How to burn purchased itunes movies to NTSC DVD disc?
Postod kelly456 » 23.01.2013 13:06
What is NTSC?
Basically it is the difference in frames per second used by televisions in different parts of the world. There are two television display systems in commercial use: PAL (common in Europe and parts of Asia) delivers a frame rate of 25 fps (frames per second) with 625 lines, while NTSC (used in the U.S. and Canada) delivers a frame rate of 30 fps using 525 lines.
The color information of the signal is also encoded differently. Most TVs decode the PAL or NTSC signal but the color information will be lost and the picture appears black and white.
How to convert purchased iTunes movies to NTSC DVD?
"I have iTunes 10.5 and I tried converting the movie "The Bourne Legacy" that I purchased on iTunes to a NTSC DVD file. It converted it with output length of 6.04 GB that seemed right to me. When I try to play it on WM or CL Power DVD it gives me a green screen through the entire movie but there is audio that seems fine. Where is the problem? Thank you.”
Solution:
First you will need to know that iTunes movies are DRM protected, you will need to remove DRM protection from iTunes movies, and convert it to unprotected video for DVD burning.
So you will need two software: Pavtube Chewtune, Pavtube DVD Creator
The Chewtune is to convert DRM iTunes movies to common video, the DVD Creator is to burn converted videos to DVD disc.
Brief guide:
Part 1: Convert DRM iTunes movies to common video like MP4 or WMV, MOV.
Part 2: burn converted iTunes video to DVD
Now please follow:
Part 1:
1.Run this iTunes movie converter, load your iTunes movies into it.
2.Choose output video formats, you can choose MP4 or MOV/WMV for output. After choosing output format, click "Settings” you will see the full information of this profile, you can adjust some of them by yourself to get the video quality you want.
3.Start converting iTunes movies for DVD burning by clicking on "Convert" button.
Part2:
1.Download and install Pavtube DVD Creator, with it, you can burn converted iTunes movies to DVD, burn any common videos to DVD disc or ISO image file.
2.Click the import button to load your videos, you can click Add title button to add more titles.
3.Switch to Menu pane. Double-click a DVD menu beneath the Menu Template to apply it to your DVD. You can customize the background video/image, background music, text, title thumbnail and more for your DVD menu.
4.Click the Burn button to start burning iTunes movies to DVD.
Now you have got the point to burn purchased iTunes movies to DVD disc via Pavtube Chewtune and DVD Creator, both are very useful tools. Now before its Christmas promotion finished, if you buy any converter product, you are qualified for "buy one get one”, please go to its activity page to learn more.
Learn more related tutorial, pls view http://www.pavtube.com/hot-topics/
