Convert Canon PowerShot N Video to Mac (FCP, iMovie, FCE)
Postod kelly456 » 29.04.2013 10:14
Summary:In this article, you will know how to import Canon PowerShot N footages to Mac (FCP, iMovie, FCE).
The black PowerShot N Digital Camera from Canon inaugurates a new series of digital point-and-shoots. It is a sleek, compact camera with a wide-angle zoom lens, tilt and touch LCD panel and Wi-Fi connectivity featuring a convenient Mobile Device Connect Button.
Full HD 1080p Video
A dedicated movie button makes it easy to switch directly to video mode. With one touch of the button you are able to capture video in Full HD 1080p video at 24 frames per second. Video is also available in lower resolutions and in miniature effect mode and Super Slow Motion mode. Short Movie "Digests" can be created at 1280 x 720 resolution.
How to Import Canon PowerShot N footages to Mac (FCP, iMovie, FCE)?
The Canon PowerShot N recorded videos are H.264 codec MOV format, which supports 1080p full HD recording, many people use Canon PowerShot N record vivid high-definition videos and images. The Canon PowerShot N recorded file format is H.264 MOV, this format is supported by many editing software, but it can't be supported perfectly, take FCP, iMovie, FCE for example.
Final Cut Pro supported best video format is Apple ProRes 422 Codec MOV format, and imovie/FCE best supported video format is AIC codec MOV format. You can edit video with these formats FCP, iMovie, FCE smoothly. So it's great choice to convert Canon Powershot N MOV to ProRes 422 codec MOV format, or to AIC codec MOV format, then you can edit video well on Mac. You can follow the steps below to convert Canon PowerShot N footages for FCP, iMovie, FCE.
1.Download and install Pavtube HD Video Converter for Mac. It's can convert videos between rich video formats, such as convert media from Canon PowerShot N to ProRes 422/AIC for FCP, iMovie, FCE.
2.Drag and drop the Canon powershot N recorded H.264 MOV video to this Mac Video Converter for Canon.
3.Click format column to choose the best output format for editing in FCP, iMovie, FCE.
If you want to edit canon powershot N MOV video in FCP without rendering, you are recommended to choose Final Cut Pro -> Apple ProRes 422 (*.mov).
For editing in iMovie and Final Cut Express, you are recommended to choose "iMovie and Final Cut Express" > "Apple InterMediate Codec (AIC) (*.mov)".
4.You can click settings button to customize the output parameters, such as resolution and bitrate.
5.Edit function is useful and convenient for you to use. You can trim, crop, adjust effects or add watermark to the video.
6.Click convert button to start transcoding Canon PowerShot N MOV to ProRes 422/AIC for Mac in FCPX/iMovie and FCE.
This Canon powershot Converter can help you convert the video format/codec you need quickly, video and audio quality are best guaranteed. You can also follow this article to import converted videos to final cut pro x for editing.
Related article:
Canon EOS Video to FCP 7 Converter
Edit Canon video in iMovie
Encode Canon Powershot S95 MOV to AVI/WMV
Note: If you want to burn your vivid videos to DVD disc or ISO files for backup or storage, you can take a try on Pavtube DVD Creator, which is a great DVD burning software.
PS. If you have any problem, pls contact with [email=http://[email protected]/][email protected][/email] to get more information. You also can leave a message on Pavtube Community or Pavtube Facebook, we will answer your questions as soon as possilble.
