Import 1080 60p AVCHD to iMovie- Sony NEX-7 & iMovie
Postod lydia622520 » 17.07.2013 11:22
Summary: Having issues when importing and editing Sony NEX-7 50P/60P AVCHD footage in iMovie 8/9/11? Get the best Mac MTS to AIC mov Converter to achieve your goal smoothly.
Sony NEX-7 is specially targeted at experienced users, enthusiasts and professionals. It is able to shoot high quality Full HD 1920 × 1080 resolution movies at 60p, 60i, or cinematic 24p in AVCHD format. While, I can’t edit and even play the 1080 60p AVCHD MTS files with iMovie on my iMac. This is a disappointment with the Sony NEX 7 camera. How to successfully import 1080 50p/60p AVCHD MTS to iMovie?
It’s confirmed (at least till now) we can’t imput the raw Full HD 60/50p video to iMovie for freely editing. Because 1080 50p and 60p are not standard video formats, they are unsupported by iMovie. iMovie can smoothly edit videos at 1080p 24/25/30, 1080i 50/60, 720p 24/25/30. So we have to change Sony NEX-7 1080 60p first. iMovie best supported format and codec is Apple Intermedaite codec MOV format, once you transcode Sony NEX-7 AVCHD to AIC in 25p/30p , you can play and edit Sony NEX-7 AVCHD in iMovie smoothly.
Brorsoft MTS/M2TS Converter for Mac is highly recommended, which enables to quickly and easily transcode any AVCHD clip(from Sony, Canon, Panasonic) to AIC with best video/audio settings. Plus, with it, you can also transocde AVCHD recordings to Apple ProRes for FCP, DNxHD for Avid Media Composer, MEPG-2/MOV for Adobe Premiere Pro, etc. So far I never had any issue with it and it's pretty straight forward intuitive user friendly software. If you are facing the problem likewise, just download it and go through the tutorial below.
How to transcode Sony NEX-7 1080 60p AVCHD to AIC MOV on Mac?
Source: Convert Sony NEX-7 60P AVCHD to AIC. MOV for easy editing
Step 1. Run the best MTS Converter on Mac. Then add 1080p Full HD .MTS, .M2TS file to the program.
Tip: Check the box of "Merge into one file", you can batch convert several AVCHD files.
Step 2. Click “Format” and move your pointer to "iMovie and Final Cut Express" Category and choose "Apple Intermediate Codec(AIC) (*.mov)" format. It ensures the perfect editing with your AVCHD files in iMovie program.
Step 3. Freely set video resolution(1920×1080/1440×1080/1280×720/720×480), bitrate(from 1Mbps to 20Mbps), frame rate (24p/25p/30p) by clicking "Settings".
Note: If your AVCHD file is 1080 50p, you need to set the frame rate as 25p while 1080 60p for 30p.
Step 4. Start the fast AVCHD to AIC conversion for iMovie via clicking Convert button.
After the conversion, click "open" to find the converted video. Then you can smoothly put the Sony NEX-7 1080 60P mts file to iMovie for editing with best quality.
Additional Tip:
Edit your raw MTS clips with this best AVCHD to AIC Converter for Mac:
By clicking “Edit” button, you can trim, crop the video, or add watermark and adjust effect to the videos which you will convert.
2) If you want to get 3D effect, just enable this fuction and do settings.
Related Guides:
Import 1080 60p/50p AVCHD Footages to Final Cut Pro
How to ingest Sony 50p/60p AVCHD footage to Premiere Pro
How to Convert Sony Handycam Files on Mac and Windows
Import Sony NEX-VG20 50p AVCHD into FCP 7 on Mac OS X
Import Panasonic GH3 AVCHD 60P movies into iMovie on Mac
Converting M2T files to Apple ProRes for Final Cut Pro
Panasonic1080 60p AVCHD and FCP workflow
Import 1080 60p AVCHD to iMovie: Sony A57/A65/A77
Convert and Import Sony NEX-7 AVCHD to Final Cut Pro X, 7, 6
Import 1080 60p AVCHD to iMovie from Sony NEX-5N
lydia622520
