How to import video from Canon XA10 to Premiere Pro/Avid MC
Postod lydia622520 » 23.07.2013 3:24
Summary: Having issues when importing and editing Canon XA10 AVCHD mts files in Avid Media Composer or Premiere Pro? Get the best Canon XA10 video converter here.
Canon XA10 AVCHD camcorders with its high quality, is popular among the videographers; however, the output videos in AVCHD(a highly compressed format) are rather difficult to handle. And the video editing software for Adobe Premiere Pro, Avid Media Composer can't support Canon XA10 MTS videos on Mac OS X perfectly.
Q1: Canon X10 into Adobe Premiere Pro I am a newbie of Canon XA10. The format shows AVCHD Video (.MTS) - into Adobe Premiere. I have CS5, running on Windows 7, 32bit. I got know Adobe Premiere CS5 and later work with AVCHD video, but require a 64 bit computer. So, I have to convert the files. When I convert .MTS to another format do I lose lots of quality? That is my only worry.
Q2: Work with Canon X10 video in Avid Media Composer The footages I edit are always coming from a Canon XA10 HD Camera. My timeline always end with 1, 2 hours of duration. And i also make a lot of After Effects transitions with Alpha to use on Premiere for de edit, but with the new machine i want to start using Avid Media Composer 6 and stop using Adobe Premiere CS6 (on windows i get a lot of problems... Like the program shutting down all by himself and etc...)
You may got know that the latest version of these Mac applications Adobe Premiere Pro, Avid MC, Final Cut Pro tends to support AVCHD videos, but we have to accept the truth that AVCHD, a highly compressed format is not ideal for editing. More than one problem has been occurred during the importing & editing process like the slow rendering, program crashed, can't recognize the camera...
In order to import and edit Canon XA10 MTS files in Avid/Premiere without crashing problem and avoid rendering, you'd better transfer the Canon XA10 AVCHD footages to Avid or Adobe native format. Brorsoft MTS/M2TS Converter for Mac can help you achieve the goal smoothly. It can aid you to change AVCHD (*.MTS) files to standard MPEG-2 format for Adobe Premiere Pro, DNxHD mov for Avid Media Composer without losing any quality. In fact, it's an all-in-one converter for fast transcoding, deinterlacing AVCHD MTS footage from Canon, Panasonic, JVC, Sony full HD camcorder/cameras on Mac OS X(Leopard/Snow Leopard/Lion/Mountain Lion) that makes the MTS editing work much easier with Non-Linear System. If you are on Window, please turn to Brorsoft MTS/M2TS Converter.
Guide: How to convert Canon XA10 video for Avid MC/Adobe Premiere Pro
Step 1: Install and Launch the MTS Converter for Avid/Premiere on your Mac and load your .mts/.m2ts files to it.
Step 2: Click on the Format box and select a proper format in dropdown-list.
For Avid Media Composer, you can choose Avid Studio> Avid DNxHD(*.mov);
And select Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg) as output format for Premiere Pro.
Step 3: For editing XA10 1080p AVCHD in Adobe Premiere or Avid MC smoothly, the best Frame Rate is 30fps, so we recommend you set 1920*1080 as video size and 30fps as Frame Rate on the Profile Settings.
Step 4: Click the Convert button on the main interface to start the Canon XA10 to Avid/Premiere conversion. Once the process is at 100%, then the converted video is ready for importing and editing on Mac OS X.
Tips on AVCHD Converter for Avid/Premiere Pro:
