Importing Canon C100 files into Sony Vegas Pro
Can Avid Media Composer 6.5/7 support 3D AVCHD MTS?
How to Convert MPEG-2 files for Editing in Final Cut Pro X
Rip DVDs for Editing in Avid Media Composer
The Best Way to Get MP4's into Premiere Pro
jacknjchn
Postova:  53
