Backup Blu-ray movie to Iconia W700 for playback
Postod kelly456 » 26.04.2013 11:00
Backup Blu-ray movie to Iconia W700 for playback with full screen(1920x1080)
Summary: Want to rip/compress 1080p Blu-ray to Acer Iconia W700 Tablet friendly format? Want to play Blu-ray movies on Iconia W700 with subtitle? Follow this tutorial to convert Blu-ray to MP4 for Acer Iconia W700 playback without any hassles.
Acer Iconia W700 Pros and Cons
Pros
[*]Dual core processor
[*]Very fast processor (1800 MHz)
[*]Lots of RAM (4096 MB RAM)
[*]HDMI connector for TV-out (Micro HDMI (Type D)
Cons
[*]The camera lacks flash
[*]Lacks microSD slot for storage expansion
[*]Lacks an ambient light sensor for automatic screen brightness adjustment
[*]Lacks global positioning system (GPS)
Acer Iconia W700 Support File Formats
Video Format: MP4, MPEG4, H.263, H.264
Video Resolution: 1920 x 1080 pixels
Audio Format: MP3, AAC+, WAV
Description
The Acer Iconia W700 comes with an 11.6 inch screen that has a 1080p resolution, and the tablet has 4GB of RAM and a 64GB SSD. Reviews indicate this Windows 8 Pro tablet is a powerful portable media player that supports universal codecs. However, Blu-ray and DVD movies are not supported by Acer Iconia W700, even if you hack protections and copy movies to Acer Iconia W700. To watch Blu-ray movies on Acer Iconia W700, you also need to convert the M2TS stream clips to MP4 format, which is naturally supported on Acer Iconia W700. With Pavtube Blu-ray to Iconia W700 Ripper, you can easily convert DVD and Blu-rays to Acer Iconia W700 ready 720p/1080p videos. Pavtube provides you with Blu-ray to Acer Iconia W700 Ripper trial, which is free, clean, and safe.
Blu-ray to Acer Iconia W700 Converter from Pavtube, provides quick output profiles for you to choose according to your usage. No matter you are using Microsoft Surface, Samsung Series 5/7 Slate, Lenovo IdeaPad Lynx, Acer Iconia W510, Asus VivoTab RT tablet, HP ElitePad 900, Google Nexus 10, Samsung Galaxy Note 2, Kindle Fire HD or iPad, you can find the related profile on the converter. It deals with both protected and unprotected Blu-rays, DVDs and even ISO/IFO files. Read on for detailed steps of converting Blu-ray to Acer Iconia W700 optimized videos.
How to Rip and Transfer Blu-rays to Acer Iconia W700?
Step 1. Load movie to the Blu-ray to Iconia W700 Ripper software.
Insert a source DVD into the optical drive, Blu-ray Disc to BD drive.
Install and launch the Pavtube Blu-ray Ripper for Iconia W700, Click "BD/DVD ROM" icon to load Blu-ray movies directly from BD-ROM, or Blu-ray file structure folder from computer hard drive to the ripper tool for conversion.
1. Load Blu-ray ISO for conversion:
With built-in virtual drive, you can now even import and convert Blu-ray ISO to Acer Iconia W700 supported video.
2. Rip main movie for playing on Acer Iconia W700:
The Blu-ray to Acer Iconia W700 displays the main movie of the Blu-ray/DVD disc. You can rip the main title to play on your Acer Iconia W700, or rip the extras for fun on your phone.
Step 2. Select subtitle and audio for converting Blu-ray movies to Acer Iconia W700.
When the Blu-ray movie is loaded, you can select subtitles and audio track (English, French, German, Spanish…) for each chapter. Forced subtitles can be attained, too. Expand the root directory to check movie clips.
Step 3. Set compatible format for copying Blu-ray movies to Acer Iconia W700.
Click the "Format" bar, and choose an appropriate format for Blu-ray to Acer Iconia W700 conversion. The Acer Iconia W700 supports various codecs and formats, here we suggest you use "Acer > Acer Iconia Tab A700 Video(*.mp4)", which is optimized for playing video on the 10-inch Windows 8 tablet.
Tips: You can also follow "Format" bar and choose "Windows"-> "Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)" for best viewing effect. This format gives video of 1280x720, which fits for Acer Iconia W700 and Microsoft Surface slab.
Step 4. Start Fast conversion.
Click the "Convert" button at bottom right, start fast ripping 1080p Blu-ray to MP4 Iconia W700. Blu-ray ripping is a time-consuming process. By processing video conversions on GPU instead of your computer's CPU, ripping time is greatly shorted and more CPU resources can be spared for other applications, making your computer run much smoother. GPU computing based Pavtube Blu-ray Ripper software helps you rip Blu-ray/DVD to H.264 video 3-5 times faster in the availability of NVIDIA's CUDA enabled or AMD APP ready Graphics card.
After conversion you can click the "Open" button to find the converted files. Just transfer media contents to Windows 8 Tablet(Acer Iconia W700 included) and watch Blu-ray movies on Acer Iconia W700 freely.
You can also read: Microsoft Surface File Transferring | Microsoft Surface Column
If you're running Mac OS, get the Mac Blu-ray Ripper instead.
What else can the Windows 8 Blu-ray Ripper do for you?
1. The Windows 8 Blu-ray Converter allows you to outputs video clips as one file or by chapter, trim out unwanted frames, remove interlacing lines, adjust video bit rate, frame rate, codec, etc.
2. The software supports all the popular Android, iOS and Windows devices (Microsoft Surface, Samsung Series 5/7 Slate, Lenovo IdeaPad Lynx, Acer Iconia W510/W700, HP ElitePad 900) and more portable media players (Xbox 360, PS3, Apple TV 3, PSP, etc).
3. The Windows 8 Blu-ray Converter also converts Blu-ray ISO, DVD and DVD ISO/IFO files to MP4, AVI, MKV, WMV, MOV, etc.
PS. The Original From best-tablet-converter.com