1. Joining files: Tick the box "Merge into one" on the main interface.
2. Preview: Double click on the file and you can get a preview on the converter.
3. Crop: Edit --> Crop and you can get the imported videos cropped as you want.
4. Auto shutdown: Click Option and tick the box “Shut down the computer after conversion” before conversion starts.
More related guides:
Convert Canon XA10 MTS to ProRes for FCP 7
Can Final Cut Pro Process 3D .mts footage
Import1080 60p/50p MTS to Final Cut Pro
Convert Panasonic Lumix GH3 footage to edit in Avid Symphony
Canon XA10 and Final Cut Pro X Importing workflow
Load Canon XA10 MTS clips into FCP/iMovie/FCE/Premiere
How Do I import .AVI files into Premiere Pro CS5/CS6
Canon XA20 Workflow - FCP, Premiere, Avid, iMovie
How to Import & Edit Sony NEX-VG10 footage in Premiere Pro CS5/CS6
Edit Sony Nex-5N 1080 60P MTS files with FCP natively in ProRes codec
lydia622520
Re: How to import video from Canon XA10 to Premiere Pro/Avid
Postod jacknjchn » 26.07.2013 4:30
Guide: Convert 3D MTS to for editing in Avid MC/Adobe Premiere
"There are plugins out there for 3D editing, but they are expensive even with the latest price cuts by GoPro. If you have Adobe Premiere Pro and Avid Media Composer and you're on a budget then this workflow is for you."
To convert 3D MTS video to Avid MC and Adobe Premiere Pro editable formats, Brorsoft Top MTS Converter for Mac is the best 3D AVCHD MTS to Avid DNxHD(*.mov) for Avid MC and MPEG-2 (*.mpg) for Premiere Pro format converter software. Get the software for free trial and follow the 3D video clips to Avid Media Composer/Adobe Premiere Pro conversion guide step by step.
SlikaBrorsoft 3D MTS Converter for Mac is the right app for you.This 3D AVCHD convert program can handle both 3D and 2D MTS videos and transcode AVCHD to Adobe Premiere Pro, Avid Media Composer, Final Cut Pro, iMovie, etc Mac tools editable format(common 2D, or Anaglyphic 3D). It works excellent and converts seamlessly. What’s more, the 3D MTS files handling tool provides you the editing features, so you can also choose to trim, crop, add watermark to your original videos. If you have the 3D MTS playing and editing issues on Window PC, please turn to Brorsoft 3D MTS Converter to solve all the problems.
Download 3D AVCHD MTS Converter Mac:
Slika Slika SlikaFor Mac 10.5.8, Please download the special installation .dmg file
Transcode/Import 3D MTS Video Clip to Avid MC/Premiere Pro Step by Step
Step 1: Launch the MTS Converter for Mac, and you may either click "Add" button to import .mts files, or directly drag and drop the files into this program.
If you want to join 3D AVCHD MTS clips together, click the "Merge into one file" function.
Step 2: Click the format bar or the pull down menu of “Format” to select output format:
a. To edit your videos in Avid Media Composer, then just choose Avid Media Composer > Avid DNxHD(*.mov) as an output format.
b. To edit AVCHD videos in Adobe Premiere Pro, then Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg) is the suitable video format.
Tip: Adjust the video and audio parameters, including the Bitrate of Video&Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings button on the main interface for getting the best quality before starting conversion.
Step 3: If necessary, click option under “Edit” icon to start video editing with your 3D files. The supporting editing functions include the cropping frame size, trimming the length, adding watermark, and so on.
Step 4: Click the convert button to start transcoding 3D AVCHD .mts/m2ts files to DNxHD .mov for Avid Media composer, MPEG-2(.mpg) for Adobe Premiere Pro immediately.
Once the conversion finished, tap the Open button to locate the converted files. Afterwards, it will be easy for you to bring 3D MTS files to Avid MC/Adobe Premiere Pro for easy editing.
Related Guides:
Import Sony 3D DEV-5 .mts footage to Final Cut Pro X
How toConvert and Edit 3D MTS files
CanFinal Cut Pro Process 3D .mts footage
3D AVCHD in FCP- Panasonic HC-X900M with FCP 6/7/X
How to Transfer Sony 3D DEV-5 AVCHD footage to edit with FCP X
Effect MTS Import into Avid Media Composer 5
Importing MP4 Videos from GoPro to Youtube movies with a FLV/AVI video format
Tutorials: Convert GoPro MP4 files for After Effects CS4/CS5/CS6
Transcoding M2T files to Avid DNxHD for smooth editing Step by Step
How to transcode M2T videos to MPEG-2/WMV for Adobe Premiere Pro
jacknjchn
Postova:  53
