[Mac PDF Editor] Edit (add/delete/modify/copy) PDF Text Mac
Postod worthy32 » 28.11.2012 11:32
Have you ever come across the situation that the PDF files are not available to edit? Sometimes you may need to edit the PDF file like adding text, modifying text and more for business or other reasons. Here is an easy and fast way to achieve your demands.
With PDF Editor Pro for Mac, you can edit PDF text directly such as: move, delete, add or correct text to the original content instead of overlaying a text box above the page. Moreover, it also enables you to set font as you like.
The Main Features of PDF Editor Pro for Mac:
Simply Edit & Convert scanned PDF documents with OCR technology
Edit(Add, modify, move, delete) Text in PDF files
Insert/move/copy/crop/resize/delete images within PDF files
Export Word/Excel/PPT/EPUB/HTML/Image/Text/RTF from PDF
Annotate by adding notes, text boxes and graphics to PDF files
Markup PDF with highlighting, underscoring, and strikethrough
Insert, split and merge PDF files
Video Demo:
More PDF Tools:
Edit PDF text/images/watermark, insert/extract/delete PDF pages
Convert PDF (Scanned) files to Word, Excel, PPT, ePub, RTF or Text
Remove PDF Password Restrictions (copying / printing / editing)
worthy32
Postova:  36
Pridružio se:  29.02.2012 5:15
