Convert Sony NEX-5R 60p AVCHD to Avid MC compatible video
Postod lydia622520 » 19.06.2013 7:53
Summary: In this article, you can learn the best way to import and edit Sony NEX-5R 60p AVCHD MTS to Avid Media Composer 6.5/6.0/5.5/5.0 without rendering or any other issues on Mac OS X. Find out the solution.
Source:Where to get Sony NEX-5R AVCHD MTS Converter Mac for Avid MC
Sony Alpha NEX-5R has much to recommend it as a top-flight large-sensor, interchangeable-lens camcorder and as a worth-the-upgrade successor to the Sony NEX 5N. It can shoot 1080 60p (50p for PAL)full HD resolution up to 240 fps in short bursts. . However, users find it's difficult to import 60p AVCHD clips to Avid Media Composer.
In fact, Avid doesn't do 1080p60. Very few NLE's do. Actually, 60fps at 1080 is a non-standard format and Avid only works with standard film and broadcast formats. Although, Avid MC has added some plug-ins, actually background converters for the high-definition video format AVCHD, the importing process are unbelievably slow. In order to import the AVCHD to Avid MC for editing, the easy workaround is to transcode 60p MTS to Avid compatible video formats DNxHD .mov. Along with some help from a top AVCHD MTS Converter, it can be done. To help those who wanna edit MTS files in Avid Media Composer without problems, here I share with you a simple guide on how to convert AVCHD clips to edit in Avid MC on Mac.
First of all, downloading the App- Brorsoft MTS/M2TS Converter for Mac
Overall, it’s an easy-to-use AVCHD Converter that can deal nearly all kinds of 1080p, 1080i, 720p MTS, M2TS videos. It can convert Sony NEX-5R MTS files natively for Avid Media Composer on Mac with the editable DNXHD codec .mov format, and then you can edit Sony NEX-5R 60P AVCHD natively in Avid MC 5/5.5/6. Besides, this program can also transcode MTS to an editable format like ProRes for FCP, AIC for iMovie/FCE, MPEG-2 for Adobe; to a playable format like MOV, MP4, WMV, FLV, etc for putting on portable devices iPad, Apple TV, Nexus 10, Kindle Fire HD, Galaxy Tab, etc or uploading to YouTube. Of course, if you are running on Windows, turn to the MTS/M2TS Converter Windows version.
Converting Sony NEX-5R 60p AVCHD to DNxHD .mov that Avid Media Composer 6.5/6.0/5.5/5/4 handles well:
1. Download the Mac AVCHD to Avid MC Converter, follow the prompts to install the program. Click “Add” to load Sony NEX-5R MTS video files or directly drag the files to the program.
2. Click “Format” bar to choose Avid Media Composer -> Avid DNXHD (*.mov), this format is best presetted for Avid Media Composer editing.
3. Tap Settings” button in the main interface to customize the Video Codec, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels as you want.
4. Hit the convert button under the preview window, the Mac MTS to Avid converter will start transcoding .mts to Avid MC on Mac OS X immediately. Soon after the conversion is finished, just click “Open” button to get the generated files for editing in Avid Media Composer perfectly.
Related Guides:
How to edit MTS files in Pinnacle Studio
Import Sony DSC-HX200V videos to Avid MC
Import Sony NEX-FS700 AVCHD to Avid MC 6.5 Mac
Convert Panasonic Lumix GH3 to edit in Avid Symphony on Mac
Solve importing problem of Sony NEX-FS100 MTS to Avid MC 5.5
Converting Sony NEX-VG900 AVCHD to DNxHD for Avid Media Composer
How to Transfer Sony 3D DEV-5 AVCHD footage to edit with FCP X
ake AVCHD content off Canon Vixia HF G25 to edit smoothly with iMovie
Canon C100 Raw Footage work with Premiere Pro
lydia622520
