Best MVI Converter-Change MVI into AVI, WMV, FLV, MOV, DVD
Postod jacknjchn » 25.06.2013 9:04
Summary: Here is the step by step guide on how to easily convert MVI, Canon PowerShot MVI to AVI, WMV, FLV, MOV, DVD, MP4, MKV, etc with great output quality for easily playback or editing work.
What is MVI?
The MVI file extension is the default file type of many digital camcorders. This generally means that the file is uncompressed, and will take up quite a bit of space, and can only be handled by a limited number of programs.
Why to change MVI file type?
It is beneficial to convert MVI to AVI, WMV, MOV, FLV, MP4... because these file formats are more commonly used for viewing and working on a computer, and they tend to take up less space on the hard drive, so it is more efficient to store files this way.
How to convert a MVI file to .avi, .wmv, .flv, mov…?
Just download and install the video converter app- Brorsoft MVI Video Converter.
It’s the best MVI converter for you, which can help you decode MVI files when converting into a different, and ideally more edit friendly, compression format like AVI, WMV, FLV, MOV, MP4, MPEG, MKV, etc. So, you can play MVI clips on PC and portable devices freely; edit MVI footage with Windows Movie Maker, Pinnacle Studio, Adobe Premier Pro, Sony Vegas smoothly. Besides MVI, this video convert program can also convert between any popular video and audio formats as you need. If you are running on Mac, please turn to its equivalent Mac version MVI Video Converter Mac. Download it and follow the tutorial below showing the detailed steps on how to convert MVI.
Step 1: Add files- Press "Add File" button to locate and open your MVI files and then import to the MVI converter. You can also directly drag MVI files to program.
Step 2: Select output format- Click on "Format" drop-down list, you could easily choose the video format you need from its various categories, and the supported formats include AVI, WMV, MOV, MP4, MKV, MPEG, MPG, FLV, 3GP, DVD, VOB, etc.
a. To play MVI in Windows Media Player, convert MVI video to WMV format;
b. To import MVI to Windows Movie Maker/DVD Creator, transcode MVI to AVI format;
c. To edit MVI footage in Sony Vegas/Adobe Premiere Pro, encode MVI to MPEG-2 format
Step 3: Advanced Settings- You can adjust video/audio parameters such as bitrate, sample rate, frame rate, codec, channels, etc after clicking on "Settings" icon.
Step 4: Convert MVI- Press "Convert" button to start the MVI conversion. It will be finished with high output quality and fast converting speed.
After the MVI conversion is done, locate the converted file in the folder you specified and go ahead to import to Windows Movie Maker, Adobe Premiere Pro, DVD creator and other applications or transfer them to your portable devices to enjoy your work now.
See more tips and tricks:
Split or Merge Video files
How to Convert MKV DTS to AC3 5.1 audio
Convert Canon MTS to MP4 for Play on Android
Fast and Easy Way to Rip Blu-ray movies with Subtitles
How Do I Upload Video clips from DVD to Youtube for sharing
Trouble Ripping DVD movies with Subtitles
Source:Best MVI Converter- Change MVI into AVI, WMV, FLV, MOV, DVD
jacknjchn
Postova:  53
