Recover Lost Contact Directly from iPhone 4 on Mac
Postod coreykaman » 14.12.2012 5:45
This video is the detailed guide of how to recover lost & deleted contacts for your iPhone 4 without itunes backup file directly on Mac.
Watch Video:
Dr.Fone for Mac can help you easily recover photos, contacts, text messages, and more on iPhone, iPad and iPod touch. Retrieve lost & deleted data directly from your iOS device, or via its iTunes backup file.
•Directly recover from your iPhone 4/3GS, iPad 1 & iPod touch 4 or iTunes backup
•For all other iOS devices, like iPhone 4S, iPhone 5 and iPad with Retina Display, recover via iTunes backup
•Recover up to 12 file types, including photos, contacts, messages, videos, notes...
•Preview photos and read details of messages, notes, calendar, call logs, and more
•Get back data lost due to accidental or intentional deletion,iOS device damage or iOS crash
Directly Recover Lost Data from Your iOS devices on Windows
Recover Lost Data from iPhone 4
Recover Lost Data from iPhone 3GS
Recover Deleted Data from iPad 1
Recover Deleted Data from iPod Touch 4
coreykaman
Postova:  40
Pridružio se:  24.03.2012 14:44
Re: Recover Lost Contact Directly from iPhone 4 on Mac
Postod Wensir2 » 28.03.2014 5:54
Actually, there are two ways to recover contacts from iPhone 4, one is from the iTunes backup files, another one is recover them directly from the iPhone with the help of iPhone Contacts Recovery software, since you are wondering about the way without the using of iTunes backup, you can choose a kind of iPhone Data Recovery software to recover your data in a few steps and it is very easy and fast, you can have a try!
Solution 1: Directly scan and recover data from iPhone
Step 1: Run the program and connect your iPhone
Step 2: Download a plug-in separately for your iPhone
Step 3: Enter the device's scanning mode and scan it
Step 4: Preview and recover deleted iPhone data
Solution 2: How to scan and extract iTunes backup to recover iPhone data
Step 1: Choose iTunes backup and scan it
Step 2: Recover deleted iPhone data
Tips: After recover data and save them on your computer, you can transfer the restored data from computer to iPhone again with iPhone to Computer transfer tool
Learn more:
how to recover deleted photos from iphone 4
how to retrieve deleted text messages on iphone 4
how to recover deleted videos from iPhone 4
Wensir2
Postova:  3
Pridružio se:  28.03.2014 5:37
Postod Winsena1 » 14.05.2014 18:57
Usually, iTunes will automatically backup your iPhone when you sync with iTunes. If you have the backup, then restore iPhone contacts will be easily:
Here are the steps:
Click the "File" menu and select "Devices" > "Restore from Back up".
Or
Open the iOS device's "Summary" tab. There are two ways to access this:
Click the device button in the upper right corner. (If viewing the iTunes Store, click the Library button in the upper right corner. The device button will then be visible.)
From any view in iTunes, click the "View" menu and select "Show Sidebar". Select your iOS device in iTunes under "Devices:.
Click the "Restore Backup" button.
Learn more:
how to recover iPhone photos
how to retrieve deleted text messages on iPhone 4
Winsena1
Postova:  2
Pridružio se:  14.05.2014 18:30
Postod Enmama21 » 29.05.2014 13:32
It is really annoying that you lost all your iPhone contacts when you reset your iPhone or delete them unintentionally. You wonder whether there is a way to solve this hard case. I can definitely tell you "YES", there are two way to restore iPhone contacts.
The iPhone data recovery tool is a convenient and efficient device, which can scan your contacts quickly to restore it. One way is to recover the lost contacts directly; another way is to restore contacts from an iPhone backup, on the basis that you have used iTunes to manage your iPhone.
How to Recover Deleted Contacts from iPhone
How to Recover Lost Video from iPhone
How to Restore Safari Bookmarks from iPhone
How to Recover Data on water damaged iPhone
Enmama21
Postova:  3
Pridružio se:  29.05.2014 12:58
Postod Loborin13 » 10.07.2014 9:42
It is really annoying that you lost all your iPhone contacts when you reset your iPhone or delete them unintentionally. You wonder whether there is a way to solve this hard case. I can definitely tell you "YES", there are two way to restore iPhone contacts .
Read more:
How to Recover Data from Broken iPhone
How to Recover Deleted Photos from iPhone
How to Print Contacts from iPhone or iTunes Backup
Loborin13
Postova:  2
Pridružio se:  09.07.2014 12:12
Korisnici koji su trenutno na forumu: Majestic-12 [Bot] i 15 gostiju
