Convert AVCHD in MTS, M2T, M2TS to ProRes MOV for Final Cut
Postod kelly456 » 13.02.2013 13:47
Import AVCHD in MTS, M2T, M2TS to Final Cut Pro HD/6.0/7/X on Mac
Summary:In this post, it shows the way to Import AVCHD in MTS, M2T, M2TS to Final Cut Pro HD/6.0/7/X on Mac, you can transcode AVCHD video footages to MOV with prores codec.
AVCHD (Advanced Video Coding High Definition), often with the file extension of mts, m2ts or mt2, is a professional digital recording format for Sony, Panasonic, Canon and more camcorders and cameras. Though Final Cut Pro HD/6.0/7/X announced to support AVCHD video files, some AVCHD files still can not imported to Final Cut Pro HD/6.0/7/X: AVCHD support is available only on Intel-based Macintosh computers; FCP only supports AVCHD camcorders typically connect to computers via USB 2.0, not FireWire; DVD-based AVCHD camcorders are not currently supported by Final Cut Pro HD/6.0/7/X; Standard definition video recorded with AVCHD camcorders cannot be accessed in Final Cut Pro HD/6.0/7/X.
In order to import all kinds of AVCHD to Final Cut Pro HD/6.0/7/X successfully, it is better to convert AVCHD in MTS, M2T, M2TS to Apple ProRes 422 which works well with Final Cut Pro HD/6.0/7/X.
The following article just aims to provide a step by step guide on how to convert AVCHD in MTS, M2T, M2TS to ProRes with almost no loss of video and audio quality.
1. Download Pavtube MTS Converter for Mac - the professional AVCHD to ProRes Converter, install and run it, the following interface will pop up.
2. Choose the best format for Final Cut Pro HD/6.0/7/X, please select Final Cut Pro -> Apple ProRes 422 (*.mov) from the "General Video" as output video format.
3. Do some adjustment as you need, such as resolution, bitrate, etc. It is ok to keep it as original.
4. Startconverting AVCHD in MTS, M2T, M2TS to Final Cut Pro HD/6.0/7/X.
The AVCHD to Final Cut Pro HD/6.0/7/X converter will transcode the MTS, M2T, M2TS immediately. It can help you convert MTS to ProRes, convert M2T to ProRes, and convert M2TS to ProRes. Then it is just easy to import the converted AVCHD whatever from Sony, Panasonic, Canon or JVC to Final Cut Pro HD/6.0/7/X. Here is also an article about how to import videos to final cut pro.
You may learn how to convert AVCHD to ProRes 422 on YouTube.
http://youtu.be/7H4y5C6n7TA
More related articles:
Edit Sony Cyber-shot DSC-WX80 footages in FCP 6/7
Transfer media files from Sony HX30V to FCP X, iMovie, FCE 4, Avid, Premiere
Convert MTS clips to Aperture editable files
Work with NEX-6 50p/60p MTS clips in Final Cut Pro
Canon C100 and FCP workflow
How can I edit NEX 50p/60p AVCHD with Avid MC?
Ingesting M500 MTS to FCP on Mac
Now if you buy any converter product, you can get DVD Creator product for free, which can easily burn AVCHD to DVD disc/ISO files. In the promotion activity, you can get up to 40% off on other products, please have a look.
Learn more Canon Cameras/Camcorders related tutorial, pls view our MTS Column, FCP Column, etc. on http://www.pavtube.com/hot-topics/
