Import BlackMagic Intensity Pro ProRes to Premiere Pro CS
Postod kelly456 » 18.04.2013 10:11
Import BlackMagic Intensity Pro ProRes to Premiere Pro CS3/CS4
Summary: To solve how to import and editing BlackMagic Intensity Pro ProRes files to Premiere Pro, you need to select a ProRes to Premiere Pro Converter for Mac program which can handle the special Black Magic Intensity Pro ProRes files. The article will show you the answer.
"I'm getting the BlackMagic Design Intensity Pro (Mac OS 10.6.6) to capture in 720 59.96 ProRes 422, which work great on my Mac Lion with FCP 7 setup. The issue I've been running into lately is I need to collaborate with other studios that are using Adobe Premiere Pro CS4. The issue I need to create some premiere project on my Windows 7 pc while Premiere Pro doesn't/ can't import ProRes 422 files (.mov files). Is there any plugin or solution that I can get Black Magic Intensity Pro ProRes files compatible with Adobe Premiere Pro?"
ProRes in a MOV file format from Black Magic Intensity Pro is beyond the capability of Adobe Premiere Pro. To solve the problem, you need to convert Black Magic Intensity Pro ProRes to Premiere Pro supported format and codec. Follow the instructions/guide below to get Intensity Pro ProRes files into Adobe Premiere Pro for editing.
Required tool:
Pavtube HD Video Converter for Mac - A professional ProRes to Premiere Pro Converter
PS. If you run PC, pls download and buy ProRes Converter
The Mac ProRes Converter for Premiere Pro provides customers with several simple editing functions, including cropping, trimming, deinterlacing, watermarking, adding special effects, and audio replacing, which help you do a fast and necessary editing on your footage before importing them to Premiere Pro Media Composer. It also supports versatile output options for iPad, Android tablets and mainstream editing software.
Read More:
[*] Convert BlackMagic Intensity Pro ProRes to DNxHD MOV for Avid
[*] Transfer BlackMagic Intensity Pro ProRes files to Adobe After Effects
How to Convert Black Magic Intensity Pro ProRes 422 files to MPEG for Premiere Pro
Step 1. Run the Mac ProRes Converter as the perfect Pro ProRes to MPEG Converter, and add your Black Magic Intensity Pro ProRes footage into this program.
Step 2. Click on "Format" bar and select output format from drop-down list. Premiere Pro prefers AVI or MPEG format for editing. Here I suggest you follow "Adobe Premiere Pro/Sony Vegas" to select "MPEG-2 (*.mpg)" or "WMV (VC-1) (*.wmv)" format. You can also choose "Format -> HD Video -> MPEG-2 HD Video(*.mpg)" as out format for Premiere Pro.
Step 3. You can control output video quality by setting resolution, bitrate and frame rate in "Settings". For preserving 5.1 channels surround sound, set audio channels to "5.1 channels" instead of Stereo. To keep 1080p full HD high quality, you can set video bitrate up and Size to 1920x1080.
Step 4. Click on the "Convert" button to start converting ProRes 422 files to Premiere Pro supported MPEG format. By ticking off the checkbox before "Merge into one file" option, you can combine all the checked videos into one file.
When conversion is completed, you can click "Open" to get the Premiere Pro MPEG files from its default output folder.
Now open up Adobe Premiere Pro and you're ready to import Black Magic Intensity Pro recordings to Premiere Pro CS3/CS4 for post-production~
